When does the low gas light go on?
Old Nov 26, 2003 | 03:57 PM
godai00's Avatar
Any experience as to how much gas remains when the yellow light goes on? It seems to go on early and I've run it to the E line and put in 14 gallons. This means about 2 gallons remain at the E line. Yellow light came on much earlier for me. I drove maybe 20 miles with it on. Any chance it goes from yellow to red? I didn't want to run any lower without more experience.
Old Nov 26, 2003 | 04:02 PM
RX-GR8's Avatar
its got about 2-2.5 gallons left when the light goes on. dont think it changes from yellow to red and dont want to run out of gas finding out.
Old Nov 26, 2003 | 04:09 PM
ptiemann's Avatar
Someone on this site ran out of gas - even twice, I think.
He did not mention anything about the light turning red.
Old Nov 26, 2003 | 04:20 PM
shift_zoom8's Avatar
My light goes on usually at 13.2 to 13.5 gallons. In other words, if I go to the gas station asap after the light goes on, it usually takes 13.2 to 13.5 gallons to fill up.
Old Nov 26, 2003 | 06:05 PM
matt's Avatar
Ditto.
Old Nov 26, 2003 | 06:59 PM
StealthTL's Avatar
Cool Out of gas.....
I find the light comes on after I have used 50 litres (13.2 US gallons/11 UK gallons), which would leave about 10 litres (2.5 US/2 UK)
So you can work out how far you have left on your 2.5 gallons, but you should make a habit of refilling at yellow for the longevity of your fuel pump. It is a high pressure submersible pump that uses the liquid as a coolant, and running dry can also cause 'overspeed' wear when the pump races.
S
Audio Concepts ATL
Sep 26, 2021 01:59 PM
drebbrnator
Dec 27, 2018 07:02 PM
Quiggs321
Sep 3, 2015 04:28 PM
Solmors
Aug 21, 2015 10:11 PM
Stubbs
Jul 28, 2015 09:23 PM
