How do you remove the back of the nav housing?
Old Jan 27, 2009 | 04:05 PM
Kippc's Avatar
How do you remove the back of the nav housing? Do I have to remove the whole nav unit to remove the back of the navigation housing?
Old Jan 27, 2009 | 05:07 PM
hakuna matata!
If you mean the back of the hood - yes you have take apart the "hood" assembly that rotates on the motor and remove it from the gears. There is 1 small screw on each side, once you get those off then you just gently pry it off... there are just small clips holding it on.
Old Jan 27, 2009 | 07:00 PM
Kippc's Avatar
Thanks.
escapedan
RX-8 Racing
58
Feb 10, 2020 06:11 PM
rotorocks
47
May 11, 2016 03:23 PM
Ccrosskno21
Jan 9, 2016 05:43 AM
harithac
Aug 26, 2015 09:24 AM
reni04
Aug 21, 2015 01:52 PM
