Want wheel advice....
Old Oct 18, 2008 | 09:58 PM
jimmi1977's Avatar
I will be picking up my 2005 RX-8 this tuesday. What a stylish car
You have to rev it high, though, it doesn't start action before 4000 RPM
Here's a quick question:
The recommended 17" rim (for winter tires) from tirerack is:
17x7.5
Offset: +48mm Backspacing: 6.18" Bolt Pattern: 5-114
Rec. Tire Size: 225/50-17
I have the following rims and tires (originally bought for G35):
17x7Offset: 45mm Backspacing: 5.78" Bolt Pattern: 5-114
Rec. Tire Size:235/50-17
So, I have 17x7 instead of 17x7.5 with different offset and slightly wider tires.
Will it fit???
Old Oct 19, 2008 | 09:09 AM
AndrewE's Avatar
Yellow Fever
offset is a simple thing to understand, if you take your 7.5 wheel with a +48mm offset all you do is divide the width in half and add the offset
so if you have a 7.5" +48 you are looking at a 5.5(5.63 in actuality) inch backspacing approximately
(25.4 mm = inch) which means you have the diffefrence of 7.5 in front(1.87"), and should clear the fenders
the 7inch should will be 5inch(approx) with about the same front spacing so you should be alright
Old Oct 20, 2008 | 08:54 AM
Thief's Avatar
Reppin Lightning Yellow
Welcome to the Brotherhood of the Rotary! Once you get your car, post some pics!
Old Oct 20, 2008 | 09:07 AM
Rotary Mike's Avatar
Registered 407 Abuser
Welcome to the club! The only problem with those tires are they are so wide, they made partially defeat the purpose of a winter tire (think snow shoe effect). That plus 235/50R17 isn't quite a match to the stock diameter of 225/45R18 (1.1% too slow)
Old Oct 20, 2008 | 09:30 AM
Kafka's Avatar
Hi and welcome to the club.
235 will be to wide for winter driving for Rx-8.
Anything less than 225 will have bad effects on suspension due to insufficient corner load when its NOT SNOWING.
You can call ask for Al Balinsky at Scarboro Mazda @ 416.752.0970 if you need further information and tires inquiry.
FYI: Winter Tire Group Buy
Thank you.
Old Oct 20, 2008 | 09:54 AM
jimmi1977's Avatar
Thanks guys! Can't wait to get the car! Will be picking it up tomorrow night and have to drive it 80km home. Hope it's not too cold tomorrow for it's stock tires...
I'll probably still get me another set of winters, since G35 has to ride on something too. I was just thinking about some extreme scenarios like putting winters only on the rear of both cars. But this is plain stupid, anyways
Old Oct 20, 2008 | 10:00 AM
Thumper3322's Avatar
Welcome! post some pics when you get it.
Get some new winters for it, with the correct sizing. It will make all the difference.
Old Oct 20, 2008 | 06:20 PM
AndrewE's Avatar
Yellow Fever
What are the ill-effects? I ran 215/55/17s last year and didnt see any problems????
Old Oct 20, 2008 | 06:23 PM
Gyro_Bot's Avatar
Zoom Zoom
Your going to love your new obsession!
Check out the many articles on this website, there is a serious wealth of information here.
PS: Where do you live?
Old Oct 20, 2008 | 06:36 PM
Kafka's Avatar
Originally Posted by #84Racing
If you only run your tires in the snow and not on dry roads etc everyone is absolutely right. HOWEVER, the 1st dry day when you go into the hwy ramp at your normal speed your smaller improperly rated tires will start to shred the tread. Your cars have a very sophisticate suspension system. We learned this years ago with BMW & Mercedes, thats why tires like the Blizzak LM22 or the Michelins were created to handle the suspension of higher performance cars and not destroy tires in one season if we dont get a lot of cold and snow.
#84Racing is GM of Scarboro Mazda, Ontario GT Sprint racer with 25+ years of street / track / drag racing experience
Old Oct 20, 2008 | 07:54 PM
AndrewE's Avatar
Yellow Fever
so only i'll effect is to the tires? no biggie I'm more of a threat to the tires anyway
also I ran my winter tires till mid august as i had complications with tires i ordered in the spring not showing for 3 months, snows still look good after 13000km about 6-8000 on bone dry pavement.
Old Oct 21, 2008 | 09:50 AM
jimmi1977's Avatar
I'm in Thornhill. Any local meets?
Old Oct 21, 2008 | 09:58 AM
Kafka's Avatar
You just missed the
Fall season drive: Forks of the Credit (photos on page 10)
But we will still have meets in the winter seasons, and will post in the forum.
btw I live in Thornhill too.
Old Oct 22, 2008 | 10:48 PM
Cerone's Avatar
hey guys im going winter tire shopping tommorow just wanted some opinions of a good type of winter tire, im new to this whole tire technology and specifications..... wondering if someone could give me or give some opinions on good tire type (dunlop, goodyear, michellin ect.) and what specs from what i read is 225/55r16 94v good cause i really have no clue give me some input
thanks.
Old Oct 22, 2008 | 11:45 PM
Kafka's Avatar
225 - good
94 - load rating above 91 (stock rx8 18" tires) - good
V - speed rating safe up to 240km/h - compare to W rating, 270km/h in stock rx8 18" tires - good
I think its good. I got 225/50r17, and your 225/55/16 is stock 16" spect so its good too.
We have forum members doing
Bridgestone Blizzak LM-22
Dunlop Winter Sport M3
Michelin Pilot Alpin PA3
All 3 are good with Michelin the latest technology...
good luck
Old Oct 23, 2008 | 08:40 AM
thanks.
Isn't 16" too small for our RX-8s?
Old Oct 23, 2008 | 09:11 AM
Yes!
Old Oct 23, 2008 | 09:18 AM
Kafka's Avatar
well we have 16" stock tires for rx8...dunno about the winter tires....
Old Oct 23, 2008 | 09:26 AM
16" fit? that's not what I have read. That would be a tight fit.
Old Oct 23, 2008 | 09:30 AM
Footman's Avatar
Dodging those Corollas
I think the 16" wheels were made for the 04 automatics in Non-North American spec vehicles. They had smaller brake calipers.
All North American models received the 18" wheels and the larger diameter disc brakes. Our discs are 12.9" in the front. The caliper itself adds another 2" roughly, so the 16" might fit radially-wise, but you gotta see how deep the face front is to clear the caliper. Steelies are very shallow on the face front and will touch the caliper.
Old Oct 23, 2008 | 09:36 AM
jimmi1977's Avatar
Here are the photos:
http://www.kraev.net/rx8-1.jpg
http://www.kraev.net/rx8-2.jpg
http://www.kraev.net/rx8-3.jpg
http://www.kraev.net/rx8-4.jpg
http://www.kraev.net/rx8-5.jpg
What a beauty. Drives amazingly too Hope the engine lasts
Old Oct 23, 2008 | 10:03 AM
Kafka's Avatar
Thanks Footman...I guess go 17 to be on the safe side then.
Old Oct 23, 2008 | 10:20 AM
prospectjtaz's Avatar
16" wont fit cause of the larger rotors in front. Dont wanna destroy your car. Honestly dont waste your time at crappy tire, do you really want high school kids installing stuff on your car.
hufflepuff
May 30, 2016 10:45 AM
snowrydr01
Nov 23, 2015 09:40 AM
duworm
Oct 1, 2015 04:57 PM
GranTouTou
Sep 30, 2015 06:11 AM
