Rack & pinion do it yourself!!
Old Aug 18, 2008 | 02:48 PM
bmccarthy's Avatar
Cool Rack & pinion do it yourself!!
In another thread I was told that I can fix the Rack & pinion myself.
I can't seem to find the thread. Click here for threadCan anyone let me know how to do it or maybe show me the right thread?
This would be greatly appreciated
Thanks,
Old Aug 18, 2008 | 03:18 PM
StealthTL's Avatar
https://www.rx8club.com/series-i-tech-garage-22/steering-breaks-78508/
If you don't want to read the whole thing - there is a poor connection, just below the rad overflow pipe. Coolant gets in and the contact gets 'iffy'.
Mazda has a replacement wire for the area, its about 18", with new ground contacts etc., but dealers don't seem to know about it.
If you're out of warranty you can tighten the grounds and cut out the big connector and solder the actual wires together. (Someone who knows how to solder can save you a wack'o'cash.) You have nothing to lose - if the steering is still intermittent, you still need a rack.
Don't forget the obvious, clean and tighten all the battery connections first.....
S
ax75f92
Aug 18, 2020 12:05 AM
200.mph
Dec 10, 2018 03:49 PM
Prescription 8
Non-Rotary Swaps
117
Feb 14, 2018 12:07 PM
shambo
Jul 18, 2015 02:07 PM
