mazdaspeed cold air
Old Mar 17, 2009 | 08:22 AM
quillero20's Avatar
mazdaspeed cold air
i just install the cold air intake on my car from mazdaspeed but the check engine light is on with 2 codes (PCM/P0300,RKEP0039) i need help please
Old Mar 17, 2009 | 08:26 AM
Red Rex's Avatar
You probably have a vacuum leak. Make sure all of your lines are secure and ziptie or clamp down ones that feel loose. Get the codes read ASAP.
Old Mar 17, 2009 | 01:50 PM
I believe this cell RKEP0039 has been determined to be nothing.
Search the ECU tunning threads.
P0300 is random misfire. One of the causes is a leak on the intake.
Recheck and tighten the install.
Also, clean the MAF.
Old Mar 17, 2009 | 02:22 PM
laythor's Avatar
I zoom therefore I am.
Cleaning the MAF should be something everyone does at least once a year.
Old Mar 18, 2009 | 08:21 AM
quillero20's Avatar
thank to everyone who replay to my post, i'm going to check that about the leak and also cleaning the maf sensor again but also i have pulleys and i forgot to mentioned them before but i really don't think this is the problem i really think it could be the cold air so i'm going to check that, thank you
Old Mar 23, 2009 | 07:56 PM
REV-N-HIGH's Avatar
I also installed a Mazda Speed cold air, I had to get it tuned in order for the light to go off.
Old Mar 23, 2009 | 08:05 PM
teknics's Avatar
Certified Mazda Tech
what code did you have?
kevin.
Old Mar 23, 2009 | 08:20 PM
Jon316G's Avatar
Grasshopper
Did you remember to cap the VFAD nipple on the intake manifold extension?
Old Mar 23, 2009 | 08:36 PM
laythor's Avatar
tuned how?
Old Mar 23, 2009 | 09:12 PM
kdparsons80's Avatar
I have the MS CAI i had a similar problem. I capped the wrong vacuum line. Make SURE that you got the right one on the manifold. The directions are a little vague on that step.
Old Mar 23, 2009 | 10:12 PM
rofl ?
Tuned ?
My car must be smoking then. cuz I just install mine, and no CEL ever?
Old Mar 24, 2009 | 09:37 AM
quillero20's Avatar
yea i took it to the techs and they said that my problem is the underdriven pulleys so i need to het my car tune..... so guys cold air intake if you don;t put it right like they said tap the wrong vacum or tip it'll get you the code...
Old Mar 24, 2009 | 11:44 AM
teknics's Avatar
underdrive pulleys require tuning? thats wrong too.
if you changed your crank pulley do the NVRAM Reset procedure that may help.
a CAI and underdrive pulleys wont set off a CEL requiring a tune in almost any car i could think of.
kevin.
Old Mar 24, 2009 | 02:40 PM
Unless the installer is an idiot. there is NO WAY that they can install the MS CAI wrong ...
So easy even caveman can do it ...
Pulley needs a tune ? ... hmm ... ok ... nope ...
Old Mar 24, 2009 | 09:01 PM
teknics's Avatar
if you dont put the screen in you can get lean codes, had that happen after installing a motor, apparently when i took the CAI apart the screen turned sideways and wedged in the tube lol.
kevin.
Old Mar 25, 2009 | 08:37 AM
quillero20's Avatar
don't know but i'm going to get the second opinion
RevMeHarder
Jun 1, 2026 02:30 PM
RXFEVER
Aug 29, 2018 10:14 AM
Kahl
NE For Sale/Wanted
21
Aug 5, 2017 02:49 AM
Vedivan1
Sep 20, 2015 04:39 PM
djp6783
Sep 19, 2015 12:12 PM
