Problem @ 7500 RPM
Old Sep 9, 2008 | 04:57 AM
Fabulous's Avatar
Problem @ 7500 RPM
Need Help!
My car suddenly jerk (kind of suddenly loss of fuel or air) at every 7500 rpm. Only @ 7500rpm.
it jerks and than suddenly continue to rev up......
Old Sep 9, 2008 | 05:03 AM
DOMINION's Avatar
I don't buy Kool-Aid
Could be a bad fuel pump. Search it up. From what I have read its a e-z fix
I would check my plugs. They could be bad not getting a good charge at the high RPM's.
Old Sep 9, 2008 | 08:00 AM
Fabulous's Avatar
Will check it. But just thinking it is wierd because it only happen @7500rpm.
Could it be the injector which start @ 7500rpm
Old Sep 9, 2008 | 08:10 AM
check your Aux port.
Old Sep 9, 2008 | 11:03 AM
Fabulous's Avatar
Don't think it is an oil issue. I'm using Greddy (5W40) since day 1.
Old Sep 9, 2008 | 11:10 AM
hakuna matata!
how many miles on the car
Old Sep 9, 2008 | 11:29 AM
Fabulous's Avatar
6 speed MT JDM. now about 45k miles.
Old Sep 9, 2008 | 07:38 PM
Are you sure you are not hitting the rev limiter?
Old Sep 9, 2008 | 09:23 PM
Fabulous's Avatar
RPM redline @ 9000. have been remapped by RE Amemiya.
no problem for years until lately....
Old Sep 9, 2008 | 10:25 PM
kersh4w's Avatar
Hit & Run Magnet
pull the room fuse?
Old Sep 10, 2008 | 08:13 AM
Fabulous's Avatar
sorry, but what is the room fuse?
Originally Posted by kersh4w
pull the room fuse?
Old Sep 10, 2008 | 08:29 AM
StealthTL's Avatar
Footwell fusebox, marked 'room' controls constant power to the ECU.
.....but it sounds like a sticky actuator on the inlet manifold, to me.
S
Old Sep 10, 2008 | 08:33 AM
Spinning Sushi's Avatar
I <3 Sushi
Do this: https://www.rx8club.com/series-i-do-yourself-forum-73/diy-mazda-zoom-power-engine-cleaner-engine-cleaning-seaform-142852/
That should fix your problem.
Old Sep 10, 2008 | 09:33 AM
elysium19's Avatar
S
Same thought here.... Although I thought those come on earlier (6800), but it's possible you're not feeling it till a half-second later or something.
You can take that apart pretty easily and make sure the valves are opening smoothly.
Old Sep 10, 2008 | 09:58 AM
Fabulous's Avatar
Done the above with the Liquid molly and compression check o.k.
Didn't help to resolve the 7500rpm jerk!!
Old Nov 11, 2008 | 11:19 AM
Fabulous's Avatar
Dear ALL,
I'm still having the problem. When I rev my rpm, it still hesitated @7500rpm (as though insufficient fuel for a 2 seconds) and then continue to climbing to 8500rpm and feeling lost of power.
It doesn't seem to be a mechanical problem. Do you think my ECU is the problem?
Anyone has experience this problem on 6MT JDM spec.
Need help urgently.
RevMeHarder
Jun 1, 2026 02:30 PM
WranglerFan
Nov 5, 2017 09:35 AM
GARCIAC951
Sep 10, 2015 07:17 PM
tgaffner
Sep 7, 2015 08:49 PM
Kim Jong Illest
Sep 4, 2015 04:27 PM
