MS Exhaust - easiest way to connect pipe with exhaust??
Old Jul 18, 2008 | 08:08 PM
mshea's Avatar
Yikes. Even on jack stands, old exhaust came off easy. Didn't even need to remove rear plastic (via creative manuevering). New MS exhuast is mounted in it's bushings; new pipe is loosely secured to the spring bolts.
But how the f*&%k does one connect the pipe to the exhaust?? The tolerance between the inside and outside diameter is a PITA to slide together on ones back!!!!
Any suggestions?
Threshermal
Apr 15, 2020 09:43 PM
RXFEVER
Aug 29, 2018 10:14 AM
r-enzyme
Oct 1, 2015 01:27 AM
Rupanrx
Sep 4, 2015 06:44 AM
