{ FS } AccessPORT JDM Version Now Available
Old Jan 22, 2009 | 01:11 PM
MazdaManiac's Avatar
The Cobb AccessPORT for the 2004 JDM models is now available.
Custom Calibrations are now available for those that have purchased their AccessPORT from another vendor.[/CENTER]
The Cobb AccessPORT allows the RX-8 PCM to be modified to accommodate for a wide variety of modifications and operating conditions, including FORCED INDUCTION.
The AccessPORT is the most user friendly reprogramming device for your vehicle's computer. The provided mapping will optimize the air/fuel ratio and ignition timing, remove the speed limiter, and more for performance results you can instantly feel!
But the AccessPORT is so much MORE than just a REFLASH DEVICE. It allows you to monitor your Fuel Economy (average and real time), perform performance tests in order to estimate your 0-60mph and 1/4 mile time, read and decipher ECU trouble codes (CELs), and monitor live data via the OEM vehicle sensors which eliminates the need for costly and cluttering aftermarket gauges!
Before installing your AccessPORT with MazdaManiac calibrations, please watch this video:
This is a small utility designed to simplify the firmware update process. All AccessPORT firmware update processes have been moved to this stand-alone utility. Users no longer need to launch the AccessPORT Manager for firmware updates.
Once installed, run the AccessPORT Updater and it will automatically check for new versions of both the updater utility and the AccessPORT firmware for their AccessPORT model.
This new updater also updates your dongle to the newest firmware, so have it connected the the AccessPORT when you install.
All MazdaManiac calibrations for the AccessPORT include the following characteristics:
  • Increased idle speed (830 RPM typical - up to 1100 for the Pettit S/C)
  • Increased OMP output in all load ranges
  • Lower cooling fan turn on points
  • Improved low-gear throttle response
  • Lean fuel targets for light throttle and cruise conditions
  • Removal/cancellation of all or any emissions-related CELs
Further customization can be realized by way of increased engine redline, altered S-DAIS operation and a variety of "novelty" calibrations such as "valet" mode, "anti-theft" mode and other such single-purpose adjustments.
List of CELs masked by the MazdaManiac calibrations for the AccessPORT:
  • P0030 Front HO2S heater control circuit problem
  • P0031 Front HO2S heater control circuit low
  • P0032 Front HO2S heater control circuit high
  • P0037 Rear HO2S heater control circuit low
  • P0038 Rear HO2S heater control circuit high
  • P0133 Front HO2S circuit slow response
  • P0138 Rear HO2S circuit high voltage
  • P0139 Rear HO2S circuit slow response
  • P0171 System too lean
  • P0172 System too rich
  • P0300 Random misfire detected
  • P0301 Front rotor misfire detected
  • P0302 Rear rotor misfire detected
  • P0410 AIR system problem
  • P0420 Catalyst system efficiency below threshold
  • P0441 EVAP system incorrect purge flow
  • P0442 EVAP system leak detected (small leak)
  • P0443 Purge solenoid valve circuit problem
  • P0446 EVAP system vent control circuit problem
  • P0455 EVAP system leak detected (large leak)
  • P0456 EVAP system leak detected (very small leak)
  • P2096 Target A/F feedback system too lean
  • P2097 Target A/F feedback system too rich
  • P2195 Front HO2S signal stuck lean
  • P2196 Front HO2S signal stuck rich
  • P2257 AIR pump relay control circuit low
  • P2258 AIR pump relay control circuit high
  • P2259 AIR solenoid valve control circuit low
  • P2260 AIR solenoid valve control circuit high
  • P2270 Rear HO2S signal stuck lean
  • P2271 Rear HO2S signal stuck rich
  • P2401 EVAP system leak detection pump control circuit low
  • P2402 EVAP system leak detection pump control circuit high
  • P2404 EVAP system leak detection pump sense circuit range/performance problem
  • P2405 EVAP system leak detection pump sense circuit low
  • P2406 EVAP system leak detection pump sense circuit high
  • P2407 EVAP system leak detection pump sense circuit intermittent/erratic problem
All prices subject to change. Does not include shipping and handling. All parts and upgrades are offered "as is". Payment must be made in full at time of order. Checks or money orders are accepted, but must clear before order is initiated. Google Checkout and money transfers are also accepted. Purchaser must pay all additional fees incurred by the transaction. ALL SALES ARE FINAL. NO RETURNS, NO REFUNDS. MazdaManiac does not offer expressed or implied warranty on any parts or kits offered and accepts no responsibility for any damages, either direct or consequential, caused by the use of these parts. For North-American models ONLY.
Orders are processed in the sequence in which they are received. Orders will typically ship within 11 business days from receipt of payment.
Shipping times vary by destination. Shipping is by UPS to all of Europe
Old Jan 22, 2009 | 06:55 PM
8-in-'08's Avatar
late '07, actually
Hi MM,
Some questions:
1. Mine is a JDM 5 speed manual. I noticed on the website it says that the AccessPort is suitable for the 4AT model. Is it suitable for 5MTs? (any plans to develop one suitable for the 5MT?)
