Parts, Frame, Drive Train, Sections - What's Under the 8's Skin
Old Nov 5, 2008 | 10:29 PM
EdwardsB's Avatar
Registered RX-8 User
Been doing a lot of research on the 8, and have been looking for pictures of the frame or other parts. This is just some of the stuff that I have been able to find. Now its easier to find pictures when taking on a subject.
I figured that some of it could help other people out see what is under our cars skin, and to have it all located in one place. Add more if you have any I missed! If you find any mistakes I made please correct me.
I do not take any credit for these pictures, just organized them into one place.
Attached Thumbnails Parts, Frame, Drive Train, Sections - What's Under the 8's Skin-1.jpg   Parts, Frame, Drive Train, Sections - What's Under the 8's Skin-5.jpg   Parts, Frame, Drive Train, Sections - What's Under the 8's Skin-7.jpg   Parts, Frame, Drive Train, Sections - What's Under the 8's Skin-9.jpg   Parts, Frame, Drive Train, Sections - What's Under the 8's Skin-10.jpg
Old Nov 5, 2008 | 10:30 PM
EdwardsB's Avatar
more
Attached Thumbnails Parts, Frame, Drive Train, Sections - What's Under the 8's Skin-13.jpg   Parts, Frame, Drive Train, Sections - What's Under the 8's Skin-14.jpg   Parts, Frame, Drive Train, Sections - What's Under the 8's Skin-16.jpg   Parts, Frame, Drive Train, Sections - What's Under the 8's Skin-17.jpg   Parts, Frame, Drive Train, Sections - What's Under the 8's Skin-18.jpg
Old Nov 5, 2008 | 10:32 PM
EdwardsB's Avatar
more...
Attached Thumbnails Parts, Frame, Drive Train, Sections - What's Under the 8's Skin-19.jpg   Parts, Frame, Drive Train, Sections - What's Under the 8's Skin-23.jpg   Parts, Frame, Drive Train, Sections - What's Under the 8's Skin-25.jpg   Parts, Frame, Drive Train, Sections - What's Under the 8's Skin-27.jpg   Parts, Frame, Drive Train, Sections - What's Under the 8's Skin-30.jpg
Old Nov 5, 2008 | 10:34 PM
EdwardsB's Avatar
and more...
Attached Thumbnails Parts, Frame, Drive Train, Sections - What's Under the 8's Skin-38.jpg   Parts, Frame, Drive Train, Sections - What's Under the 8's Skin-40.jpg   Parts, Frame, Drive Train, Sections - What's Under the 8's Skin-43.jpg   Parts, Frame, Drive Train, Sections - What's Under the 8's Skin-32.jpg   Parts, Frame, Drive Train, Sections - What's Under the 8's Skin-11.jpg
Old Nov 5, 2008 | 10:35 PM
EdwardsB's Avatar
some of the frame...
Attached Thumbnails Parts, Frame, Drive Train, Sections - What's Under the 8's Skin-59.jpg   Parts, Frame, Drive Train, Sections - What's Under the 8's Skin-60.jpg   Parts, Frame, Drive Train, Sections - What's Under the 8's Skin-61.jpg   Parts, Frame, Drive Train, Sections - What's Under the 8's Skin-62.jpg   Parts, Frame, Drive Train, Sections - What's Under the 8's Skin-63.jpg
Old Nov 5, 2008 | 10:36 PM
EdwardsB's Avatar
more frame...
Attached Thumbnails Parts, Frame, Drive Train, Sections - What's Under the 8's Skin-64.jpg   Parts, Frame, Drive Train, Sections - What's Under the 8's Skin-65.jpg   Parts, Frame, Drive Train, Sections - What's Under the 8's Skin-67.jpg   Parts, Frame, Drive Train, Sections - What's Under the 8's Skin-68.jpg   Parts, Frame, Drive Train, Sections - What's Under the 8's Skin-69.jpg
Old Nov 5, 2008 | 10:37 PM
EdwardsB's Avatar
even more frame...
