short trips
Old Nov 13, 2008 | 09:29 PM
shodan's Avatar
short trips
Hey,
I read that short trips are not really got for this car.
I don't drive it much. Basically to work and back.
So on average i do two 7min long trips a day
My work is 1 exit away from me and when i hit highway car is cold anyway - so no red lines.
Should i get worried?
(I drive like that almost year - no problems)
Its 04 stock with cai.
Old Nov 13, 2008 | 09:33 PM
XxSaMiRxXS's Avatar
i dont think that should be a problem .....as long as you let it work for 5 minutes or so when you turn the car on
Old Nov 13, 2008 | 09:39 PM
tubingchamp's Avatar
What mawd bug?
Take it for fun drives and redline it.
Old Nov 13, 2008 | 11:07 PM
TrochoidMagic's Avatar
is adjusting valve lash
i would worry about your driving habits.
exercise the revs a little bit and make sure the car is up to full tempurature. this will keep the air valves from sticking and varnish from building in your oil.
Old Nov 14, 2008 | 12:12 AM
Old Rotor's Avatar
Originally Posted by shodan
Hey,
How much oil do you have to add? When you check your oil is there any foam(water) on your dip stick. How often are you changing your oil(miles or time).
Old Nov 14, 2008 | 06:41 AM
PBlue's Avatar
Dial P for Phantom
im in fl, commute is 0.9 miles, it just warms up as i arrive, car is fine, i thrash it every other time i drive it.
its fine.
Old Nov 14, 2008 | 08:19 AM
greg985's Avatar
The 337
one day leave for work a little early and have some fun with it before you get to work....it will make you day so much better!
Old Nov 14, 2008 | 09:57 AM
hakuna matata!
yes, get worried.
Old Nov 14, 2008 | 10:15 AM
shodan's Avatar
I add every 1000. I think about 30% is gone on dipstick (not really sure but less then half hehe). Change every 3k.
No foam.
Yeah right earlier - dream on. I can't get up on time not to mention earlier
After too much traffic to go over 40 anyway.
I'll try just before work red line on 2nd gear. Just hit 9k and shift huh? Or i have to keep it there for a while?
poacherinthezoo
Aug 3, 2016 11:01 PM
R3Dream
48
Mar 12, 2016 01:44 PM
Evan Gray
Nov 24, 2015 01:00 AM
XianUnix
Sep 29, 2015 03:48 PM
