catless midpipe = CEL?
Old Nov 24, 2008 | 11:34 AM
AE92's Avatar
so i have a cat back system now buit i want a catless midpipe. if i just install it as is i would get a cel correct? so how would i go about clearing the CEL and being able to run the midpipe without a CEL?
Old Nov 24, 2008 | 12:02 PM
Socket7's Avatar
ಠ_ಠ
put electrical tape over it. Or search the forums for an accessport or spark plug spacer.
Old Nov 24, 2008 | 12:16 PM
Silver06's Avatar
Zoom Zoom....
Yes you will get a CEL.
The Cobb AccessPort (using a MazdaManiac map) will mask emmissions cel's ($695).
There are "MIL Eliminators" for sale all over the Interwebs (or you can make your own from Radio Shack). What they do is use a capacitor and resistor (replacing the Rear O2 sensor) to provide a steady voltage to fool the computer. From what I've read here, they are not very successful on the RX-8. The problem seems to be that the ECU expects different voltages as the car warms up - and throws a code if the voltage is constant.
Old Nov 24, 2008 | 12:30 PM
04RX8man's Avatar
Rotary Powered Countryboy
yes def a CEL the only way i know is like above is get the accessport
Old Nov 24, 2008 | 01:02 PM
AE92's Avatar
what would the spark plug spacer do?
Old Nov 24, 2008 | 01:08 PM
Silver06's Avatar
Zoom Zoom....
A spark plug spacer is an extension that moves the rear O2 sensor out of the flow of exhaust gasses.
Note that our rear O2 sensor is a device that transmits varying voltage to the ECU based on the oxygen content of the exhaust stream. If you move the sensor the *right* distance, then it will transfer different voltages from its normal location. It's getting this distance *right* that is the challenge.
Old Nov 24, 2008 | 01:25 PM
dozer's Avatar
on his 3rd rx8
i installed a midpipe on mine this weekend...NO cel
Old Nov 24, 2008 | 02:00 PM
Big Money Pit's Avatar
you just wait.
Old Nov 24, 2008 | 02:39 PM
quazmosis's Avatar
Chode
I had a midpipe on for quite sometime and never got a CEL. It was the Agency Power midpipe. I took it off because it was insane loud.
Old Nov 24, 2008 | 03:45 PM
Jon316G's Avatar
Grasshopper
Give it a few drive cycles. Mine lasted a couple days without a CEL (both the AP and MazSport midpipe).
But few were lucky and never received one.
Well there you.. isane loud and ticket or Cel.
Old Nov 24, 2008 | 07:45 PM
MazdaManiac's Avatar
'04s often don't get CAT efficiency CELs.
mdl0209
May 23, 2019 05:46 PM
Evan Gray
Sep 26, 2015 12:30 PM
Forevermore
Sep 20, 2015 01:04 PM
DVerdeyen
Sep 13, 2015 11:19 AM
