Auto Leveling Headlight Malfunction switch
Old Sep 17, 2008 | 12:49 PM
Rx8driver08's Avatar
Hey all, when i turned my car on the other day and when i turned on the headlights, a warning light came on saying that there was an auto leveling malfunction. I waited for the light to go off like all the other lights but it didn't. I have an 04' Rx8 Grand Touring. The beam pattern and height were fine but i was wondering if i should even bother to have the auto levelers fixed and if so how much does that usually cost assuming i need new ones.
Old Sep 17, 2008 | 01:56 PM
greg985's Avatar
The 337
are you still in your warrenty?
Old Sep 17, 2008 | 02:06 PM
Jon316G's Avatar
Grasshopper
If you're under warranty, take it to the dealer!
Here is the TSB for it:
http://www.finishlineperformance.com...8-07-1729a.pdf
When mine failed, the lights slowly started to lower the angle down to the point I only had roughly 6ft of light in front of me (which is scary doing 70MPH).
If you're out of warranty, here is a link to a DIY for rebuilding the sensor:
https://www.rx8club.com/series-i-do-yourself-forum-73/diy-headlight-auto-level-sensor-rebuild-aka-headlamp-leveling-131557/
Good luck!
Old Feb 24, 2009 | 06:12 PM
tj7723's Avatar
glad you posted this, i am having the same prob.
Old Apr 7, 2012 | 08:49 AM
RaspyRotary's Avatar
Rotary teen!
Just like an Easter miracle, I shall revive this thread!!!
Glad I found this. gonna have to check it out, before I go blind.
Old Jan 24, 2021 | 08:12 PM
hufflepuff's Avatar
can this feature just be deleted for a fixed angle?
Old Mar 29, 2021 | 09:03 PM
Krazymonkeys's Avatar
I think so. I know someone made a thread regarding a manually adjustable setup that I ran across once, but what I found is that it's the same sensor that's used on the Prius and several other Toyota and Lexus cars and maybe a couple Nissan. The only difference is the brackets. You can buy the sensors extremely cheap on Amazon. I think mine were $44 something for two, shipped with Prime. $21.99 each I think before tax? They're probably knock-offs, but they work. At $22 each, though, who cares? You can replace them MANY times for the price of OEM ones and probably have a total lifespan far longer for the sensors by the time you hit the same cost.
Old Mar 30, 2021 | 08:12 AM
Legal_Legend's Avatar
https://www.rx8club.com/series-i-do-...stment-220833/
Old Mar 30, 2021 | 08:48 AM
Yep that's the one. It's been a while and I couldn't remember exactly where I saw it.
bren5279
Feb 8, 2012 12:20 PM
ocyoo
May 4, 2011 06:46 PM
zx10 r rx8 man
Jun 1, 2010 01:32 PM
Mingo
Jan 29, 2010 03:20 PM
munn3yxiong
Nov 16, 2009 05:22 PM
