How to lossen the steering wheel? Help
Old Nov 13, 2008 | 07:51 PM
Maybe your connections are bad and you don't have power steering at all.
Do a search and you will find the connectors have been the problem on a lot of cars.
Old Nov 13, 2008 | 10:36 PM
SiLVeRE8's Avatar
a.k.a. WhITeRE8
are you sure its not because you dont have the strength to steer the steering wheel...? well anyways i actually like the steering being stiff because it feels like you are more incontrol of the car
Old Nov 13, 2008 | 10:48 PM
kersh4w's Avatar
Hit & Run Magnet
if its too hard to turn you need to either:
1. start lifting 1lb dumbbells
2. take it into a dealership
Old Nov 14, 2008 | 03:51 AM
SiLVeRE8's Avatar
a.k.a. WhITeRE8
then maybe theres a problem with you power steering then. well i have a suggestion for you before you bring it into the dealer... why not just see if there are anybody on this board which is near by you and ask them to see if you can try to steer their steering wheel and see if its same with yours or not.
Old Nov 14, 2008 | 06:22 PM
get a saw and cut it out
but seriously when did this start?
Old Nov 15, 2008 | 10:23 AM
compared to other peoples rx-8s or other cars? you got it used?
Old Nov 15, 2008 | 02:52 PM
Triperformance's Avatar
Keep in mind you have electronic motor for power assist. if it takes more then normal effort you may want to run it up to the dealer and see what they think. I would go to a dealer and try a new cars steering feel also.....doesn't matter if the car isn't the same but the feel should be similar.
Old Nov 15, 2008 | 02:59 PM
Does your car have a light in the upper left side of your dash looks like a steering wheel??
Old Nov 15, 2008 | 03:02 PM
Mazurfer's Avatar
Surf Hard, Drive Hard
That's what I was thinking................if he has a problem with the connectors or whatever, it should pick it up and he should have the dash light on. If not, then he needs to go find another RX8 and drive it to see if it's just him. WTF?
Old Nov 15, 2008 | 04:44 PM
04RX8man's Avatar
Rotary Powered Countryboy
yea we have electronic steering so check the cconnections but unless u know about electronic steering i would just take it to the dealer....if still under warranty just take it to the dealer now do not even check for anything tht is what warranty is for
Old Nov 18, 2008 | 11:13 PM
greg985's Avatar
The 337
^ummm yes haha
Old Nov 19, 2008 | 12:44 AM
kersh4w's Avatar
Hit & Run Magnet
yes...
go to a dealership.
Old Nov 19, 2008 | 12:48 AM
If you're under warranty take it in..otherwise check the connectors under the coolant overflow bottle....they get corroded and the connection screws with the CAN bus signals......and the power steering quits working. It's usually the smaller connector
Old Nov 19, 2008 | 02:10 AM
8 Maniac's Avatar
Originally Posted by dhan
Oh so there is a problem if a "!" next to it comes on?
the little wheel shouldn't be there either. The fact that it's lit at all is an indication that you have a problem.
On a related note... driving cars without power steering can be a pain. Drove a friend's 7 with the power steering removed and was surprised at first because I didnt know that it had no power steering... went to turn the wheel like I would usually turn my wheel and it barely budged lol.
Old Nov 19, 2008 | 04:47 PM
GTConversion's Avatar
Clean and comfortable
You should be steering with two hands anyway.
