Bolt and Nut Sizes--Exhaust
Old Oct 10, 2008 | 07:41 AM
endowdly's Avatar
Guppies? Anyone?
Does anyone know the bolt and nut sizes on the spring connectors between the midpipe and the muffler (catback)? Can't find it in search and I need to replace mine for... reasons. Thanks...
i'm guessing either 10 or 14 mm studs? which is it?
Old Oct 10, 2008 | 07:47 AM
nuke0907's Avatar
Never Blend In
they are studs not bolts. the nuts on mine seized. i tried looking at auto parts stores for days trying to find them but nobody had the right size. you will have to get them from a dealer unfortunately and they are about $9 each. you can try to see if the service department is doing a cat swap and see if the can give you the old studs from another car. thats what i did and the guy gave them to me for free.
Old Oct 10, 2008 | 09:10 AM
endowdly's Avatar
Guppies? Anyone?
yikes that sucks.
all i really need to know is if the studs and nuts are standard sizes. because if yes i can find them in a hardware store or make my own. and when i say size i mean internal diameter. i guess i really just need to know the stud size then, huh? lol...
Old Oct 10, 2008 | 09:41 PM
Optical TDI's Avatar
If you don't want to use the springs then you can take one of the bolts/studs in to hardware shop. Find what nut fits on the end that go into the catpipe. Then you can use that to find the correct thread size, pitch, etc. I think the pitch was 1.25 and it was a metric bolt. That's what I just did and bought two 1.25 inch bolts that threaded perfectly into the catpipe. No springs though.
Old Oct 11, 2008 | 06:28 AM
endowdly's Avatar
Guppies? Anyone?
got it. thanks to nuke and optic for the help, really helpful to know that pitch.
for reference, it's a 10 mm stud with 14 mm nuts. <--that's what she said.
Old Oct 11, 2008 | 07:34 AM
nuke0907's Avatar
Never Blend In
i wouldn't suggest using just plain bolts. that joint is made to be flexible so you don't crack your manifold or something.
Old Oct 11, 2008 | 10:32 AM
endowdly's Avatar
Guppies? Anyone?
Yeah the springs on the stock joint help the rear assembly flex back and forward under stress. But, since the cat and muffler assembly are on hangers and can flex a little anyway--I don' t think damage will occur if just straight bolts are used.
Old Oct 11, 2008 | 10:47 AM
chancejat's Avatar
Drive it like u stole it!
i got bolts from home depot ....but i forget what size....maybe 5/8
TotalAutoPerformance
Vendor Classifieds
12
Oct 17, 2018 09:00 AM
RX-8 Racing
20
May 14, 2016 06:25 PM
He||hammer
Sep 29, 2015 09:40 PM
WingleBeast
Sep 9, 2015 10:10 AM
Series I Do It Yourself Forum
Sep 6, 2015 01:04 PM
