How long do the OEM Spark Plug Wires Last?
Old Jan 16, 2009 | 05:24 PM
Kippc's Avatar
How long do the OEM Spark Plug Wires Last? Would I create more damage to the car if I just replace the spark plugs and the ignition coil? I am trying to rid myself of the CEL being on. I have a P0300 code and I believe the ignition coils are the culprit. I have the spark plug wires on order but they are not here yet. I just want that light to go off.
Old Jan 16, 2009 | 05:27 PM
Mazurfer's Avatar
Surf Hard, Drive Hard
Tough call on how long. Too many variables.
Use your old wires until the new ones come in. You'll be fine.
what year is your car? Miles? Original owner? Are you using OEM spark plugs? How old are the coils / plugs?
I'm pretty sure those wires will last quite a while unless they're damaged. Would be a shame to swap out coils / plugs and then have to work in that same area again when your wires show up. Easier to just kill 2 birds with one stone but you won't cause any damage. (as long as they wires are in working condition with no physical damage / defect to them)
Just make sure you properly secure the wires to the plugs
Old Jan 16, 2009 | 05:29 PM
Mazurfer's Avatar
I was trying to be brief!
Old Jan 16, 2009 | 05:30 PM
haha!! It's alright my friend, between our two posts I'm sure we covered it.
Old Jan 16, 2009 | 05:31 PM
laythor's Avatar
I zoom therefore I am.
:cough:
make sure the wires are on snug when you replace the plugs
:cough:
Old Jan 16, 2009 | 05:32 PM
^^ yeah, that too
Old Jan 16, 2009 | 05:33 PM
Mazurfer's Avatar
I thought about mentioning that one!
Old Jan 16, 2009 | 05:34 PM
and don't forget the anti-seize when you put the new ones in.
Old Jan 16, 2009 | 05:41 PM
04RX8man's Avatar
Rotary Powered Countryboy
^and that one!!!! haha....these guys have said it all I see my help is not needed anymore!
Old Jan 16, 2009 | 06:03 PM
Mazurfer's Avatar
Damn it Jorge!
Old Jan 16, 2009 | 06:22 PM
Kippc's Avatar
Thanks for the speedy reply folks. Much appreciated. I will swap em out first thing in the morning.
Old Jan 16, 2009 | 06:53 PM
04RX8man's Avatar
haha JEDI always beats us to it lol
Old Jan 17, 2009 | 12:33 AM
until they fail..
it could be 10k miles. could be 198k miles.
Old Jan 17, 2009 | 08:43 AM
Charles R. Hill's Avatar
Owner of BHR
I heard there is a set of performance wires for the RX-8 available somewhere for $60, shipped.
Old Jan 17, 2009 | 09:30 AM
04RX8man's Avatar
^yes I believe the same thing!
Old Jan 17, 2009 | 10:45 PM
Nubo's Avatar
Lubricious
In my '90 Miata I could tell when the plug wires needed replacement by the interference it would create with weak AM radio stations. Seriously. Replaced them 2 or three times based on that and each time the engine would be smoother and the radio noise would be gone. Always stuck with the OEM wires. Don't know if that trick will work on the RX-8.
Old Jan 18, 2009 | 01:07 AM
one could find those where???
Old Jan 18, 2009 | 02:00 AM
^^^ currently installed on my car as of a few hours ago.
Too bad they'll only be on for a week.
Old Jan 18, 2009 | 02:14 AM
i hear they are hot and zesty!!!
Old Jan 18, 2009 | 09:36 AM
Yes sir swoppe is correct again.
normally I would consider looking at them at 50 or 80k miles.
Old Jan 18, 2009 | 12:44 PM
slidey's Avatar
As far as i'm concerned the stock leads are crap, i've always had a crackle on LW radio, not that i use it, i just noticed one day when i was board, i just put it down to poor surpression, then my next door neighbour complained about her telly going daft every time i had the car running on the drive, it remineded me of the old jap bikes with metal plug caps from the 70's-80's, so i invested in some magnacor kv85 leads and the prolem is gone , on closer inspection of the old leads, they'd started to crack up and go hard, you could see signs of water ingress, the rubber moulding on the plug caps is very poor, i can see why they get replaced so often.
I'd fit better leads just for reliability, the standard ones just are'nt upto the job, and are built down to a very cheap price.
my £'s worth
dave
ironj221
36
Jan 20, 2026 08:28 PM
05TR1CH
Apr 18, 2023 04:56 AM
uZu
Dec 30, 2015 12:35 PM
Zank300
Aug 26, 2015 07:40 PM
ne0tas
Jul 26, 2015 04:27 PM
