SPIED!! RX8 MR edition
Rating: Thread Rating: 5 votes, 5.00 average.
Old Jul 23, 2008 | 12:47 PM
dmp's Avatar
dmp
RX8 and a Truk....
WOW!
I snapped this at work yesterday.
Old Jul 23, 2008 | 12:48 PM
SideOfBacon's Avatar
belongs in what not to do to your car
Old Jul 23, 2008 | 12:50 PM
TopGear8's Avatar
mkuhnracing.com
Ha, some guy is actually selling those right now in the FS section...
Old Jul 23, 2008 | 01:02 PM
Unknown_Driver's Avatar
Give Me Another Rotor!
it would probably look better wingless and without the stupid useless sunroof visor
i give it 2 thumbs down
Old Jul 23, 2008 | 01:03 PM
Spinning Sushi's Avatar
I <3 Sushi
Those are from RX8Strakes.com and they're called Vortex Generator Fins. http://www.rx8strakes.com/index.asp?...PROD&ProdID=99
They are actually proven to work, surprisingly.
Old Jul 23, 2008 | 01:07 PM
all to be defeated by the sunroof visor guard thing
rglbegl's Avatar
Baned
To bad their effect at freeway speeds is practically nothing.
There is a debate goin on over on the 7 forums about these.
They are great for a race car, but for commuting . . . . . . . .they are nothing more than ricer jewelry
Old Jul 23, 2008 | 01:08 PM
jiggawha1's Avatar
Tejas
I wish I couldve snapped a pic but I saw a Yellow 8 the other day with those stupid fender accents that come off the oldmobiles....you know the little oval chrome things that the swangas have....yes on a 8
Old Jul 23, 2008 | 01:39 PM
dillsrotary's Avatar
jersey fresh
That car in the pic is actually a member here, its a pretty good looking build minus the vortex generators.
Old Jul 23, 2008 | 01:56 PM
dmp's Avatar
dmp
RX8 and a Truk....
I didn't notice a build..just stick-on stuff.
I'd seen it several times driving around - didn't notice the Vortext stuff till yesterday.
I appreciate their enthusiasm - a lot. My kar still looks st0ck, going on 4 years later.
Old Jul 23, 2008 | 02:43 PM
C Ya L8r's Avatar
I hear they give you like +2mpg!!!
Old Jul 23, 2008 | 03:19 PM
nvrfalter's Avatar
tonybob failpants
im pretty sure they do work, but on a race car with a functional spoiler only.
Old Jul 23, 2008 | 03:35 PM
paulmasoner's Avatar
Asshole for hire
Fwiw
This article is not about fins on an automotive application, but much/all of the science behind it still applies...
Common sense tells me that to even see minimal advantages under any conditions, the fins have to be placed fairly perfectly... you cant just go stick some fins on so they look straight and get the same current eddy effect.
http://www.lmglasfiber.com/Products/...odynamics.aspx
Vortex generators
A wind turbine blade does not have the same aerodynamic efficiency along its entire length. Towards the root, thick airfoils are used to enable the blade to bear its own weight. The blade is circular at this end, to permit mounting on the turbine. These factors have a negative effect on the blade’s performance.
Vortex generators consist of a number of small fins that protrude over the interface that occurs when the wind moves over the surface. These fins are mounted opposite each other at a certain angle that causes counter-current eddies in the air flow.
Vortex generators result in the flow of air subsequently separating from the surface at a later point, i.e. at higher wind speeds. This delays the moment when the blades stall and thus lose their capacity to produce power – the lowest part of the blade is thus efficient during a greater part of the turbine’s production time.
Vortex generators can boost blade performance by up to 4–6
Old Jul 23, 2008 | 05:03 PM
Cromus's Avatar
I love the look of them
Old Jul 23, 2008 | 05:08 PM
nvrfalter's Avatar
tonybob failpants
this is the part that matters. it keeps the air flow running on the surface of the car until it reaches the FUNCTIONAL rear wing spoiler, thus adding more downforce
dweezil22
NE For Sale/Wanted
12
Sep 9, 2015 10:50 AM
vetteor8
Aug 9, 2015 05:56 PM
Rx808BI
Aug 9, 2015 10:06 AM
robd1337
Jul 31, 2015 09:35 PM
AussieGray
Jul 16, 2015 03:58 AM
You have already rated this thread Rating: Thread Rating: 5 votes, 5.00 average.
