WTB greddy oil drain plug
Old Dec 26, 2008 | 02:16 AM
czar's Avatar
Almost boosted
wanted to buy the plug for the oil drain line from turbo, annoying little peice i am trying to find instead of buying a oil pan with a adapter included.
refering to fitting that plugs into the oil plug for the oil drain from the turbo to clamp on to
Old Dec 26, 2008 | 06:11 AM
mysql's Avatar
Doppelgänger
it's the same exact drain plug that you used on the OEM oil pan. Buy an oem one or anything aftermarket.
Old Dec 26, 2008 | 08:14 AM
nuke0907's Avatar
Never Blend In
are you talking about a fitting to screw in to attach the hose?
Old Dec 27, 2008 | 01:42 AM
czar's Avatar
Almost boosted
yea the one you clamp the hose on to, sorry ^_^
Old Dec 27, 2008 | 10:40 AM
nuke0907's Avatar
Never Blend In
they have one on ATP, but i'm not sure if its the right size. you might also want to check an autoparts store for something. try looking for heater hose connectors. here's a pic of mine that came with my Greddy kit. if you notice, the threaded part is somewhat narrower than the nipple part.
By nuke0907, shot with NIKON D40X at 2008-12-27
Old Dec 27, 2008 | 12:37 PM
NgoRX8's Avatar
it's tough to find. i ended up ordering a set of fittings from ray to hook up and combine.
the oil drain is a M14x1.5 and in this case to a 5/8" barb
Old Dec 27, 2008 | 03:34 PM
czar's Avatar
Almost boosted
awsome, exactly the info i needed,
i can use the barb above with the
http://www.atpturbo.com/Merchant2/me..._Code=ATP-OIL2
weld in bung for the oil pan, i may have to go this way if i cant find it.
lol all these little things ~_~ for a turbo
drebbrnator
Dec 27, 2018 07:02 PM
uZu
Dec 30, 2015 12:35 PM
Sifu
Aug 30, 2015 10:51 PM
reni04
Aug 21, 2015 01:33 PM
Obivious
Jul 29, 2015 05:57 PM
