Lack of heat on driver's side
Old Dec 20, 2008 | 10:28 PM
Rogueain's Avatar
Cool Lack of heat on driver's side
Just like to let everyone know, I finally got my RX8. Winning Blue, gorgeous car. Woot.
Problem is lack of heat. It's cold outside...
I already ripped the dash apart, soldered the heater chip, now it passes the diagnostic.
Problem is, it's gotten only a little warmer, and only on the passenger side. Driver's side still blowing freezing cold air in my face.
Wtf do I do?
Old Dec 20, 2008 | 11:08 PM
mazdaverx7's Avatar
RX-Heaven
passenger side and defrost blowing warm air?
Old Dec 20, 2008 | 11:42 PM
Rogueain's Avatar
Yes. Both warm on passenger. Cold on driver.
Edit: Same goes for floors too.
Old Dec 21, 2008 | 12:18 PM
Rogueain's Avatar
Anyone?
I'm doubting it's the antifreeze, i added to it, with no luck.
Maybe it's a fuse? I checked the fuses I thought might be related under the hood, they're all good.
Maybe it's one near the driver's side floor?
Should I attempt to change the thermostat?
(Bought the car in Arizona, where the previous owner most likely NEVER used the heat since it's the desert)
Old Dec 21, 2008 | 12:53 PM
DeViLbOi's Avatar
The devil made me do it
None of your issues would issolate cold air to the drivers side and warm air to the passenger. It isn't even like the 8 has dual climate controls to get hung up. You have one heat pump that services both sides.
Old Dec 21, 2008 | 01:00 PM
Rogueain's Avatar
Do you think the heat pump is bad? The engine temp is where it's supposed to be, just slightly below half. Oil pressure is 2 notches above half. I'm really considering replacing the thermostat.
Old Dec 21, 2008 | 01:05 PM
There is an actuator valve on the left side that directs air to the drivers side...it might not be working. That is the most likely thing if you have heat on the other side
If you have a shop manual I think it has a picture and diagnostics for this valve
Old Dec 21, 2008 | 01:38 PM
Rogueain's Avatar
Thanks a lot, I'll get right on it. Just thought I'd ask though, a lot of people on here say the heat is Really hot. When I say the passenger gets hot, i really only mean warm at best.
It's noticeably warmer than the passenger, but it's not scorching hot or anything. Lukewarm, and this is with the heat on full blast, engine's been idling for about 10 minutes.
Old Dec 21, 2008 | 01:42 PM
Takes a while to heat up...10 minutes with the temp it is today...will take a bit longer than that.....
Old Dec 21, 2008 | 02:42 PM
DeViLbOi's Avatar
No...if the pump was bad you would have no heat at all. Dannobre has an idea there...however dannobre wouldn't the airflow be restricted to the drivers side as well? And as for the heat...yes...you could probably melt an ice cube quickly when the thermostat opens and you get full on heat.
Old Dec 21, 2008 | 02:48 PM
Rogueain's Avatar
Well, I will admit that the thermostat is probably OK. When I was driving it home, stuck in traffic, the heater kicked on finally, and it was pretty hot. Had to open the windows to vent a little. But, that's the only time It's worked properly, and I was stuck on I5 while everyone put on chains for a couple hours.
Very little movement.
Old Dec 21, 2008 | 03:09 PM
DeViLbOi's Avatar
Did you have heat on the drivers side while you were sitting there?
Old Dec 21, 2008 | 03:17 PM
Rogueain's Avatar
Yeah, I think so. My hands were freezing, so I don't remember clearly. But it was hot enough to warm my hands up. After we got back on the road, it went back to cold.
Old Dec 21, 2008 | 03:33 PM
Sounds like the A/C amp? Or tje thermoregulator isn't working?
Old Dec 21, 2008 | 03:46 PM
Rogueain's Avatar
I don't know, I regret, I know very little about cars.
But I can fix just about any computer.
Old Dec 21, 2008 | 05:24 PM
DeViLbOi's Avatar
If it was something like the AC amp or thermoregulator thingy it would effect both sides...right?
Old Dec 21, 2008 | 06:58 PM
Rogueain's Avatar
I'd put money on this thing, it's not working correctly.
Old Dec 21, 2008 | 07:13 PM
DeViLbOi's Avatar
Sure...it could be the blower if the air isn't moving at all. I just went through all 89 pages of the service manual. There is nothing that is driver vs. passenger side specific except for the duct. You probably have a dead rat or something stuck up in there.
Old Dec 21, 2008 | 07:18 PM
Rogueain's Avatar
LOL crap. How would I fix that?!
For that matter, how would I check?
Old Dec 21, 2008 | 07:23 PM
Victorino77's Avatar
Whitexican
I am having the exact same issue. If it weren't so cold outside i would be out there troubleshooting it myself. I need a garage!
Old Dec 21, 2008 | 07:28 PM
DeViLbOi's Avatar
It's only 1F here...-15 with the wind. Come on over. A wrench might freeze to your hand in 5 minutes...but that will give us 4 minutes to try and get in there. :P
Seriously...best bet would probably be to take a coat hanger and try and fish it in and see how far you can get. Out of curiosity...does your rear drivers side duct put out hot air?
Old Dec 21, 2008 | 07:32 PM
Rogueain's Avatar
Good question, didn't think to check. Let me go run my 8 for a bit and i'll check back with ya.
Old Dec 21, 2008 | 07:37 PM
Whitexican
Yeah that would involve me going outside ... We'll just see what Rogueain finds out.
Old Dec 21, 2008 | 08:05 PM
Rogueain's Avatar
Prognosis:
Same thing in the back, as the front. Unless i found the wrong vents...
Under the seat is where i found it blowing in the back.
Cold on driver, warm/warmish on passenger. Seems the vents blow a little colder in the back, which would seem normal to me, since the air has to travel a bit farther. Plus it's freezing outside ;p
Old Dec 21, 2008 | 08:06 PM
DeViLbOi's Avatar
How is the air speed between the two?
