eibach vs stock springs ride height comparison
Old Dec 6, 2003 | 08:43 PM
another8owner's Avatar
stock sport pack car on level ground
front: 27.5" both sides
rear :27.5" both sides
this measuring from ground to under fender lip
eibach kit
front: 26 3/8 " passenger side only
rear: 26 3/8" passenger side only
this is also measuring on level ground to under fender lip.
heres the catch, maybe this is just on my car, the driver side measured,
front: 26.5" driver side only
rear: 26.5 " driver side only
so 1/8 " difference, dont know if it was meant to be or not but i will say again, car looks so so so sweet and the ride feels just the same if not better, im very satisfied with the eibach kit, and i dont rub around corners, turning or hit curbs when pulling up to them.
hope this helps all.
Old Dec 6, 2003 | 08:44 PM
oh yeah, my car is also a sport pack car.
Old Dec 7, 2003 | 04:14 PM
syntrix's Avatar
I like cheese!
maybe it assumes that it's going to be balanced with the driver and no passengers
Also try a measurement in a big flat parking lot, if you are on the street, most pavement slopes to the outside for drain off and could be affecting your measurements!
Old Dec 7, 2003 | 06:30 PM
Omicron's Avatar
Maybe you should stop lifting weights while sitting in the passenger seat?
yurcivicsux
192
Sep 12, 2017 10:54 PM
Sakebomb Garage
Sakebomb Garage
Oct 22, 2015 04:28 PM
Paul_Y
Sep 21, 2015 02:23 PM
Sakebomb Garage
Group Buy Center
Sep 12, 2015 08:18 PM
