weird grinding noise from shifter.
Old Nov 21, 2008 | 06:49 PM
Mr.&Mrs.Magic's Avatar
I had an annoying grinding noise coming from trans/shifter. Tonight I was driving around a bit and discovered that when in 1st 3rd 5th if I very very lightly push ^ on the shifter the noise goes away and when in 2nd 4th 6th if I lightly pull I get the same results. Any ideas?
I have the AFE shifter but I don't recall the noise till after I swapped the clutch and installed the RB gauges at the same time. I was thinking maybe the lines from the gauges were putting pressure on the shifter . I'm pretty sure I did a good job getting the lines out of the way though.
Tomorrow I'll get a sound clip/video
Old Nov 21, 2008 | 06:57 PM
I was thinking that is what is was but surely that has to be not good for the synchros
Old Nov 22, 2008 | 02:59 AM
ppf alignment..
check fluid level in the tranny..
btw, what color is the bucket on the short shifter?
Old Nov 22, 2008 | 07:53 AM
Not 100% on PPF but I'm pretty sure it's right.
fluid level should be good. Any way to actually check it? You can't see any fluid by looking down into the shifter hole so that means I didn't over fill.
off white color i think or was it yellow?????
Old Nov 22, 2008 | 12:18 PM
04RX8man's Avatar
Rotary Powered Countryboy
yeah def the forks rubbing on the synchros.....i think the only way to check it is to look through the check plug(?) on the trans to make sure it's filled all the way up....what type of trans fluid are u using?
Old Nov 22, 2008 | 06:14 PM
eneos GL-5
theblinkof
Oct 4, 2023 05:24 PM
Quiggs321
Sep 30, 2015 05:34 PM
tommy26Germany
Sep 29, 2015 10:33 AM
Jb4ker96
Sep 27, 2015 10:06 PM