Attached Thumbnails Parts, Frame, Drive Train, Sections - What's Under the 8's Skin-79.jpg   Parts, Frame, Drive Train, Sections - What's Under the 8's Skin-88.jpg   Parts, Frame, Drive Train, Sections - What's Under the 8's Skin-89.jpg   Parts, Frame, Drive Train, Sections - What's Under the 8's Skin-92.jpg   Parts, Frame, Drive Train, Sections - What's Under the 8's Skin-93.jpg
Old Nov 5, 2008 | 10:40 PM
EdwardsB's Avatar
some parts pictures from onlinemazdaparts.com I went through and saved from their online catalog...
*As I get time I will add descriptions to the numbers.*
AC System
1) Condenser 2) Protect shield 3) Compressor 4) Clutch 5) Pressure hose 6) To condenser 7) Upper hose 8) Upper hose Bracket 9) Evaporator tube 10) Evaporator tube Bracket 11) Pressure switch 12) Pressure switch Clip 13) Temp sensor
Air Bags
1) Driver air bag 2) Psngr air bag 3) Clockspring 4) Diagnostic unit 5) Head air bag Righ 6) Module Cloth Right 7) Ft impact sensor 8) Side impact sens Back 9) Side bracket Right
Air Pump Assembly
1) Air pump 2) Air pump Bracket 3) Air pump Rubber mount 4) Air pump Bolt 5) Air pump Harness 6) Air hose 7) Control valve 8) Control valve Gasket 9) Control valve Clamp 10) Air pipe 11) Resistor 12) Bracket 13) Boost sensor 14) Boost sensor Bolt 15) Tube 16) Tube Insulator 17) Tube Rubber mount 18) Ft oxygen sensor Manual trans 19) Rr oxygen sensor Manual trans 20) Vapor canister
Alternator
1) ALTERNATOR 2) VOLTAGE REGULATOR 3) BEARINGS 4) STATOR 5) ROTOR 6) BRUSHES 7) RECTIFIER 8) FRONT COVER 9) REAR COVER
Diff and Axel
AC system - Air Bags - Air Pump Assembly - Alternator - Axel and Diff
Attached Thumbnails Parts, Frame, Drive Train, Sections - What's Under the 8's Skin-ac-system.gif   Parts, Frame, Drive Train, Sections - What's Under the 8's Skin-air-bags.gif   Parts, Frame, Drive Train, Sections - What's Under the 8's Skin-air-pump.gif   Parts, Frame, Drive Train, Sections - What's Under the 8's Skin-alternator.gif   Parts, Frame, Drive Train, Sections - What's Under the 8's Skin-axel-diff.gif
Old Nov 5, 2008 | 10:42 PM
EdwardsB's Avatar
Center Arm Rest/Console
1) Lid assy 2) Lock assy 3) Base 4) Base Spring 5) Base Mat 6) Hole cover
Radiator Cooling Fans
1) Fan assy 2) Shroud 3) Fan Right 4) Motor Right
Door Gutter/Seal
Front Door Lock
1) W/o smart keyless Black Right 2) Bolt Bolt Back 3) Grommet Grommet Back 4) Door check Back 5) Striker Back 6) Upper hinge Right 7) Lower hinge Right 8) W/o theft alarm W/o theft alarm Right 9) Clip Clip Back 10) Handle inside Right 11) Handle bezel Right 12) W/smart keyless W/smart keyless Right
Door Sills
Center Arm Rest/Console - Radiator Cooling Fans - Door Gutter/Seal - Front Door Lock - Door Sills
Attached Thumbnails Parts, Frame, Drive Train, Sections - What's Under the 8's Skin-center-arm-rest.gif   Parts, Frame, Drive Train, Sections - What's Under the 8's Skin-cooling-fan.gif   Parts, Frame, Drive Train, Sections - What's Under the 8's Skin-corner-gutter.gif   Parts, Frame, Drive Train, Sections - What's Under the 8's Skin-door-lock.gif   Parts, Frame, Drive Train, Sections - What's Under the 8's Skin-door-sill.gif
Old Nov 5, 2008 | 10:44 PM
EdwardsB's Avatar
Exhaust System
1) Exhaust manifold 2) Exhaust manifold Gasket 3) Converter and pipe 4) Converter and pipe Gasket 5) Intermed pipe 6) Muffler
Front Bumper and Support
