Go Back   RX8Club.com > Series I Tech & Performance > Major Horsepower Upgrades
Old 12-29-2008, 06:54 PM   #1
alz0rz
i had an rx8 relapse.
Trader Score: (24)
Send a message via AIM to alz0rz
Exclamation Al's Nitrous Install Thread!
There is a serious lack of nitrous build threads in this forum.. it's being dominated by the turbo people and their builds. I shall document my nitrous build as I go.
Why Nitrous? You have a nice boost whenever you need it at 1/6 the price tag of a snail/blower. Plus it's simple and clean.
My build will involve the following:
Zex #82021 Wet Kit - $500 (Charles R. Hill / BHR / eBay)
Zex #82006 Bottle Heater (w/ thermostat) - $130 (Charles R. Hill / BHR)
Zex #82005 Nitrous Pressure Gauge - $30 (eBay)
BHR Throttle Body Spacer - $100 (Charles R. Hill / BHR)
I'm going for a clean and simple install. Since I started off with a smaller budget I opted for the bare essentials in accessories. I know I will eventually be getting a remote bottle opener but I can live without it for the time being. As for needing a purge kit, I just have to remember to do a quick blast before I park the car for the evening or before I race (sanctioned, of course). I did however go with the bottle heater with the automatic thermostat. This bottle heater automatically turns itself on and off so the bottle will be at a optimal psi/temp. I don't think I'll even have that crappy inline nitrous pressure gauge on the tank in the end. As I expand on the build I may interface a sending unit to my carpc and display my nitrous pressure through my gauge software, but that will be later on. Lastly, due to my goal of a clean and reversible install I had to get the throttle body spacer offered by BHR.
So I read through pretty much ALL the threads on these forums regarding nitrous use in the RX8. I don't think I have to mention it but I would not have even thought once about using nitrous if it hadn't been for Charles R. Hill and his support through his threads and advice. There is a lot of misinformation in some of these threads so if you're thinking of doing your own nitrous install make sure you are clear on everything.
I am using the ZEX #82021 kit as has been proven to be quite effective on our engine. I will be sticking with the 55-shot (36 n20/17 fuel jets) for the time being. As progress is made in finding a way to change timings only when spraying I will move onto higher shots. I figure a 50 hp boost will be enjoyable for the time being.
What I've done...
I did the cabin electrical stuff today. I'm using a small discreet 12v rocker led switch for arming the system. I have mounted it inside my ashtray right below the cigarette lighter.
I am using the aux power wire from the fusebox for power (switched) and grounded the switch by the passenger footrest area.
I ran the wire into the cabin from the engine bay through a small hole by the windshield wiper fluid reservoir.
I also received this work of art today...
Test fitting the nitrous nozzle in the spacer... this spacer is a MUST!!!
I didn't get a chance to run the nitrous line under the car today since I didn't have much time to work on it. Mind you I live in an apartment complex and I'm working in the parking lot!
Anyway, so I did get to tap the throttle body harness for the TPS signal.
Getting it off was easy but I there is no room to work here!
Ah.. better!
Tapped!
tokico d-specs, tein s-tech springs, progress tech sway bars, evo-r endlinks, cobb ap
racing beat rev8 exhaust, racing beat intake/duct, racing beat dual resonated midpipe, yukon coil conversion
my carpc install - nitrous install - glowshift digital gauges install
alz0rz is online now   Reply With Quote
Old 12-29-2008, 06:55 PM   #2
alz0rz
Trader Score: (24)
I mounted the ZEX module as well. This position and spot was recommended by Charles.. though it will definitely be a tight for the inlet hoses...
Test fitting the intake.. and it clears the tray perfectly! Like I said.. it will be interesting when the hoses are run!
I quickly wired up the ZEX module temporarily..
Switch On!
Let's go check the hood! Ah... Yes! Green light.
I spent the rest of the day replacing a local guys coils/wires/plugs and then I went to 4 auto parts stores looking for a replacement fuel line to use for the nitrous tap. They only carry SAE 30r7 rated hoses which are rated for 50 psi of working psi.. we want more! I read up online and it looks like I will be getting a SAE 30r9 rated hose which has a working pressure of 125psi! More than enough.
So third day working on it... I did alot. Did all the work I had too under the hood.. all that left is to drill in the trunk for the bottle bracket and nitrous feed line and then fill the bottle!
With my UIM off... so much foam in there! I took the UIM off to make it easier to remove in the stock fuel line.
UIM off...
Sealing the tee fitting with some gasket stuff..
