Ahhhh, the "weird" bevel...
Old Jan 6, 2003 | 04:53 PM
wakeech's Avatar
mostly harmless
ladies and gents, Sputnik has posted some rather beautatious pics of the RENESIS cut-away model at the Detroit show Boowana is storming, and gives us a rather excellent view of the new spec rotors...
here's the link: Boowana's Beautatious Pics 'o' the RENESIS
i've heard of this trick on rotary tuning pages, where the leading sides of the rotor are ground away (corresponding with the side inspiriation ports) to advance the intake timing without cutting into the perhipheral housing with an extended J-Port ("Monster" port)...
so, this means that to really get "Zero" overlap, Mazda could advance the intake timing to the point where the rotor is JUST coming around to TDC when it starts to open (that's like, earlier than piston engines friends)... COOL BEANS TO THE MAX!! :D
of course, with the "correct" porting you could advance the timing wellllll before TDC, not that it'd be a good thing, but you could... :p
Old Jan 6, 2003 | 05:02 PM
Toadman's Avatar
Nomad Mod
Got my new wallpaper. Thanks guys!
Old Oct 18, 2018 | 01:54 PM
loewenm's Avatar
Links don't work for some reason.
Old Oct 18, 2018 | 03:22 PM
kevink0000's Avatar
85 cylinders, 6 rotors...
Check those dates. I have done that too.
Zelse
74
May 29, 2013 05:19 PM
Crash
Nov 14, 2005 03:07 PM
rotarygod
General Automotive
9
Mar 28, 2005 03:42 PM
DTECH-RX
May 12, 2003 11:03 AM
vipeRX7
Mar 16, 2003 04:36 PM
