Driving in Icy conditions
Old Feb 20, 2009 | 09:10 AM
jimb342's Avatar
Recently drove my wifes 2005 RX8 in a blanket of hail (Southern Orange County, California) not a normal occurance in my town. Found the vehicle very difficult to drive in the icy condition. Brakes were terrible, car slid like it was ice skating. To be honest it had,by far, the worst handling charateristics of any vehicle I have ever driven. Once on the wet surface, it was great, as usual. Anyone else comment on this. Really surprised me. Tried a search, but couldn't find info.
Old Feb 20, 2009 | 09:19 AM
CTrx8's Avatar
space for rent
if you're on stock summer tires it's no wonder you were sliding. besides being RWD (which isn't all that bad since torque isn't high in the 8), it's a lot like any other car in that weather. slow down and respect the elements. and if your'e on stocks, i blame you for trying to drive in that kind of weather.
Old Feb 20, 2009 | 09:20 AM
MyRXdrug's Avatar
Did you have the stock summer tires on?
Old Feb 20, 2009 | 09:25 AM
RIWWP's Avatar
Stock summers are horrific in ice/snow. Other summers are generally only slightly better at best.
There is a DRASTIC improvement if you have ice or snow tires, to the point that deep snow is your only real challenge, you will outperform any other car on the road, including AWD or 4WD. Almost easily.
No offroader would consider using drag slicks, and no dragster would consider using mud tires. Dry vs snow is no different. The rubber you are on is the single biggest factor in how much trouble you have.
Old Feb 20, 2009 | 09:27 AM
ken-x8's Avatar
Try searching using "winter" or "snow." That should turn up a lot of discussion.
Like CTrx8 says, it's the tires. Have you driven a car with summer performance tires on wintry stuff before? Ice is always tough, especially near freezing, even with winter tires.
Glad you survived it.
Ken
Old Feb 20, 2009 | 09:37 AM
Vyndictive's Avatar
"13B vs. Renesis" Discuss
People have sold their 8 because they didn't have the correct tire for the season - everyone above is correct. If you plan on driving this car in winter conditions, you NEED a winter tire... I'm sorry, but all seasons don't really cut it if you want to be confident driving in icy conditions.
Talk to myself, or anyone from New York, Penn. and even those crazies up in Canada who drive their 8's year round and I promise they will all say the same thing. "The 8 is great in the snow IF you have the proper tires" (or tyres) I know I can handle up to about 5 inches of snow - my only limitation is when I start to scrape the whole car because I've run out of ground clearance.
Living in Cali - I don't think you should drop the money for snow tires... just accept that it might happen once in awhile and see if you can either ride out the storm, or if you MUST drive, turn on those flashers and creep along, even then it won't be fun experience at all.
Old Feb 20, 2009 | 09:48 AM
SpIcEz's Avatar
As mentioned...
Car has nothing to do with it.
Wrong Tires for Wrong weather.
Thats it.
Beleive me. I drive in more icy conditions in 1 month then you probably have (Im assuming, might be wrong) in your whole life.
On ice, all cars are ****. Even with the best tires.
You have to be carefull no matter what.
It might FEEL ok in a big SUV... until all 4 tires break loose and you crush that little Pontiac Firefly at the red light...
Old Feb 20, 2009 | 09:51 AM
Ryoma-kun's Avatar
I've driven all winter with my 8 in this godforsaken cold country. Driving on stock summer tires in snow/ice is madness whether you have a Jeep or a Ferrari. Snow tires are a MUST if you even think of driving when it drops towards freezing temperatures. If you buy snow tires though, avoid getting too big tires... For optimal performance in snow, anything more than 215/55 is excessive. The 18" stock rims aren't ideal but I guess they'll work. Too width tires will make the tires 'swim' upon the snow instead of gripping the surface.
Old Feb 20, 2009 | 10:20 AM
Tim Tim Tim's Avatar
auto suckkssssss
the stock rim is retarded to put snow tires on. you can get rims AND tires for the same price as an 18 inch winter tire.
Vyndictive's Avatar
^ Yeah... and Norway doesn't exactly salt the roads... they just drop fine gravel all over the place, or in the mountains its just sort of accepted that the base of the road will be covered with ice
(I lived in Oslo for 1 year - I don't miss the driving conditions nor do I miss the 4 hours mere of sunlight in the winter)
However, Norway does allow studded tires, which most places in the US does not.
Old Feb 20, 2009 | 10:32 AM
dmc27's Avatar
doin' the bull dance
Guys . . . OP is in So.Cal. There's no reason for winter rubber. The hail & ice they got hit with recently is extraordinarily rare.
So yes, the tires on the 8 are not made to grip ice. But running out an buying winter tires for a SoCal 8 is pretty much out of the question. Just don't go out in that crap again - if it ever happens again, that is.