2 clamps are better than 1!
My engine bay in bits!
Me head first where my UIM used to be.. was getting those clamps on the fuel line nice and tight..
UIM back on.. with the BHR spacer...
Hot.
The fuel and nitrous inlet hoses on the bottom of the intake tray.. see how tight of a turn they had to make..!
Everything put back together.. check how tight the accordion tube is.. oyy what a pain that was to get back in.
Old 12-29-2008, 06:56 PM   #3
alz0rz
Trader Score: (24)
Overview of what was done today...
All I have left to do is drill and fill!.. Oh yeah and clean it up a bit.. my engine bay is dirty! Damn salt.
--- Today I drilled and filled and sprayed!! Initial reactions are on my post on page 3.. not quite what I was hoping for.. but it is there!!!
Drilling into the trunk.. pretty easy.
Mounted and hooked up (at this point the bottle was filled)
Everything tidy and zipped.
Final trunk view:
Old 12-29-2008, 06:56 PM   #4
Easy_E1
4 engines/3 manifolds
Easy_E1's Avatar
Looking good!
Easy_E1 is offline   Reply With Quote
Old 12-29-2008, 07:11 PM   #5
trustbuddy
trustbuddy's Avatar
Send a message via AIM to trustbuddy
oh, i am so subscribed to this thread!@@!!!
i may be looking into squeezing the 8 as well in the near future.
keep up the good work~
Originally Posted by Captain Amazing
^ Someone once asked me if I knew anything about cars because I said my car is a rotary and has no cylinders.
Originally Posted by topgear8
^Well as long as you don't think Veilside looks good, then I respect your opinion.
From Honda to Mazda...yet same 9000 RPM.
I love Horse Thief Mile @ Willow Springs
trustbuddy is offline   Reply With Quote
Old 12-29-2008, 09:05 PM   #6
learycd
Hold DSC for 7 Sec
learycd's Avatar
awesome, gotta love the laughing gas
keep us updated
2005 White Water Pearl GT - 6MT - w/ Toys
learycd is offline   Reply With Quote
Old 12-29-2008, 09:18 PM   #7
chrism
Misfit Moderator TnC
chrism's Avatar
Send a message via AIM to chrism
been there done that but d00d im jealous...i didnt get the damn stickers!!.....soooo jealous!
the story of why the beast must go
http://www.rx8club.com/showthread.ph...14#post2517714
from then till now
http://www.rx8club.com/showpost.php?...39&postcount=1
08 Stormy Blue MX-5 GT PRHT the new hotness
chrism is offline   Reply With Quote
Old 12-29-2008, 09:20 PM   #8
gregs
Pull My Finger
gregs's Avatar
looks like a good list, i look foward to seeing alternates to more power!
07 Rx8// Greddy/BNR Turbo Kit// HKS SSQ BOV// Greddy Oil Pan// Greddy Oil Filter Adapter// Greddy Profec Spec B//Cobb AP//19x9.5 SSR Professor Rims Front & Rear// Mazsport DR MidPipe// Mazsport CAI// Greddy Evo TT//AEM Meth Inj.// RP Short Shifter// VooDoo Shift Knob// Apex-i n1 CoilOvers// CorkSport 3Pt StrutBar// Ingalls Engine Damper//Pro Sport Gauges// RB Gauge Pod RaceRootsRipped Me Off!
gregs is offline   Reply With Quote
Old 12-29-2008, 09:41 PM   #9
YaXMaNGTO
It's a Cavalier
YaXMaNGTO's Avatar
Keep going man!!! Great start to your project.
Do me a favor... when you're done, please take it to the drag strip just once to figure out what it traps. PLEASE!!!! I really want to know...
2005 Pontiac GTO Torrid Red / Red / M6 / 18" (1 of 71)
Nitrous Outlet 100 shot halo dry kit, xpipe, muff delete, K&N
441 whp / 434 lb-ft
GBNF: 2004 RX-8 GT 6MT Brilliant Black / Red
YaXMaNGTO is offline   Reply With Quote
Old 12-29-2008, 10:25 PM   #10
Charles R. Hill
RX8Club.com Sponsor
Charles R. Hill's Avatar
Trader Score: (7)
You guys keep buying enough stuff from BHR I will be able to afford to fill my tank and see what an RX-8 with porting, nitrous, MM-tuned AccessPort, and a handful of other mods will trap. I am guessing around 108 mph.
Yes, my car hauls ASS and pulls hard from 3,500-9,500. It doesn't stop even at 125 mph. Ask MM, Flashwing, tdiddy, and I can't remember who else.