1) Bumper cover W/o lmp washer 2) Emblem 3) Emblem Clip 4) Retaining brkt Right 5) Front retainer 6) Side bracket Right 7) Retainer plate Right 8) Energy absorber 9) Retainer 10) Fastener Fastener Back 11) Reinforcement 12) Fastener Fastener Back 13) Seal plate 14) Seal plate Rivet 15) Seal plate Fastener 16) Side duct 7) W/o fog lamps W/o lamp washer 18) Tow hook Back 19) Tow hook Cover assy 20) Front spoiler 21) Clip Clip Back 22) License bracket
Front Center Console
1) Console assy 2) Side panel Right 3) Manual trans Cloth 4) Panel assy Clip 5) Trim plate To 11/05 6) Shift boot 7) Shift indicator 8) **** 9) Seat heat switch Right 10) Control switch 11) Ashtray assy 12) Lamp 13) Bulb 14) Spring 15) Lighter 16) Holder 17) Power outlet
Front Seat Belt
1) Seat belt assy Right 2) Cloth seats Cloth seats Right 3) Rail Right 4) Bracket Bracket Right 5) Anchor cover Back 6) Cap Back
Front Seats
1) Cloth Cloth Right 2) Cloth Cloth Right 3) Front Cloth Back 4) Rear Cloth Back 5) Cloth Cloth Right 6) Side air bag Back 7) Seat back panel Right 8) Cloth Cloth Right
Exhaust System - Front Bumper and Support - Center Console - Front Seat Belts - Front Seat Assembly
Attached Thumbnails Parts, Frame, Drive Train, Sections - What's Under the 8's Skin-exhaust.gif   Parts, Frame, Drive Train, Sections - What's Under the 8's Skin-front-bumper.gif   Parts, Frame, Drive Train, Sections - What's Under the 8's Skin-front-center-consol.gif   Parts, Frame, Drive Train, Sections - What's Under the 8's Skin-front-seat-belts.gif   Parts, Frame, Drive Train, Sections - What's Under the 8's Skin-front-seats.gif
Old Nov 5, 2008 | 10:46 PM
EdwardsB's Avatar
Fuel tank to help people understand the fuel starvation on sweeping turns with a 1/4 tank left
#15 is the fuel pump
#1 is the "saddle" fuel tank
Front Suspension
1) FRONT HUB and BEARING 2) KNUCKLE 3) STRUT 4) COIL SPRING 5) SPRING INSULATOR 6) STRUT BUMPER 7) STRUT MOUNT 8) UPPER CONTROL ARM 9) LOWER CONTROL ARM 10) STABILIZER BAR 11) LINK 12) BUSHINGS 13) BRACKET 14) CROSSMEMBER
Fuel Tank
1) Fuel tank 2) Strap 3) Filler hose 4) Clamp No. 1 5) Clamp No. 2 6) Clamp No. 3 7) Filler pipe 8) Dust cover 9) Dust cover Bolt 10) Filler cap 11) Upper hose 12) Breather tube 13) Lower hose 14) Protect shield W/o sport susp 15) Fuel pump 16) Fuel pump Gasket 17) Fuel pump Bracket 18) Fuel sender unit Right 19) Retainer Back 20) O-ring Back 21) Pipe 22) Pipe shield 23) Pipe shield Bracket
Interior Heating Assembly
Hinge Pillar
Hood
1) Hood 2) Cushion Cushion Back 3) Rear seal 4) Insulator 5) Insulator Fastener 6) Front seal 7) Striker 8) Striker Bolt 9) Support rod 10) Support rod Holder 11) Support rod Spacer 12) Release cable Manual trans 13) Latch W/o alarm 14) Hinge Right 15) Lower bolt Lower bolt Back 16) Upper bolt Upper bolt Back
Front Suspension - Fuel Tank - Interior Heating Assembly - Hinge Pillar - Hood
Attached Thumbnails Parts, Frame, Drive Train, Sections - What's Under the 8's Skin-front-suspension.gif   Parts, Frame, Drive Train, Sections - What's Under the 8's Skin-fuel-tank-pump.gif   Parts, Frame, Drive Train, Sections - What's Under the 8's Skin-heater-assembly.gif   Parts, Frame, Drive Train, Sections - What's Under the 8's Skin-hinge-pillar.gif   Parts, Frame, Drive Train, Sections - What's Under the 8's Skin-hood.gif
Old Nov 5, 2008 | 10:48 PM
EdwardsB's Avatar
partss...
