May be a stupid noob question... Please help anyway
Old Feb 28, 2009 | 05:52 PM
blackbeltclub99's Avatar
Smile May be a stupid noob question... Please help anyway
I just purchased an 04 RX8 base model 6sp. Anyway the heat doesn't work. The guy I bought it from took it to the dealer last week and they said the "Logicon" needed to be replaced. What is the logicon? Where is it located and how do I change it? Does this sound like what it is? Thanks in advance for the help.
Old Feb 28, 2009 | 05:58 PM
Mazurfer's Avatar
Surf Hard, Drive Hard
There are quite a few threads on heaters not working........do an advanced search and put in "no heat" ot "heater". I believe the logicon is nothing more than the selector, so I'll go find that out because I am curious.
Yep...............it's the selector!
You can even use "logicon" in the search and it brought up several threads about heater not working. Suggest you give it a try.
Old Feb 28, 2009 | 06:20 PM
Thanks for the help. I did a search but could not come up with a definite answer. I even googled it and couldn't find out. Once again thanks for all the help. I know what to look for on ebay now.
Old Feb 28, 2009 | 06:51 PM
riveraRX8's Avatar
I wanted to ask a question. I just got my RX8 a few months ago and i wanted to lower the ride height. I was giving a set of DROPZONE Springs for free that lower the car about 2' . My car is completely stock with 18' rims. What do you guys recommend i add to the springs to make sure everything is good ? I'll take any suggestions.
Old Feb 28, 2009 | 07:23 PM
Socket7's Avatar
ಠ_ಠ
i believe the heater selection dial not working is the result of bad solder joints. Theres a DYI that shows you how to take the climate control module apart and re solder it.
Old Mar 1, 2009 | 08:52 PM
JGR4444's Avatar
GR
im sorry but wtf man? start your own thread if you cant find anything by searching but you for sure can
Old Mar 1, 2009 | 08:59 PM
Jon316G's Avatar
Grasshopper
A local guy had issues and the pot/heater **** needed soldered.
Its a thru-hole component and the solder was insufficient inside the barrels (barrels should be no less than 75% filled)
I added solder and hooked it back up. Worked perfectly afterward.
Here is the DIY:
https://www.rx8club.com/showthread.p...ghlight=heater
Audio Concepts ATL
Sep 26, 2021 01:59 PM
Learners_Permit
Sep 27, 2015 07:38 PM
NotAPreppie
12
Sep 24, 2015 03:22 PM
Randolph Alvarez
Sep 14, 2015 04:25 AM
MolecularConcept
Aug 5, 2015 04:43 PM
