Tein Basic, better or just for looks?
Old Jan 23, 2009 | 11:34 AM
whitepearl05's Avatar
CA Tein Basic, better or just for looks?
Is the tein basic coilover setup better than the stock suspension on the 8, or is it mostly for looks? Also part 2, I have never seen rota slipstreams on an rx8 before; if the offset is correct will they work with a rwd car? I have only seen them on fwd. I have an automatic with the 16's so I am thinking about keeping the 16" and just finding a better style.
Old Jan 23, 2009 | 11:58 AM
Atilla's Avatar
I am THAT guy
Tein basics have had a pretty bad review from some owners on here - best to search and develop your own opinion
For the Rota's - what are the wheel spec's you're looking for?? 19's? 18's?? and what's the width and offset??
there's a thread dedicated to rim size questions - search the 'will it fit' thread
Old Jan 23, 2009 | 12:21 PM
cjkim's Avatar
^noob
Wait... are you saying you want the rotas in 16"?
Old Jan 23, 2009 | 12:29 PM
Yes, I was looking for a lightweight 16" wheel. I don't want to hurt performance at all because my 05 is auto with the 16" wheels. I didnt even know the difference between a 4 port and 6 port motor before I started reading this board. I am trying to keep as much performance as I can out of my car.
Old Jan 23, 2009 | 12:38 PM
Atilla's Avatar
I am THAT guy
dude...upgrade your wheels...
though the stock 16's are lightweight - they lack width and the stock tires are usually all weather - atleast upgrade to 17's and get a wider set. I believe the stockies are 16x7.5 or 8 - look to upgrade to 17x9 or something - i know the FNo1r's are pretty good or enkei rpf1's - both are light weight and wider
wider sport tires = better traction
Old Jan 24, 2009 | 12:49 AM
I was thinking more like the compound the tire is made out of is better traction. For example If I were to get some falken azenis in a 225 compared to regular summer tire from lets say yokohama or sumitomo with a treadwear of lets say 200 in a 245 or 255 the falkens would grip much better. Or am I completely off base? When I had an SVT focus, I kept the 17" rims the car came with and bought some khumo tires for autox, the sidewall was much thicker and tougher and the treadwear was around 100.
Old Jan 25, 2009 | 01:54 PM
JantzenRX-8's Avatar
I have Tein Basics. It was my first mod and i didn't know anything at that point. If i were to do it again i would have gone for a different set up.
It is, however, better than stock. Less body roll, more compliant with the road, a little stiff on the ride but much more confidence inspiring on the street than stock.
Can't speak for their use on the track though.
I'd say they are a good cheap upgrade for the not so serious among us but i will be upgrading to the KW Variant 3's (or comparable) after i have some track days under my belt
Old Jan 25, 2009 | 11:07 PM
coolstorm92's Avatar
The basics are better looking than stock and possibly better performing but they ride like crap. I would not buy them again, just get s-tech instead. I would also recommed light 17x9 for looks/performance.
Old Jan 26, 2009 | 10:49 AM
How long would my stock shocks/struts/dampers last if I were to get just springs?
Old Jan 26, 2009 | 10:51 AM
Looks only..
Go with Racing Beat.
You should replace the shocks at the same time.
At least the rears........
Old Jan 26, 2009 | 10:57 AM
Atilla's Avatar
I am THAT guy
granted a better compound will give you a huge advantage over the all weather tires on the stockies - if you were to upgrade in width + compound - you would be looking at a far better gain -
i went from the same setup to 18x8.5's w/falken's and it's almost night and day on dry pavement - turns that i would slip out at became far more feasible - all of which was from personal experience.
Old Jan 26, 2009 | 10:58 AM
Atilla's Avatar
I am THAT guy
btw - variant 3's ftw!
Old Jan 26, 2009 | 11:19 AM
moete87's Avatar
Ohio State
I had the Tein Basics and thought they were good for the money. They were a little soft for my taste compared to the stock suspension. I was going to sell my car and sold the Teins but decided to keep the car and mod the **** out of it again and ended up getting the Megan Racing Coilovers..which are amazing!
Old Jan 26, 2009 | 05:40 PM
philsbluerx8's Avatar
wut???? tein basic is only for looks? i have experienced way better respound and less body roll from the suspensions. I guess it might not be enough for track use but as a daily driver, it will give you a lot fun on corners and not a harsh ride. plus a set of stiffer sway bars, it will be a very good street car.
Old Jan 26, 2009 | 06:08 PM
pdxhak's Avatar
Official Post Whore
Originally Posted by Razz1
Looks only..
RB springs for looks? Seems to me they would be ideal for someone wanting to run a slighter stiffer setup vs. lowering for looks.
R3Dream
Mar 7, 2019 09:11 AM
OnebaddRx8
Oct 17, 2015 10:05 PM
drlubell
Sep 26, 2015 11:58 PM
Tweaked Tay
Sep 25, 2015 07:54 AM
Forevermore
Sep 20, 2015 01:04 PM