Front Dash - Interior Blower - Starter - Oil Cooler - Front Seat Rails
Attached Thumbnails Parts, Frame, Drive Train, Sections - What's Under the 8's Skin-instrument-panel.gif   Parts, Frame, Drive Train, Sections - What's Under the 8's Skin-interior-blower.gif   Parts, Frame, Drive Train, Sections - What's Under the 8's Skin-manual-starter.gif   Parts, Frame, Drive Train, Sections - What's Under the 8's Skin-oil-cooler.gif   Parts, Frame, Drive Train, Sections - What's Under the 8's Skin-passenger-seat-rail.gif
Old Nov 5, 2008 | 10:50 PM
EdwardsB's Avatar
even more parts...
Radiator - Rear Brakes - Interior Rear Door Trim - Rear Door Locking Mechanism - Rear Suspension
Attached Thumbnails Parts, Frame, Drive Train, Sections - What's Under the 8's Skin-radiator.gif   Parts, Frame, Drive Train, Sections - What's Under the 8's Skin-rear-brakes.gif   Parts, Frame, Drive Train, Sections - What's Under the 8's Skin-rear-door-interior-trim.gif   Parts, Frame, Drive Train, Sections - What's Under the 8's Skin-rear-door-locking-hardware.gif   Parts, Frame, Drive Train, Sections - What's Under the 8's Skin-rear-suspen-knuckle-assembly.gif
Old Nov 5, 2008 | 10:51 PM
EdwardsB's Avatar
parts parts parts...
Roof & Lights - Sunroof - Steering Wheel - Water Pump - Windshield Wiper and Washer
Attached Thumbnails Parts, Frame, Drive Train, Sections - What's Under the 8's Skin-roof-subframe-lights.gif   Parts, Frame, Drive Train, Sections - What's Under the 8's Skin-sunroof.gif   Parts, Frame, Drive Train, Sections - What's Under the 8's Skin-steering-wheel-air-bag.gif   Parts, Frame, Drive Train, Sections - What's Under the 8's Skin-water-pump.gif   Parts, Frame, Drive Train, Sections - What's Under the 8's Skin-wiper-washer.gif
Old Nov 5, 2008 | 10:52 PM
Mazdaspeed RX8 ver2's Avatar
this is a great thread for references to these parts. this will help a few people in the club. thanks, those pics are awesome!
8 Maniac's Avatar
wow.. nice. That's a lot of good photos. Havent really seen many pics of stuff like these. Great thread.
Old Nov 5, 2008 | 11:05 PM
EdwardsB's Avatar
thanks guys. I was just going for a reference page because I know it can be frustrating to find that one picture you need.
Old Nov 6, 2008 | 06:26 AM
altspace's Avatar
Eccentric Shafting
Awesome post. If you can get your hands on the RX-8 book it really goes into detail in regards to why they engineered what they did to build the 8.
Old Nov 6, 2008 | 11:19 AM
greg985's Avatar
The 337
great thread
Old Nov 6, 2008 | 11:21 AM
scwchapman's Avatar
Sticky
Old Nov 6, 2008 | 12:00 PM
perks11's Avatar
HEADTURNER
^^^i agree this is Sticky material. the pics are very nice, and it was nice to see some pics of the drive train and everything. i had been looking for some good pics like this for a couple of days. thanks
Old Nov 6, 2008 | 01:15 PM
EdwardsB's Avatar
what book are you talking about, do you have a name...is it an SAE journal?
EDIT: wow I'm dumb...the book is just called: RX-8. Going to try to pick this up, or maybe for christams.
thanks again...glad I could help out some.
Old Nov 6, 2008 | 02:24 PM
Big Money Pit's Avatar
this is a really neat post.
i enjoyed it very much.
where is that skeleton car at?
Old Nov 6, 2008 | 02:53 PM
altspace's Avatar
Eccentric Shafting
Not sure where that is, but here's the Mazda Museum in Japan. http://www.mazda.com/mazdaspirit/museum/guide.html
Old Nov 6, 2008 | 04:00 PM
imput1234's Avatar
I ♥ Drifting!!!
altspace, what museum is that from?
