Do you need the RP bolt and gasket to install RP cat??
Old Mar 23, 2009 | 01:55 PM
Rena my Rx8's Avatar
as the title says, im finally installing the cat later on today and i bought the cat from someone and i dont know if it came with the bolt and gasket when i bought it. thanks guys.
Old Mar 23, 2009 | 01:56 PM
yeah, those gaskets shouldn't be reused. Best to put a fresh one on when installing the RP. (it's what I did)
also, check the welds on the heat shield around the cat. They're not the greatest and down the weld could break and cause excessive rattle.
Easy fix though, just have someone throw a quick spot weld on it or do it yourself. (muffler shops can probably do it for less then $20)
Old Mar 23, 2009 | 02:02 PM
thanks. and the only place to get that gasket is the website huh??
Not sure if it's the only place, but one of the easist.
Old Mar 23, 2009 | 02:19 PM
aww boooo i guess i can't put it on today then lol damnit!!
Old Mar 23, 2009 | 02:29 PM
baysj's Avatar
yea and the bolts from the stock cat are welded to the cat so you would need new bolts too.
Old Mar 23, 2009 | 02:49 PM
yeah when i meant gasket i meant bolts and gasket haha... thanks for the help guys... i guess i just gotta wait n do it right the first timee.. grrr i hate that!lol
Old Mar 23, 2009 | 02:55 PM
did you check those welds yet?
Old Mar 23, 2009 | 04:52 PM
nah not yet. when i do i'll make sure to let you know.
Old Mar 23, 2009 | 05:10 PM
I took a look at the welding.. n I didn't see anything wrong frm what I cud tell... but then again I'm not an expert on welding...
Old Mar 23, 2009 | 05:13 PM
i looked at the weldings and i didnt see anything that i thought was wrong... then again im no welding expert
jay_tibo
22
Sep 13, 2016 08:10 PM
ableobject
Mar 22, 2016 11:37 PM
FoxRacer600RR
Aug 31, 2015 06:32 AM
RenzoRx-8
Aug 25, 2015 10:29 PM
dbarber
Jul 25, 2015 01:34 PM