2. I currently have done a Knightsports ECU remap done. I suppose i can still install the AccessPort?
3. Any idea whats the improvement in HP, torque over the improvement given by the ECU remap?
Cheers.
Old Jan 22, 2009 | 07:31 PM
It works with the standard-power 5mt as well.
The Knightsports ECU flash would be saved as the OE flash in the AccessPORT when you install it and can be returned to that state by uninstalling it.
For actual gains, it really depends on your current state of tune.
Presumably, the Knightsports tune is pretty good already, so you would probably see less improvement than someone that is running the OE Mazda calibration.
The biggest gains (besides drivability and durability improvements) are usually seen with turbo and supercharged RX-8s.
Old Jan 22, 2009 | 10:06 PM
aLip's Avatar
does remove the speed cut for JDM models??
Old Jan 22, 2009 | 10:15 PM
Cobb has indicated it does.
Old Jan 23, 2009 | 12:09 AM
Swerve76's Avatar
You have a PM Jeff
Old Jan 23, 2009 | 07:21 AM
csl's Avatar
csl
The biggest quaestion I have is that, knightsports only recommend OEM ignition parts on their map (came from their technician's mouth during the last remap session in Singapore), and I would like to have BHR coil on my car. If this myth solved, I would like to get a unit ASAP :D
Old Jan 23, 2009 | 03:04 PM
a_ahlan's Avatar
Anji
BHR and OEM igniton has the same dwell and therefore no adjustments are required in the ECU.
Its unlikely Knight Sports (in Japan) would recommend BHR (in US). But that does not mean BHR coils are not compatible with KS flashed ECU.
Old Jan 23, 2009 | 03:08 PM
^^ yup, you'll be fine with the BHR coils. I am assuming the reason they only recommend OEM is because some coils out there have different dwell setting then the OEM's (ie: Mazsport) so just to be on the safe side they only recommend OEM (that way they are certain the dwell settings have not been adjusted)
It's kind of like how mazda officially recommends against synthetics but after speaking with some of the Japanese engineers, I learned that they say that because not all synthetics are made the same... some are better then others but just to be safe, they say don't use them.
The point is, if you have a good solution that fits within factory parameters, you are fine.
Old Jan 25, 2009 | 07:57 AM
csl's Avatar
csl
I have the same feeling
Old Feb 4, 2009 | 08:49 PM
silvercosworth's Avatar
Hi,
Can this AP be used as a tool for tuning individual fuel and timing maps in the stock ecu, i do not want a readily developed map, i want to tune my own...with my own fuel and timing map. if these are possible, i will order one set.
Let me know.
Old Feb 4, 2009 | 08:50 PM
paulmasoner's Avatar
Asshole for hire
silver... you can use the software availible on Cobb's website(i think it still is) to make your own maps
Old Feb 4, 2009 | 10:51 PM
Yep.
Old Feb 6, 2009 | 08:35 AM
PitchBlaC's Avatar
Anyone installed it in SG? Pls review.
Old Feb 9, 2009 | 09:16 PM
fd3s777's Avatar
www.EVO-R.Net
MM is it ture that other than north america AP, all others AP applications are the same? I remeber you said Cobb made them intergrate into one version for all other none north american AP. I have PMed you about my AP. Please let me know how we can work out. Thanks!
Old Oct 10, 2010 | 07:08 PM
looking4's Avatar
Red RX8 in Philippines
Do you still have for JDM?
Old Oct 10, 2010 | 07:12 PM
Easy_E1's Avatar
Originally Posted by looking4
do you still have for jdm?
click here
Old Oct 11, 2010 | 08:41 AM
looking4's Avatar
Originally Posted by Easy_E1
CLICK HERE
Thank you. I just placed an order but it automatically charged me for international shipping even though I had US shipping address. will just email them about it. Thank you again.
Old Oct 11, 2010 | 02:16 PM
looking4's Avatar
Wow, they were quick! Gave me a refund right away for the freight difference.
Old Dec 7, 2010 | 01:13 PM
Bump
Old Dec 7, 2010 | 01:16 PM
Brettus's Avatar
Boosted Kiwi
How about Race tuner ? Is that likely to ever be available for JDM ?
Old Dec 7, 2010 | 01:21 PM
No.
Old Jan 2, 2011 | 12:36 AM
csl's Avatar
csl
MM, do you think your 3071R base map can use on a top mount setup with the same turbo model?
Old Jan 2, 2011 | 02:13 PM
My turbo base calibrations will work with any FI setup - as a base setup. You can't really drive it that way without tuning, though.
Old Jan 4, 2011 | 07:20 PM
csl's Avatar
csl
Thanks. Will it be sold as the same price as the custom calibrations you offer?
