Power FC for the 8?
Old Dec 14, 2003 | 07:05 PM
pp13bnos's Avatar
Pineapple Racer
Power FC for the 8?
I was wondering if anyone knew if Apexi, will ever make a Power FC for the Rx-8? I have one in my 3rd gen Rx-7, and love the control it gives. I've checked out the apexi web page, but I could'nt find any info. Has anyone heard of any rumors in Japan about this? CJ
Old Dec 14, 2003 | 07:21 PM
Jt-Imports's Avatar
No rumors yet that I know of. Im not sure they will, but I think they are thinking about it.
They are know for getting too excited about N/A vehicles, so you know..... Since the trust turbo kit is coming out, the others will follow, so I think in DUE time it will be released.
Old Dec 15, 2003 | 10:57 AM
RX-8 friend's Avatar
I'd be very surprised if they do one. Everything on the car is controlled by the ECU and it talks to the other modules too (ABS, EPS, etc.). Very difficult to do all that. Piggyback ECUs are much easier on this car.
Old Dec 15, 2003 | 11:20 AM
Omicron's Avatar
Canzoomer was, at one time, talking about developing a multi-map setup using an Apexi (or similar) controller. I believe he was talking about doing one after he gets his stage II mod out the door (most likely sometime in Jan-Feb '04) and that his multi-map setup would include the same settings as Stage I, Stage II, and an "Economy" map.
Old Dec 16, 2003 | 04:40 AM
-=Zeqs=-'s Avatar
Hmm..maybe AEM will come out with an EMS setup...or Greddy will come out with a E-Manage piggy.
Old Dec 16, 2003 | 08:46 AM
pp13bnos's Avatar
Pineapple Racer
I talked to Rob@Pineapple Racing last night about programable fuel controlers....He should have one on the market by the end of Janurary. Target price is $1300. I'm very interested in a programable setup thats plug and play. No cutting or hacking.... CJ
Old Dec 22, 2003 | 04:37 PM
tbonerx7's Avatar
That's great that Rob's making one! Motec should have one out soon as well. Though, it might be for the StarMazda series and not for the RX-8. Besides, I'm not sure if it's compatible with existing sensors.
Old Dec 22, 2003 | 06:32 PM
Jason's Avatar
RX7store.net
Has anyone tried hooking up an Apexi Super AFC to control the fuel?
Jason
Old Dec 23, 2003 | 01:02 PM
MazdaManiac's Avatar
Jason
I contemplated the S-AFC before I bought the E-Manage.
I don't see why it wouldn't work, but for the same $350 or so you can have the much more capable E-Manage doing the same thing and more.
Old Dec 23, 2003 | 03:39 PM
-=Zeqs=-'s Avatar
No codes thrown by running the E-Manage?
I was actually contemplating getting one of those for my Civic before I picked up the AEM EMS due to more technical supporting from local dealers.
I might end up getting the E-Manage after all then...
Old Dec 23, 2003 | 03:44 PM
Runs like a charm. Instant power gains. Seriously.
Check out the two threads I have open on the thing:
https://www.rx8club.com/showthread.p...ghlight=greddy
Old Jan 10, 2004 | 05:52 AM
Jt-Imports's Avatar
PFC--I talked to Apexi today. They said no plan to even make one. Although things are changind they never jump on the car for the first year its new due to the bugs and information thats lacking..
Old Jan 11, 2004 | 10:31 PM
zerobanger's Avatar
adkdai8e dkadloi98
Thats all I want, an rx8 where its a/c doesn't work. I have a pfc on my 94 rx7 and while its great, my AC only works on position 1 due to the voltage drops. I would rather have a piggy back.
Old Jan 12, 2004 | 08:33 AM
Jt-Imports's Avatar
I never had that problem on my 7
Old Jan 12, 2004 | 08:45 AM
pp13bnos's Avatar
Pineapple Racer
Yeah, my P-fc thing is kinda a pain. But my cars AC works on 1,2 and 4. Sucks you only have one level. I'd still like to the see the P-fc for the US market though. CJ
Old Jan 12, 2004 | 08:52 AM
Jt-Imports's Avatar
PFC a pain.... Humm this is the first time in quite a long time I have heard this
*sorry about the quick thread steal*
Humm could it be your FD is 10 years old and things start to get weak and wear out over time?
Old Jan 12, 2004 | 08:55 AM
pp13bnos's Avatar
Pineapple Racer
I meant that the 3rd setting on the AC does'nt work. Other than that, I love the p-fc. BTW, Its just not something with my car, or zerobangers....its pretty much everyones who has a p-fc. CJ
Old Jan 12, 2004 | 09:35 AM
dcfc3s's Avatar
RX-7 Guru
Greddy in Japan does make "easy connect" harness adapters for some cars. Hopefully they'll do an RX-8 appliation.
Basically, it's a harness that goes between the stock ECU and the wiring harness, and the E-manage harness is tapped into that. Total plug and play, no modification of the stock harness at all.
Dale
Old Jan 12, 2004 | 10:16 AM
zerobanger's Avatar
adkdai8e dkadloi98
because the power FC was designed for the japanese market. the us rx7's all have this problem.
Old Jan 12, 2004 | 10:17 AM
zerobanger's Avatar
adkdai8e dkadloi98
its not about wearing out. I can plug my stock ecu in and the ac works on all settings. with the power FC my ac worked on all settings except 3, then after about 9 months it stopped working on all except position 1 which obviously is not enough to cool the car down.
Old Jan 12, 2004 | 06:35 PM
Jt-Imports's Avatar
Still the first I have heard about it, but thats a bummer.
My A/C is in a box in the garage anyway, since its a waste....
Old Jan 12, 2004 | 10:40 PM
zerobanger's Avatar
adkdai8e dkadloi98
search the power fc forum on rx7club.com you will find a million posts.
Old Jan 13, 2004 | 04:29 PM
Easy fix. Just search as already stated.
Old Jan 21, 2004 | 06:12 PM
zerobanger's Avatar
adkdai8e dkadloi98
there is no easy fix. the "easy fix" you refer to is to get a new engine harness which is over $1000 and doesn't always work. the other is to bypass the ECU which causes a host of problems. I tried to bypass the ECU and it still didn't work, although I have a 94 and the instructions were for a 93.
Again, i have searched and searched. its a PIA.
Old Jan 28, 2004 | 10:37 AM
j9fd3s's Avatar
Dale
we sourced out the connectors here, but the buy in is nuts ($8k)
