Lowering Springs Question
Old Dec 10, 2003 | 03:38 PM
Koala Joe's Avatar
Pink Slip?
Does anyone know if I just install a set of lowering springs instead of putting in coilovers, does it decrease the handling characteristics or wouldn't make a difference? Coilovers are a bit pricey for me at this point.
Please help, thanks in advance.
Old Dec 10, 2003 | 03:58 PM
mikeb's Avatar
100% Italian
I just know coilovers can be adjusted and springs cant
Old Dec 10, 2003 | 04:09 PM
donald121's Avatar
Correct me if I'm wrong. Just replacing springs will hurt the shocks in long run. The coilover is the whole set of springs + shocks and is adjustable.
syntrix's Avatar
I like cheese!
Initially, it should help.
I'll bet, just like on most cars, that if you go higher spring rate, the stock dampners (shocks) won't hold up for very long.
When they start to go, you'll be bouncing down the freeway. When that happens, obviously your performance will decrease.
I always recommend springs with a matched set of shocks... however, I think the only option right now is the MS shocks. I'm sure other options will come out in the future though.
YMMV, and the stock shocks could last for a long time..... that just an unknown right now as the car is so new
Old Dec 10, 2003 | 05:51 PM
Koala Joe's Avatar
Pink Slip?
Thanks Guys
Old Dec 10, 2003 | 08:18 PM
sup3rbad's Avatar
Numbah 1 in da hood... G
quote from Eibach:
"Eibach Pro-Kits are designed to work with original equipment shocks and struts provided they are in good working condition."
Old Dec 11, 2003 | 02:44 PM
donald121's Avatar
Originally posted by sup3rbad
quote from Eibach:
yes, that's what the box said, but in my personal experiences, just but changing the springs will damage the original shocks in long term. It will probably last around 2-3 yrs.
Old Dec 11, 2003 | 04:58 PM
VividRacing.com's Avatar
The reason stock shocks and struts wear out quicker is due to the restricted stroke of the shock shaft. With lowering springs the shock is compressed more than stock, and stays like that. It xtra stress on the bushings. All in all, I've had springs on other cars and the shocks will be fine depending upon how hard you drive the car.
gwailo
May 14, 2024 06:57 AM
WingleBeast
22
May 23, 2016 09:22 PM
TJSiegrist
Sep 10, 2015 09:29 AM
LMURailsplitter02
Sep 6, 2015 10:56 PM
Jazzmeson
Jul 31, 2015 01:47 AM
