A/C on and off cycles ac problem need help
Old Nov 14, 2008 | 01:33 AM
GrayRx810k's Avatar
My 04 rx8 is a 4 speed auto (I know ). I have no loss in power from the ac issue but my ac does cycle like crazy. On then 10 seconds and then off 5 sec then same thing over and over again, while driving and stops. I was build 09/03 and im out of warranty at 62000 miles. I recently visited my stelership for a check engine light, but my car has no problems and I also let them know about the ac, they said they had problems reading "the computer" and It needed to be replaced at 1300 dollars, so meaning they couldnt check the ac problem till they replaced it. Bull if you ask me the ac problem has a year but i hardly turned it on cause of the problem. I need help here and am offering a 30 dollar reward thru paypal for anyone that can solve my problem. I would like to take it to my local mechanic and let him know how to fix it so he can do it.
Old Nov 14, 2008 | 03:03 AM
https://www.rx8club.com/showthread.p...ghlight=ac+amp
the answer is in this thread.
post #7 is what you have to do.. you have to do it every time you reset the ecu or pull the battery...
Old Nov 14, 2008 | 03:23 PM
GrayRx810k's Avatar
Thats only for build after 09/03 mines before also I dont have a replaced compressor could that be the problem?
Old Nov 14, 2008 | 04:23 PM
did you try it to see if the recrc ac comes on when full cold.. see if it works..
more info in the tsb in the post..
Old Nov 14, 2008 | 05:07 PM
Nubo's Avatar
Lubricious
If your build is before, then I believe you need the updated AC Amplifier.
Old Nov 20, 2008 | 08:45 PM
GrayRx810k's Avatar
Do you think I need a new amplifier or just a reprogram??
RevMeHarder
Jun 1, 2026 02:30 PM
WranglerFan
Nov 5, 2017 09:35 AM
1.3_LittersOfFurry
Sep 22, 2015 01:54 AM
stickmantijuana
10
Sep 13, 2015 11:28 PM
RAE008
Sep 12, 2015 09:08 PM