This forum has been around so long that if you hafta ask, you haven't searched enough.
Charles R. Hill is offline   Reply With Quote
Old 12-29-2008, 10:56 PM   #11
rx82hate
Rehabed RX8,TheComeBack!!
rx82hate's Avatar
Trader Score: (6)
Oh, can't wait.... Finalizing n20 install too. Ray getting me a few more parts......
Stealth install part 2.....
I pay rent and BHR monthly, the rest of the bills can wait
Oh yeah, and that MM guy is building me a turbo...
Will post pics of n2o soon...
Rebuilding piece by piece........
Respect to the 3 Amigos.....
FI in 201??? !!!! Thunderhill here I come....
rx82hate is offline   Reply With Quote
Old 12-29-2008, 11:23 PM   #12
toneskii707
suck my smog
toneskii707's Avatar
Your setup is lookin good, ya BHR TB spacer cleans it up very nice. Ay I never got stickers either maybe ill get sum when I order the stealth nozzels
2004 Ti Grey 6sp MT, K&N V2, RB air duct, Agency power full exhaust, clear coners, mazdatrix 10mm spark pulg wires, BHR TB spacer, BHR stealth nozzel, 65 shot zex wet kit, zex nitrous pressure gauge, and lotek gauge pod(still need to buy gauges)
toneskii707 is offline   Reply With Quote
Old 12-29-2008, 11:41 PM   #13
HockeyRX-8
TNC
HockeyRX-8's Avatar
Send a message via AIM to HockeyRX-8
Looking good Al. I want a BHR sticker!!!!
HockeyRX-8 is online now   Reply With Quote
Old 12-30-2008, 02:14 AM   #14
kersh4w
Hit & Run Magnet
kersh4w's Avatar
stops at 125?
do you have an AT?
why would an rx8 stop at 125? mine soars past 125.. 135.. at 145 it starts to creep. all on private roads/tracks.. of course.
please post video of you trapping 108! i would LOVE to see that. :D
Speed is money. How fast can you afford to go? - TeamRX8
need a better shift feel, pedal going squeaky on you, want faster shifts? Race Roots clutch brackets.
rx8 service manual
Originally Posted by mysql101 View Post
how strong of a transmission do you need with 120 torque?!
kersh4w is offline   Reply With Quote
Old 12-30-2008, 10:19 AM   #15
Charles R. Hill
RX8Club.com Sponsor
Trader Score: (7)
125 is about as fast as I have taken it in the past year or so. I said it pulls HARD and doesn't stop.
You'll see video as soon as I have a chance to get to the track with decent weather.
Old 12-30-2008, 10:39 AM   #16
9krpmrx8
SARX
Trader Score: (8)
Send a message via MSN to 9krpmrx8 Send a message via Yahoo to 9krpmrx8 Send a message via Skype™ to 9krpmrx8
I so need that spacer for my reinstall. That is awesome.
9krpmrx8 is online now   Reply With Quote
Old 12-30-2008, 10:52 AM   #17
Charles R. Hill
RX8Club.com Sponsor
Trader Score: (7)
I have a rather large stack, with all the hardware, awaiting shipment to those who want them.
Old 12-30-2008, 08:29 PM   #18
alz0rz
Trader Score: (24)
Yes, the spacer rocks! I will definitely be recommending it to anyone even considering a nitrous install.
I updated the bottom half of the first post and second post with new pics!
I mounted the ZEX module today and tapped the TPS signal. I also tested the arming switch with the module all hooked up, perfect!
Left to do:
- Fuel line tap.. i'm completely replacing the stock fuel line.,, need a SAE 30r9 rated fuel hose.. none of the auto parts stores near me have one!
- Run the nitrous line from the trunk.
- Mount the nitrous bottle in the trunk.
- Install BHR spacer.. I'll do this when I have the UIM off to remove and replace the fuel line.
After that it's just permanently wiring everything up and filling the bottle!!
Old 12-30-2008, 10:01 PM   #19
Swerve76
Swerve76's Avatar
Not meaning to sound like a fanboi but the build quality of the BHR nozzle and spacer are spot on!!
Just curious Ray....what size nozzle do you do up to?
