Clutch to the Floor
Old Feb 8, 2009 | 11:10 PM
PRLegend's Avatar
FL Clutch to the Floor
I have and 04, Blk/Blk 6sp with 100K and just recently the clutch gave up. First it was a little loose on the pedal then it went to the floor. It happen at the Florida State Fairgrounds. Hit the brakes for a person to walk across and that was it. Could not put in gear after that. Its at the Mazda Dealership getting fixed. Wish me the best.
Old Feb 8, 2009 | 11:12 PM
Jon316G's Avatar
Grasshopper
Fluid low?
Makes me think so since you mentioned brakes also (clutch and brake share the same fluid).
Old Feb 8, 2009 | 11:17 PM
Bunique's Avatar
Ground Assault
what happened to me was it was a broken clutch pedal assembly....it's happened to alot of peeps. usually around 50k miles tho. there is a thread on it some where on here. best of luck.
Old Feb 8, 2009 | 11:27 PM
JeRKy 8 Owner's Avatar
Stuck in a love triangle
How much they charging you????
Old Feb 8, 2009 | 11:29 PM
Bunique's Avatar
Ground Assault
no charge.....it was covered under warranty I think.
Old Feb 9, 2009 | 12:08 AM
Charles R. Hill's Avatar
Owner of BHR
That "loose" feel was the welds giving out on the pedal. They finally snapped on you.
Old Feb 9, 2009 | 09:43 AM
Snap!
By the way... clutch and brakes use the same fluid, same reseviour
theblinkof
Oct 4, 2023 05:24 PM
XianUnix
Sep 29, 2015 03:48 PM
tommy26Germany
Sep 29, 2015 10:33 AM
Forevermore
Sep 20, 2015 01:04 PM
