O2 Sensor Fooling
Old Dec 19, 2003 | 04:30 PM
slavearm's Avatar
Boost Junkie
Unhappy O2 Sensor Fooling
Gentlemen,
I got my RP Midpipe in today. Installed the O2 Sensor Fooler and the midpipe. Everything was going fine until about 3 hours later and I threw a CEL. Two questions for you guys.
1. Has anyone tried the O2 Sensor foolers on a RX-8 and had them working?
2. Anyway to get rid of this CEL? (Other than the dealer)
Thanks,
Slavearm
Old Feb 3, 2005 | 03:25 AM
cgrx's Avatar
DRIVEN
Bump
Old Feb 3, 2005 | 06:41 AM
superscout03's Avatar
you dont need the fooler, the cel will come on, but it will go off after a few hours of driving, or just disconnect the battery.
Old May 24, 2005 | 03:06 PM
MazdaManiac's Avatar
The RX8's catalyst monitoring is different from past Mazda models, due to the addition of a front linear oxygen sensor. Past systems monitored front & rear oxygen sensors to compare inversion ratios. This system uses a linear type sensor for fuel control (Front) and a conventional sensor for catalyst monitoring (Rear). The PCM will command the short fuel trim to change from rich to lean 30 times at a 1 HZ interval. This will induce the front oxygen sensor current to cycle from high to low at the same interval. The PCM then compares the waveform inversions of the rear sensor to determine catalyst deterioration. This makes it impossible to use conventional O2 sensor "foolers" to spoof the rear O2 sensor signal.
Old May 24, 2005 | 08:54 PM
Michael's Avatar
Are you referring to the Sparkplug Anti-foulers O2 Sensor Fooler method as seen on STi's and S2k's initially?
Old May 26, 2005 | 12:50 AM
Like Jeff said, the foolers don't work. Like I am saying, if you want to use the catless midpipe then get used to the CEL.
CRH
Or not.
It might be a hit-or-miss thing, but I have had a CAT-less midpipe on my car for about a year now and I've never had a CEL.
Then again, I've never had a CEL on my car for any reason unless I intentionally triggered one by over-limiting a sensor (or unplugging one altogether).
I can't say that I know why, exactly.
Old May 26, 2005 | 10:27 AM
I'm not a big fan of luck.
I'd much rather know what is going on.
Old May 26, 2005 | 05:08 PM
So what, exactly, did you do?
Old May 30, 2005 | 09:51 PM
That is awesome. Nice engineering. I don't see why it works (restriction has nothing to do with the way the feedback system operates on the rear O2 sensor), but that doesn't matter.
Old May 30, 2005 | 10:13 PM
Originally Posted by TR1GGERx1
hey my friend was thinkin the same. u think this will work if i buy a 22mm spark plug non fouler and put it in between the o2 bung and the o2 sensor ? my friend di dit on his s2000 and also on a wrx and worked. im thinkin it would work for me as well?
It isn't 22mm. It is 18mm with a 1.5 thread.
Old May 31, 2005 | 02:58 PM
Interesting. That is very cool.
Too bad I don't need it or I would try it out.
Old May 31, 2005 | 04:28 PM
Well, if you have the Greddy kit, you don't need to do any sort of RPM extraction.
If you are starting from scratch, Greddy now makes an RPM extractor module that is simple to implement.
The diodes are only necessary to condition the outputs of the E-Manage to control the ignition coils.
Old Jul 1, 2005 | 03:29 PM
Rasputin's Avatar
Originally Posted by GTAW
After reading my thread, I guess restriction isn't the best term to use, I know the cat can store about 3-5 seconds of oxygen at idle with a lean burning mixture.
Then, with a rich mixture the stored oxygen will be released. After the cat reaches it storage limit as well, causes the oxygen to be passed into the exhaust.
As the cat loses its ability to store and then release oxygen, the 3-5 seconds starts to decrease causing a current drift that increases quite dramatically. This then falls out of a predetermined range, giving you that lovely CEL and telling you that the cat is not functioning correctly. With out the cats... say, with a midpipe, it doesn't take long for the sensor to go crazy and trip the cel.
So, I was looking at it like a sponge, if you will, and would "soak" up so much oxygen, then ultimately releasing it slowly into the path of the second 02 sensor.
By making a bushing that brings the 02 sensor out at the right amount....(Sorry, an extra 02 bung welded or an antifouler, even in the right size and pitch doesn't work....I've tried it with my car and it lasted about 18 miles.....If you don't belive me, try it!)..... gives the sensor an atmoshpere that resembles a "stock" setup.
That was a crappy way to type that....oh, well. :p But, you get the idea!
So you're bushing induce a slight leak into the sensor's vicinity? Is it what it's doing?
Fabrice
Old Mar 22, 2006 | 12:43 AM
Jeromie's Avatar
i dont get it can u possibly post pics?
Old Mar 22, 2006 | 09:58 PM
lexplay's Avatar
pics please im confuzed
Old Mar 22, 2006 | 10:21 PM
carbonRX8's Avatar
U-Stink-But-I-♥-U
Check the dates. You will have to pm for info.
Old Mar 22, 2006 | 11:37 PM
StealthTL's Avatar
Foolers don't work.....
These bushings don't work.
Even the "GTAW" person has not got it to work.
Nobody who has tried it has had a positive result.
It doesn't work for the Mazda Protege, where the idea originated, and it certainly won't work on the '8.
If you read the previous thread thru, you will notice that Mr. GTAW owns a ScanTool, that he uses to delete the CELs, which may explain why the bushing works SO well for him .
The whole theory of the cat "storing oxygen to release later" is so far off as to be laughable .
Some people have reported that after many CELs, they stop coming so frequently, but that is as good as it gets.
End of truthiness session!
S
Old Mar 22, 2006 | 11:44 PM
carbonRX8's Avatar
U-Stink-But-I-♥-U
I debated saying just what you just said but I thought it better that they learn for themselves. I think there is another thread where GTAW even said that the doo-hicky wasnt working any more.
I love truthiness. It is so much better than thinking.
FWIW my cat, in fact both of them, store oxygen to release later (think about it, it will make sence later.) They also store hair in their gut to release later, too. I just got done pulling, not five minutes ago, one of these special treats out between my toes after steping on it.
Old Mar 23, 2006 | 12:44 AM
I've got a new one if somebody wants it, I won't ever need it since I'll be running a cat
Old Mar 23, 2006 | 12:56 AM
just know that with a midpipe. borla resonator. 15 miles later cel 420 if i remenber correct....
3" out and cat to 3" out. no cel.... go figure.
Old Mar 23, 2006 | 04:31 AM
florent75's Avatar
ebay fooler
receive it next week
say you if this works ...
Old Mar 23, 2006 | 06:47 PM
Moonrover333's Avatar
My Goodness My Guinness
damn i just posed bout that in the Aftermarket section i will delete
Old Mar 23, 2006 | 07:05 PM
modena's Avatar
Modena
S
Sorry to say I run one of said bushings no cell sins 3500 miles.
Without the bushing the cell was on in less then 10 miles of driving the car.
Even the dealer could not find 1 error code stored in the cars ecu.
(Only fault they could find was the tire sensors, OEM tires and rims where replaced)
Have 4 fellow RX-8 drivers that can testify these results!
