Gulf RX-8 Forum Serving TX, OK, AR, LA, MS
Anyone in San Antonio have a scanner? (Clear a CEL)
Old Nov 20, 2008 | 11:48 PM
To be named later's Avatar
Now with 25% more fluff..
It would be much appreciated.
CEL 0456-Evap-by the way.
Old Nov 21, 2008 | 08:45 AM
VS8's Avatar
VS8
4 Cylinder Rotary
ill be getting one in like a month
Old Nov 21, 2008 | 12:18 PM
cornholio135's Avatar
SARX
do this procedure should not (I believe) mess with the fuel trim..
1) With the key in the off position, press and hold the odometer reset button and turn the key to on;
Continue to hold the odo button until the odometer reads "TEST" and then release.
2) Turn the key to off and repeat step one.
should clear CEL....
Old Nov 21, 2008 | 06:47 PM
Thank you.
Long story short.......I called the dealer for the price on a gas cap ($19.92)
Instead of a cheapo replacement cap from Autozone, in case we still have the car 10-20 years from now it will be better to have as much as possible OEM parts.
So I figured long as I am at the dealer (North Park Mazda), I'm due for an oil change. I called them back, got an oil change appointment, and asked if they could clear the CEL, without doing a full diagnosis. The tech agreed.
So.......CEL is gone, has not come back on with about 3 small trips around town since.
Hopefully the %#$#@! thing stays off with the new cap.
Thanks anyway.
Hunterkelley24
Jun 14, 2022 08:32 AM
mdl0209
May 23, 2019 05:46 PM
GK1707
Sep 27, 2015 07:33 PM
Evan Gray
Sep 26, 2015 12:30 PM
