High Pitch noise
Old Feb 11, 2009 | 01:28 PM
joshnu's Avatar
High Pitch noise
I noticed this morning when warming up the 8 a high pitch noise coming from under the hood, anyone know what this is?
It seems to go away once warmed up.
Old Feb 11, 2009 | 01:40 PM
White_Shadows's Avatar
6mt? Push in the clutch and the noise will go away. *shrugs* mine does it too. I figured it's just the clutch dragging in nuetral.
Old Feb 11, 2009 | 01:43 PM
tubingchamp's Avatar
What mawd bug?
If that doesn't work, then it could be a belt squealing.. I've had this problem for a little while.. Took it to the stealership and it came back worse 0_o
Maybe air pump? Shrug!
Old Feb 11, 2009 | 01:57 PM
If your belt sounds worse they probably tried some b.s. belt dressing.
Old Feb 11, 2009 | 02:00 PM
Potentiated's Avatar
It's the air pump on the passenger side under the hood.
Old Feb 11, 2009 | 02:03 PM
Silver06's Avatar
Zoom Zoom....
If the noise happens only on cold starts, and lasts about a minute or so, Potentiated is right on the money.
Old Feb 11, 2009 | 02:57 PM
joshnu's Avatar
Air Pump
If it is the air pump is this normal?
Old Feb 11, 2009 | 03:01 PM
Socket7's Avatar
ಠ_ಠ
It'd be a sign of the air pump failing. But I wouldn't worry too much about it unless you need to take the car in for an emissions test while the engine is cold. The air pump's only purpose is to get the cat warmed up within X period of time. I've seen several members remove it entirely.
Old Feb 11, 2009 | 03:02 PM
Silver06's Avatar
Zoom Zoom....
If it is the airpump, then some noise is normal.
The airpump is an electric motor that pumps, well, air..... Like any mechanical device, it is prone to failure. When they fail, they usually make abnormal noises beforehand.
The good news is that nothing bad will happen to your car if the airpump fails (other than probably blowing the fuse when the motor actually seizes).
If your car is under Emissions Warranty, the air pump is covered. Get the dealer to change it out.
Old Feb 11, 2009 | 03:06 PM
What does the air pump do? If it's a warm up thing does it enrichen fuel by forcing in more air? Sorry motorcycle mechanic only thing I can think of. Which would explain why pulling in the clutch would kill the noise. It slightly changes the load.
Old Feb 11, 2009 | 03:07 PM
alfy28's Avatar
yep, if its cold outside my airpump will make a loud noise for about 30sec. but since its been warm here lately in texas, no more noises
Old Feb 11, 2009 | 03:31 PM
Silver06's Avatar
Zoom Zoom....
Originally Posted by White_Shadows
What does the air pump do? If it's a warm up thing does it enrichen fuel by forcing in more air? Sorry motorcycle mechanic only thing I can think of. . It slightly changes the load.
The airpump dumps fresh air into the exhaust (at the exhaust manifold) to lean the fuel mixture. This prevents unburnt fuel from saturating the cat. converter and then destroying it (or causing a fire) when the cat starts to heat. Our cars are hella-rich to get them going on cold starts.
Our transmissions are really noisy when cold. This is more of a 'rumbling', 'rocks in a dryer' sound. We tend to get used to it. When the fluid warms, it is much less noticeable.
The easy way to figure out if you have airpump noise is to unplug the power connector to the airpump before you start cold. The airpump is attached to the passenger-side shock tower.
Old Feb 11, 2009 | 05:10 PM
So right idea just an O2 sensor style override for fuel? Because it is past the Combustion? Could they really not write the code into the startup map on the ecm? Seems counter balanced to have the ECM telling the injectors to pour in fuel and then tell them to stop because of a reading on the O2 sensor? Is there maybe more to it? Is the air being plumbed in fresh air? Therefore "technically" it's passing emissions because its fresh air and not hydrocarbons lol?
galognu
Rotary Swaps
138
Nov 16, 2020 05:20 AM
XianUnix
Sep 29, 2015 03:48 PM
tommy26Germany
Sep 29, 2015 10:33 AM
Jb4ker96
Sep 27, 2015 10:06 PM