Old Feb 20, 2009 | 10:52 AM
CTrx8's Avatar
space for rent
i agree 100%. snow tires are not necessary if you don't get a lot of snow/ice.
however, as you also said, the biggest point here is that the OP needs to understand what could have been easily found by a quick search. summer tires are not meant below 40 degrees and definitely not in snow/ice. if he/she is not used to that kind of weather b/c it doesn't snow there often, they need to understand the basics - dress for the weather. you don't wear dress shoes when hiking or trying to tredge through snow. if you do, you know you take it easy and will slip. you don't put on summer tires when it's too cold or slick to drive on them. if you do, you have to know you need to take it easy in any car - not just the 8.
Old Feb 20, 2009 | 11:09 AM
dmc27's Avatar
^IDK, I like to wear high heels and a dress when I go hiking.
Old Feb 20, 2009 | 11:11 AM
Ryoma-kun's Avatar
Heh yeah but we use some salt here in Bergen though because of the milder climate. We have snowy roads quite often though and I drive over the mountains sometimes each winter too.
Believe it or not but I have studded tires on my car lulz. I've got 225-55-17 on my winter tires/rims. Previous owner bought them because he lived in Lillehammer where they've got snowy roads all winter. My advice, don't even think about getting studded tires for a sports car. I can't accelerate and shift gears on max RPM without the DSC working like crazy for many seconds everytime. And the grip sucks compared to regular snow tires. I mostly drive without the DSC on because of this or atleast tend to turn it off everytime I'm thinking about doing max throttle. Unless the roads are covered with snow 90% or more during the winter, just don't get it.
Old Feb 20, 2009 | 11:44 AM
CyberPitz's Avatar
Huge hole is huge
Don't we all...
Old Feb 20, 2009 | 11:51 AM
CTrx8's Avatar
space for rent
and that is why i keep trying to get you to go hiking
Old Feb 20, 2009 | 11:53 AM
White_Shadows's Avatar
Psh just gas it hard and call it a day haha. I was on my motorcycle that day! You've just been in cali tooooo long. Rain/Snow/Ice/dirt/sand is a aquired taste. Just watch the ...2008 seattle Formula D?? Whatever year and wherever it was that it was raining. Rhys Millen was all like wweee haaa because he does rally and baja and drifts in the rain, versus the people that never drift wet were in the walls and just having a horrible time.
Old Feb 20, 2009 | 12:53 PM
ZoomZoomH's Avatar
Mulligan User
you californians are too pampered with your year round nice weathers :P
Old Feb 20, 2009 | 12:57 PM
szym0n's Avatar
yea winter tires is deff a plus in winter...I drove last winter with summer tires and almost crashed multiple times but god was with me and saved me and this year I bought a set of winter tires and the traction/handling was ALOT! better.
Old Feb 20, 2009 | 01:00 PM
exsequor's Avatar
wipe me down
most people are just noobs when it comes to snow driving. I have 60% tread nankang ns-II's that were $65 a piece and I have no problems. Sure the vehicle wasn't meant for it..but I still get around even in a few inches of snow with no sliding. I only slide when my driver input causes me to slide..
Obviously with my tires in the condition they are right now, I have to start in 2nd and take it like a grandma when it's real snowy or icy..but honestly those occasions are pretty rare and I drive everyday.
Old Feb 20, 2009 | 01:02 PM
exsequor's Avatar
wipe me down
im from california and so is my family but i must say they are bitch drivers when it comes to snow / ice.
disclaimer: not all of them..but most
Old Feb 20, 2009 | 01:58 PM
Socket7's Avatar
ಠ_ಠ
As a native Masshole who's lived in California for 4 years now, I can say with great athority that people in California have absolutely no idea how to dive when it precipitates. They will eventually get used to driving in rain, but I'm always amazed by the number of speeding tailgaters you get the first rain of the season. I've never seen what happens when it snows, and I hope i never need to.
But yeah. Rain is one thing on summer tires. You can get away with it. Ice and snow? Just stay home unless you have some proper all weather or winter tires.
Old Feb 20, 2009 | 02:21 PM
ken-x8's Avatar
Originally Posted by szym0n
...and almost crashed multiple times but god was with me...
A man was driving along a country road one night. Suddenly another car passed him at a pretty good clip...and then ran off the road at a bend just ahead.
The man stopped at the wreck and ran over to it, just in time to see a priest crawl out and dust himself off.
"Father - are you all right?" he asked.
"Yes, I am. The Lord was riding with me."
The man looked at the mangled car, then said "You better let him ride with me. You're going to kill him driving like that!"
Ken
Old Feb 20, 2009 | 02:23 PM
Rhawb's Avatar
Has the whole shit.
You should see Florida. All summer it rains for half of the day, every single day, and every single day, as soon as the first drops of rain hit the ground the drivers lose even MORE of their minds. It's pretty incredible, you'd think they'd have figured out what's happening by now.
Old Feb 20, 2009 | 02:39 PM
Rems31's Avatar
The 8 also sucks in towing a speedboat...like everyone else has said, why wouldn't you look at the thing (or 4) that makes the biggest difference in driving on ice.
