car won't start after deflooding procedure
Old Mar 23, 2009 | 05:30 PM
kdparsons80's Avatar
Angry car won't start after deflooding procedure
I installed and amp and sub last night and listened to it with the car off for about 30min. Tried to start a few minutes ago the car didn't start checked the battery it has 12.2 volts, so I tried the deflooding procedure still nothing. Any Ideas???
Old Mar 23, 2009 | 08:06 PM
Anybody got anything???
Old Mar 23, 2009 | 08:14 PM
Side note the car makes three beeps while trying to start. Dont know what that is.
Old Mar 23, 2009 | 08:31 PM
Mazurfer's Avatar
Surf Hard, Drive Hard
Which de-floeed procedure exactly and do you have someone that can give you a jump even though you have 12.2 volts? Just because you have 12volts or so, doesn't mean you got cranking amps left.
Old Mar 23, 2009 | 08:35 PM
chrizknot's Avatar
wORd
you dint flood ur engine if ur car was off, id say jump start it.
you flooded it if you turned it on and off right away.
Old Mar 23, 2009 | 08:47 PM
The reason I think it may be flooded is I can smell the premium after attempting to start. The battery is in good condition, even if it wasn't I have a charger starter, that's what let me know I had 12.2 Volts.
Old Mar 23, 2009 | 08:49 PM
I used the foot in the floor for 10 seconds then trying without gas pedal.
Old Mar 23, 2009 | 08:52 PM
chrizknot's Avatar
wORd
well the amp is ganan suck power from ur battery if the car wasn't turned on. and since you just installed the amp and sub, then you had problems, there is a 99.9 & chance u didnt flood it.
Old Mar 23, 2009 | 08:57 PM
when I made my first attempt it was powered. Then i disconnected the power wire. On sat i was working on the install, and started to go home and the power steering wasnt working. I unhooked everything except the high level inputs no result. When I got home I unhooked that then like magic no problem. So what the heck caused that to stop power steering, and or starting.
Old Mar 23, 2009 | 09:00 PM
StealthTL's Avatar
Check these three fuses - the beeps mean it won't start till the ECU is happy.
EGI COMP1
EGI COMP2
Engine
Old Mar 23, 2009 | 09:03 PM
Checking now
Old Mar 23, 2009 | 09:06 PM
All 3 fuses good. ????
Old Mar 23, 2009 | 11:35 PM
Vyndictive's Avatar
"13B vs. Renesis" Discuss
Need more details:
All other systems appear to work fine?
Did you damage any wires in the wire bundle during installation of the positive wire from battery to amp? Drill through the firewall or use existing holes?
Did you disconnect the battery from the car during the install?
Stealth is right - the 3 beeps mean something isn't right in your electrics that only has to do with the engine. (implied from listening to the stereo the previous night)
The only thing I can say with any level of certainty is that its probably not flooded - Your not starting because of the electrics - thus, probably no spark.
Old Mar 23, 2009 | 11:38 PM
shazy's Avatar
Postt your DIY on how to deflood it. Remember copy paste is your friend
Old Mar 24, 2009 | 02:57 PM
Well I am sharing a ground in the left side of the trunk. Does anyone know what that might be?
Old Mar 24, 2009 | 07:34 PM
okay everything is disconnected power, ground, high level inputs, remote. Still nothing it will crank but not fire. Need help trying to make Midwest Mazda Fest on the 18th.
Old Mar 24, 2009 | 07:39 PM
Sorry Vyn just read your post. I poked a hole through the very bottom of the firewall boot on the lower most circle. During the install I did have a problem with the power steering. Disconnected everything just like now and it worked. Disconnected the negative battery terminal during the whole process.
Old Mar 25, 2009 | 08:02 AM
Vyndictive's Avatar
Hmm, I'm sort of stumped on this one.
Since you smell fuel, lets assume you're fuel pump and delivery system still work fine. Did the 3 beeps go away or are they still hanging around? Pull the plug and confirm that they're sparking when you're starting.
Does the car start when you disconnect all the audio stuff completely?
Unless the PCM and power steering are on the same curcuit, I don't see how those problems would be related unless you some how damaged them in the install. Then again, it could be as simple as a loose wiring harness, but I don't think you're going to get off that easy.
. . . and I thought my install went bad...
Old Mar 25, 2009 | 02:24 PM
The beeping stopped, but still will not start. I'm going to check every fuse next. Then I'll pull the plugs, I don't have my floor jack here or stands right now.
Old Mar 25, 2009 | 07:56 PM
ITS ALIVE!!!!!!!!!!!! Believe it or not I got it started by cranking the *((* out of it. It was flooded. Lots of white smoke and funny smells. Thanks to Everyone Stealth, Vyn, Chirz. You guys were a big help. So should I reconnect everything or not??? That is the question??
Old Mar 25, 2009 | 11:20 PM
Vyndictive's Avatar
Yes... because you know it didn't start because it was flooded... power steering issues?
Old Mar 27, 2009 | 07:02 PM
No power steering issues yet took it for a short ride the other day. The weather hasn't been great here in Northern Indiana lately. The sub and amp are installed but I have to figure out a way to mount it so it won't shift on those s-curves.
Wantingtoknow
Dec 15, 2016 02:25 PM
Davey's RX-8
Jul 28, 2015 12:13 PM
harithac
Jul 25, 2015 04:21 PM
Peanutbuttertruffle
Jul 24, 2015 07:49 AM
Bamaham
Jul 23, 2015 08:08 AM
