Squeaking Sound under 25 mph
Old Jul 27, 2008 | 06:21 PM
Scrapin 240's Avatar
Hi Everyone,
I've been having a problem with a wheel squeak, and I can't really tell which one as it happens when going under 25 mph. I've noticed it especially since I changed my brakes recently, but it happens when its rolling. any thoughts? i have 23,000 miles on a '05
Old Jul 27, 2008 | 09:52 PM
alnielsen's Avatar
I had a squeak when I hit the brakes or went over a bump at low speeds. Then the lower control arm broke. Check for cracks around were the alignment adjusters are.
There is also a TSB out for the swaybar endlinks.
Old Jul 27, 2008 | 09:58 PM
Im_DANomite's Avatar
I love GOOOLD
it's probably your brakes. it started AFTER you changed your brakes. did you apply any kind of lube on all the contact points of the brakes? does the sound change with the speed of the wheels?
Old Jul 28, 2008 | 08:00 AM
no lube on brakes, and the sound/squeal does get "faster" (get most consistent)as i go faster.
92trbolzr
May 18, 2025 09:04 AM
theblinkof
Oct 4, 2023 05:24 PM
Digitz0070
55
Jul 25, 2017 08:40 PM
RX-8 Racing
20
May 14, 2016 06:25 PM
Racingjunkie
Sep 29, 2015 05:05 PM
