electrical or mechanical.
Old Nov 20, 2008 | 12:45 AM
eva02's Avatar
what's the difference or better? ill be installing a water temp gauge on the 8.
Old Nov 20, 2008 | 01:25 AM
hakuna matata!
electrical for sure.
you don't want a line going loose inside your cabin and hot coolant/oil spraying everywhere...
that and installing any mechanical gauge is a PITA.
Old Nov 20, 2008 | 07:38 AM
the difference is
mechanical required u to connect the tube from the water source all the way into your cabin. So like alz0rz said, if the tube or the gauge leak for whatever reason, its going to be a total mess.
Electrical on the other hand, require just a sensor to be installed on the water source. much cleaner and electrical wire is ALWAYS thinner than a tube. making it easier to route it into your cabin.
Only good thing about mechanical is that its a bit cheaper.
I have electical Defi gauge installed.
Old Nov 20, 2008 | 02:12 PM
eva02's Avatar
sweet ,thank's
Old Nov 20, 2008 | 06:16 PM
04RX8man's Avatar
Rotary Powered Countryboy
electrical for sure(if you didn't realize that from the above posters
Old Nov 20, 2008 | 06:20 PM
Mazurfer's Avatar
Surf Hard, Drive Hard
Originally Posted by nycgps
the difference is
Most people will tell you that besides cheaper......a mechanical is more accurate, but I agree.......not at the expense of having hot coolant or oil all over the cabin!
Old Nov 20, 2008 | 10:53 PM
Yep ur right. Mechanical is more accurate, but not by too much
Old Nov 21, 2008 | 06:31 PM
TrochoidMagic's Avatar
is adjusting valve lash
also agreed with more accuracy for mechanical gauges.
yurcivicsux
192
Sep 12, 2017 10:54 PM
Evan Gray
Nov 24, 2015 01:00 AM
garethleeds
Europe For Sale/Wanted
Nov 19, 2015 06:32 AM
zoom44
General Automotive
10
Sep 29, 2015 09:56 PM
1.3_LittersOfFurry
Sep 22, 2015 01:54 AM
