Something is eating up my engine compartment paint
Old Jan 20, 2009 | 09:47 PM
Jon316G's Avatar
Grasshopper
Originally Posted by unvolador
I have something that sprayed up from in front of the engine that is bubling the paint on the engine and compartment parts and is causing rust to form on every surface.
If its upfront, could be the coolant.
Old Jan 20, 2009 | 10:45 PM
04RX8man's Avatar
Rotary Powered Countryboy
There is a DIY for the air filter/box removal...sounds like brake fluid to me! have you been in the shop lately or had any brake work done or done any yourself?
Old Jan 22, 2009 | 03:52 PM
TrochoidMagic's Avatar
is adjusting valve lash
double that on brake fluid.
had to repaint my engine covers due to small amount of brake fluid touching it and eating up the paint.
brake fluid is very hygroscopic and clings to water very well... so simple hose off with water can remove any potentially harming brake fluid left on surface.
do it now!
Old Jan 22, 2009 | 07:25 PM
13bturbofc's Avatar
400whp RX-7+05 RX-8=BROKE
brake/clutch fluid is the only fluid under the engine compartment that will eat paint.
Old Jan 22, 2009 | 07:35 PM
04RX8man's Avatar
^yes...
Old Jan 22, 2009 | 10:33 PM
13bturbofc's Avatar
And you should make it a priority to fix the cause of the problem and get it repainted ASAP because it will continue to rust until you'll have big problems on your hands trust me. ive worked in a body shop all my life. rust is my worst enemy lol
Old Jan 23, 2009 | 01:45 AM
Silver06's Avatar
Zoom Zoom....
A contrarian thought....
I just noticed this thread.
For the Original Poster, did you figure this out?
If so, ignore what follows. If not......
I'd bet a dozen Root Beer that it is your battery offgassing that is causing the mystery paint removal / quick rusting.
If it is, your battery should be just about out of electrolyte (or you have had to change it in the last little while).
Just a thought.
& Curious for a reply.
Old Jan 23, 2009 | 06:25 AM
Go48's Avatar
Pictures of the damage might help locate the source of the problem fluid/gas. Good theory Silver06. Could even be a leak in the battery. OP should remove the battery cover and check it out right away.
Old Jan 23, 2009 | 07:11 AM
13bturbofc's Avatar
Just a thought.
that's a very good theory, however im pretty sure our batteries are maintenance free. so unless the case on his is cracked, or he doesn't have the maintenance free battery, then it cant be the battery.
Old Jan 23, 2009 | 07:58 AM
DOMINION's Avatar
I don't buy Kool-Aid
Maybe he took it to be serviced and someone sprayed something like to clean a part under his hood and now that is whats eating his paint. Or maybe he did it lol IDK...
Old Jan 23, 2009 | 11:13 AM
04RX8man's Avatar
ah yes Silver06 might have a point there!~
Old Jan 23, 2009 | 11:30 PM
Pictures please
Old Jan 24, 2009 | 09:13 AM
Renesis07's Avatar
Vtak just kicked in yo!!
A RESPONSE PLEASE lol.
Old Jan 24, 2009 | 01:07 PM
13bturbofc's Avatar
haha screw this thread this guy isnt coming back...thanks for wasting our time..
Old Jan 24, 2009 | 01:16 PM
Socket7's Avatar
ಠ_ಠ
Sealed lead acid batteries can outgas. I'm sure that the 8's battery could outgas as well; but i'd be very surprised if it could start the car after melting down to the point where it would do that.
I'm voting it's brake fluid.
Old Jan 25, 2009 | 09:05 AM
Go48's Avatar
You could have an overcharging problem. Have it checked. Filling the cells to where you did should not cause acid to blow out.
Old Jan 25, 2009 | 02:11 PM
13bturbofc's Avatar
why dont you get a sealed battery? im pretty sure thats what they come with from the factory...
Old Jan 25, 2009 | 06:23 PM
04RX8man's Avatar
All Hail To The Great Almighty Silver06
Old Jan 25, 2009 | 06:26 PM
StealthTL's Avatar
......don't forget the dozen root beer!
S
Old Jan 25, 2009 | 06:32 PM
DOMINION's Avatar
Yea sounds like hes been down that road before lol
Old Jan 25, 2009 | 06:44 PM
04RX8man's Avatar
yeah "root" BEER!!!!
aka coors light?
Jesus Martinez
44
May 6, 2025 08:09 AM
ouimetnick
25
Sep 14, 2023 01:44 PM
vapor2
Nov 3, 2020 03:38 PM
akagc
Aug 11, 2015 07:07 PM
