Bent Rim
Old Dec 10, 2003 | 11:39 AM
fe-silver-rx8er's Avatar
Bent Rim
Hey guys, I was having a little too much fun in the snow this weekend and the left side of my car ended up hitting a curb. Now I'm stuck with a bent rim and god knows what. Just a question to you all... would the bent rim cause the car to pull in whatever direction it is on? I'm trying to figure what could be the problem, because I need to compensate by steering about 40 degrees to the right side to go straight. And does anyone know a good place to order OEM toyota wheels for cheap?
Old Dec 10, 2003 | 12:13 PM
eccles's Avatar
Prodigal Wankler
No, a bent rim might cause vibration, but will not cause a constant pull in one direction. Sounds like you've knocked that corner out of alignment. To be that far out, you may have actually bent a suspension component or two. Get it checked and repaired or adjusted before you put egregious amounts of uneven wear on your tires.
Old Dec 10, 2003 | 12:30 PM
Smoker's Avatar
RX-8: Hmmmmmmmmmmmmm.....
Got that fixed ASAP. Otherwise, your tires will too be ruined.
Rx8 VA Guy
Jun 4, 2016 12:42 AM
Brokegang
Jan 3, 2016 12:45 PM
Trancemission
RX-8 Multimedia/Photo Gallery
46
Dec 2, 2015 07:26 PM
yankeepicker
Sep 11, 2015 05:42 PM
Series I Do It Yourself Forum
Sep 6, 2015 01:04 PM
