trouble shoot my lean AFR problem
Old Nov 18, 2008 | 06:27 PM
Mr.&Mrs.Magic's Avatar
I need a bit of help and some possbile insights as to what may be causing my AFR to go lean.
When I go WOT in 1st gear my afr gets real lean but 2nd gear is fine. Then if I drive normal thru 1st and matt it in 2nd it will go lean. I'm currently running the AP with an MM tuned map. The maps for 1st and 2nd gear are the same and I've tried 3rd and 4th but they are always fine so I dunno.
Here's what I know for now: MAF sensor clean, No CELs, No hesitation during WOT, No cat, New Mazsport ignition solution so coils should be good, New plugs, No hard starts, timing stays at a flat 30/15 diff during WOT
wada ya think
Attached Thumbnails trouble shoot my lean AFR problem-1.jpg   trouble shoot my lean AFR problem-2.jpg   trouble shoot my lean AFR problem-1st-gear-ign.jpg   trouble shoot my lean AFR problem-2nd-gear-ign.jpg
Old Nov 18, 2008 | 06:39 PM
05rex8's Avatar
sold the 8... :(
maybe cuz the mazsport coils are caca.
Old Nov 18, 2008 | 06:44 PM
Flashwing's Avatar
3-wheeler
If possible I would experiment using your stock coils and see if the problem reproduces itself.
Old Nov 18, 2008 | 07:01 PM
old coils are shot! Shouldn't the ECU try and correct the problem in some way Because the only thing that changes to any noticable extent is afr.
this is what they looked like after a good thumb rubbin
Old Nov 19, 2008 | 07:16 PM
I think you picked the wrong map when you prgramed it. Re-read then instructions.
Theres nothing wrong with the coils.
Old Nov 19, 2008 | 07:24 PM
well thats good news about the coils but i pick up 20+hp(this is a guess went from mustang dyno at 134 to dynojet at 187) by switching to the mazsoprt ignition solution. I think you missed the part where I said this is not a base MM map. This is from a tune he sent me after I had established the proper MAF recal and sent him a datalog. If it was a maping issue shouldn't it show in both 1st and 2nd not just the first time I go WOT. Ither way I have gone back to 3a base map to see If I can reproduce the lean spikes
Old Nov 20, 2008 | 12:12 PM
kersh4w's Avatar
Hit & Run Magnet
how did you get that datalog?
Old Nov 20, 2008 | 12:22 PM
Not sure exactly what you mean but I got the format to create the log from r0tor. https://www.rx8club.com/series-i-engine-tuning-forum-63/d-i-y-datalog-graph-your-ap-efi-dude-scanalyser-157648/ and I used ATR to get the datalog
Old Nov 20, 2008 | 12:36 PM
MazdaManiac's Avatar
There is no way that ignition timing curve is correct.
Your boosted ignition curve should drop down to 11 or so at the 4k range and work its way back up to 20 or so at most by redline. (Not exact numbers - just ranges).
Have you verified the accuracy of your AFR readings with an external AFR gauge?
I know that my OE sensor is significantly slower than my Innovate.
BTW - that pic of your OE coils is meaningless.
Brand new coils look like that after only a few days. Its just mineral migration from the environment and the interaction with the EMF from the coils.
Old Nov 20, 2008 | 01:00 PM
By boosted do you mean FI because i'm NA or is this just more tunner lingo -->
I have been waiting till christmas for the AEM uego so the answer to that question is no.
Thought 1 way to tell how your coils are is by how white the the bottoms are again -->
Old Nov 20, 2008 | 01:08 PM
I thought you were turbo. (Too much going on in my noggin to keep track of everybody. lol)
Either way, the ignition advance will not "lock" onto one value.
Old Nov 20, 2008 | 01:34 PM
rotary.enthusiast's Avatar
The Local Idiot
^Doesn't the stock tune stay at 30 leading 15 trailing for a fairly large high load RPM range?
Is this one of MM's flashes? How many times have you data-logged this behavior?
Old Nov 20, 2008 | 01:47 PM
yes but I'm looking to something other than the fuel map since it only shows up the first time I go wot in ither 1st or 2nd gear. Lots of times every time.