'05 6MT in Top Secret Gold // Greddy TC @ 1.5 bar // Microtech LT10S // HKS EVC // Defi VSDX // Defi Gauges // Custom Straight Thru Exhaust // Custom Manifold // Cusco F&R Strut Bars // Autoexe 8-Point Underbrace // Cusco Zero2E Coilovers // Whiteline F&R Swaybars // Volks Racing GT7 // RE Amemiya Batt Relocation // RE Amemiya II CF kit // RP Short Shifter // 72mm Custom Oversized Throttle Body // Upgraded 3mm Seals // ZEX Nitrous with BHR Custom Spacer & Nozzle // www.fujimotorsports.com.sg //
Swerve76 is offline   Reply With Quote
Old 12-30-2008, 10:04 PM   #20
chrism
chrism's Avatar
al if you need a shop holler...i got some sources near the tuesday night spot
from then till now
Old 12-30-2008, 10:09 PM   #21
alz0rz
Trader Score: (24)
i'm going to attempt to do it all myself.. the only thing that scared me away originally was the fuel line tap but I've grown comfortable now knowing exactly what to do..
edit: actually on second thought i may take it to a shop and give them 20 bux to mount the bottle for me.. drilling through the trunk will suck.. and i'm not sure how I'm mounting the bottle yet.. either your way (chrism) or the standard mount in the corner of the trunk to the left..
i still don't know where i am going to fill up the bottle though!... i did find these though but i don't know how outdated they are..
MARIOS AUTO PARTS 309 PACIFIC AVE
JERSEY CITY , NJ 07304
DISTANCE: approx. 8.6 miles
PHONE: (201) 435-3477
EASTCOAST AUTOSPORT INC 434 HARRISON AVE
HARRISON, NJ 07029
DISTANCE: approx. 12.2 miles
PHONE: (973) 485-6900
EMAIL: info@eastcoastautosport.com
SPENCER'S SPEED SHOP 31-35 JORALOMON STREET
BELLEVILLE, NJ 07109
DISTANCE: approx. 12.6 miles
PHONE: (973) 450-5880
EMAIL: spencerspeed@comcast.net
WEB: http://www.spencerspeed.com
B & R PERFORMANCE 121 EAST JERICHO TPK
MINEOLA, NY 11501
DISTANCE: approx. 15 miles
PHONE: (516) 248-7380
TURBO PEOPLE OF NEW YORK 282 FARRAGUT AVE
HASTINGS ON HUDSON, NY 10706
DISTANCE: approx. 15.4 miles
PHONE: (914) 478-1727
S-K SPEED AUTO STORE 273 SUNRISE HWY
ROCKVILLE CENTRE, NY 11570
DISTANCE: approx. 16.6 miles
PHONE: (516) 766-2225
EMAIL: andrewl@skspeed.com
WEB: http://www.skspeed.com
SPEEDWORLD 598 SUNRISE HWY
BALDWIN , NY 11510
DISTANCE: approx. 18.2 miles
PHONE: (516) 771-2525
EMAIL: mspeed598@yahoo.com
Old 12-30-2008, 10:28 PM   #22
chrism
chrism's Avatar
thats where i went
been there too but they are $$$
from then till now
Old 12-30-2008, 10:37 PM   #23
alz0rz
Trader Score: (24)
thats where i went
what did you pay at Spencers per lb?
Old 12-30-2008, 10:45 PM   #24
heyarnold69
Rotary wanabee
heyarnold69's Avatar
Send a message via AIM to heyarnold69
great pics... I was wondering where you would mount everything.
AEM CAI, AP Dual Res mid pipe,Greddy SP2 Exhaust,Cobb Access Port,Mazda Speed Rear w/ LSD,AFE Shifter,Billet Rotor Shaped Engine Dress-up-Kit,19" Black Rims, 10" Kicker comp, Flex Innovations Grounds, more...
Decarb Lovin!
http://www.youtube.com/watch?v=09rDT9fkqRQ
heyarnold69 is offline   Reply With Quote
Old 12-30-2008, 10:47 PM   #25
alz0rz
Trader Score: (24)
that intake box is the one you sold me longgg ago!! remember we met up at like 1am at some random gas station on LI? :P
i too was concerned about mounting but Charles cleared everything up.. the only thing I have to plan now is the bottle mounting.
2006, boost, electric, gauge, gto, install, installing, mazdaspeed, nos, prosport, rx8, support, technical, tps, zex
new nitrous thread?? lol Rotard Aftermarket Performance Modifications 1 12-11-2008 06:26 PM
2 CEL's after Nitrous Install 0_o Flash Trouble Shooting 2 06-21-2008 05:31 AM
Nitrous install help? LiL BenNy Major Horsepower Upgrades 1 01-14-2007 01:47 PM
