Quick question about engine noise...
Old Mar 10, 2009 | 11:09 AM
bigexecutiveguy's Avatar
Hey all, new on here and only had my 2004 8 AT since October. I had a misfire a couple of months ago and got the spark plugs and coils replaced. Drove like a dream...until now, some two months later. Accelerating in 2nd causes a horrid rattling nastiness from the depths of hell, almost similar to the sound I heard when I believe the misfire occurred. Im very new to this if I'm gonna put some money into this, I want it to run like the day whoever took it off the car lot. Any ideas? Thanks for your help!
Old Mar 10, 2009 | 01:13 PM
Silver06's Avatar
Zoom Zoom....
No flashing CEL's, right?
Obviously, you'll want to check that nothing has become disconnected or is loose in the ignition wiring - like a loose or broken plug wire. Pull the sparkplugs and see if they are all a consistent colour.
You should also check the engine mounts. There are many threads, and here is a TSB from Mazda
g.luck.
Old Mar 10, 2009 | 01:35 PM
Engine mounts sounds like a good way to go.
CEL is a come and go thing, never flashes though like with hard accelerating after the misfire. It comes on for a day or two, then its gone for a week. I'll pull the plugs later tonight. Thanks for the TSB.
Old Mar 10, 2009 | 01:36 PM
Easy_E1's Avatar
I hope your using premium gas.
Old Mar 10, 2009 | 01:45 PM
Silver06's Avatar
Zoom Zoom....
Obviously, you'll want to pull the OBDII codes.
Some auto parts stores will read your codes for free (tell them it is a CanBus system).
There's a table converting the numeric codes to component descriptions in words: here
Old Mar 10, 2009 | 01:55 PM
Highway8's Avatar
Registered RX8 Nut
What RPM ranges do you here the noise? Full throttle? How is the idle?
Old Mar 10, 2009 | 07:42 PM
Old Rotor's Avatar
Did it sound like a big coffee can with two marbles in it getting shaken hard? A hard metal on metal hammering.
Old Mar 10, 2009 | 10:45 PM
Yup, straight up premium gas for me. The people I bought it from are gonna pull the code for me whenever I can get over to them. But the big coffee can with marbles is a perfect description of what im hearing. The idle at times can be rough, but when I hear it, I'd say im hitting 3500 rpms. Thanks for all the input and possible redundancy regarding my post!
Old Mar 11, 2009 | 12:26 AM
Old Rotor's Avatar
It's very bad on the engine! I hope it's not damaged. You might have carbon build up and need a cleaning. Here is the "TSB" that shows one way to clean it. You might do the Throttle body bypass that takes a minute it has helped some.
http://www.finishlineperformance.com...4-08-1924g.pdf
Old Mar 11, 2009 | 01:29 PM
Update: I pulled the codes and got this: P0456 EVAP system leak detected (very small leak) ON 2 EVAP system. Two actual codes, but they were both the same.
Old Mar 11, 2009 | 07:28 PM
Old Rotor's Avatar
Here is the "TSB" on that code.....let us know how it goes...
http://www.finishlineperformance.com...26-07-1800.pdf
Old Apr 9, 2009 | 09:13 AM
Hey guys, sorry about the relapse. Busy as hell with school for the past weeks. I have some updates. I need a new water pump and EVAP pump. Now I would do these myself, but I am no mechanic. I don't want to take it to the dealership in town cause I do not want a stock water pump. Any ideas who makes high quality water pump application?
As for the EVAP pump, I haven't a clue about this one, I just know what it does. Now, the filler cap I think I can manage, heh heh.
Anyhow, thanks again for the help.
Old Apr 9, 2009 | 11:34 AM
For P0456, just replace your cap and see how it goes.
Why u need a new water pump ? is your old one leaking ?
mr. GrandGame
Sep 9, 2025 10:41 PM
vapor2
Nov 3, 2020 03:38 PM
Rx8Lovin
Jul 25, 2015 08:39 PM
dbarber
Jul 25, 2015 01:34 PM
LiftOff
Jul 16, 2015 08:24 PM