I just switched to base 3a map a few days ago and was trying to see if I could get the spikes on a base map. Unfortunatly Johnny law heard my car and saw a huge fire ball come out so that pretty much stop my logging for the day(stupid turboxs pipe). Strangly he was pretty nice once I explained what I was doing and showed him the laptop plugged into the car.
Old Nov 20, 2008 | 02:55 PM
The Local Idiot
I'm surprised he didn't try to bust your chops about the emissions
Have you tried logging with the stock tune to see if the same (or at least similar) behavior is there?
MM: Do you change the closed loop exit RPM in your flashes?
Old Nov 20, 2008 | 03:04 PM
imput1234's Avatar
I ♥ Drifting!!!
re install it? and see what happens.
Old Nov 20, 2008 | 03:40 PM
1)No emissions in north georgia but i'm cat free so that is a problem.
2)thats what i'm doing is working my way back thru tunes till I get the point where I uninstall the AP then I have to log with dudelogger
Old Nov 20, 2008 | 03:56 PM
The Local Idiot
If you're doing more data-logging, humor me and my craziness and log STFT as well. It may seem like an odd request, but it is an indicator of closed loop vs. open loop operation (it will always be 0 in open loop).
The only working theory I have is that when you get the lean spike you're still actually in closed loop operation... when you do a WOT run in 1st gear, you eventually get into open loop, and it remains in open loop through 2nd gear, and thus your 2nd gear graph looks good. When you "take it easy" in 1st gear, and do a WOT pull in 2nd gear almost the entire thing ends up being in closed loop and you see the lean spike again. It's a pretty "out there" theory, and it shouldn't happen unless MM tweaks some things that I really doubt he messes with, but it's all I can come up with at this point.
My only other suggestion would be to get a different/better wide-band as a second opinion on your AFR.
Old Nov 20, 2008 | 04:08 PM
you may be on to something here. when I mat it the stft goes from negs to + then to 0 for the remainder. as soon as it goes open/0 stft wham lean spike. the highlighted area from left to right is AFR, MAF, MAF volt, STFT. Load also goes up a bit and then back to 100 or there about
Old Nov 20, 2008 | 04:14 PM
I do not alter the exit points for open/closed loop.
Old Nov 20, 2008 | 04:24 PM
possible fuel pump issues? maybe the signal telling to pump to START FREAKING PUMPING is getting there to slow. how could I trace this as a possible solution.
Fuel pluse width doesn't seem to be much different when I compare the gear to load and rpm
The Local Idiot
^That was in 1st gear? That doesn't explain it then... I was thinking you were remaining in closed loop during the lean spike. I'm at a loss
Old Nov 21, 2008 | 04:41 PM
Ok so after switching back to the stock V1c_3a map from MM I've been trying to tell myself the car wasn't pulling any harder It's just my brain playing tricks on me and the fuel trims weren't settled yet. After a week of tooling around I tried to do a bit of logging yesterday and was very unsuccessful thanks to mr. law dog. So today I gave it another shot today and could not get a WOT run for first because the damn tires would cut loose big time. This was a big suprise to me as I have never had such trouble with spinng and frankly didn't think this car has to power to do such things . Any way long story short I got a 2nd and 3rd ger WOT pull and these are the graphs.
Looks like the afr is all over the place but the spikes are no longer in the danger zone and the upper RPM AFR rage it's far better than the stupid 11's I was getting. When I sent in for my first tune with jeff I had a gutted stock cat but have since switched to the full turboxs pipe maybe this was the problem. Any who I'm going to drive for another few days and relog everything and see what I come up with.
Oh and I also noticed the spikes are in roughly the same place 6500-7000 RPM'S
Attached Thumbnails trouble shoot my lean AFR problem-2nd-gear-wot-v3a.jpg   trouble shoot my lean AFR problem-3rd-gear-wot-v3a.jpg
Old Nov 21, 2008 | 04:53 PM
Wow. Almost perfect. Just a couple of rich spikes here and there.
Remember, 13.2 is your target AFR N/A.
Is the timing normal now?
jeff i see you here please again cancel work on any maps from me as at this time it might be a waist of your time
not sure I'll check next time
Last edited by Mr.&Mrs.Magic; Nov 21, 2008 at 05:01 PM. Reason: can't type for sheet
Old Nov 21, 2008 | 04:56 PM
Yeah. Just get me complete logs with the current calibration and let me know what is going on with the open-loop cruise and fuel trims.
