tire fitting
Old Jul 16, 2008 | 01:37 AM
XclR8's Avatar
tire fitting
I have 225/45/18 on my stock 04 rx8 rims will 225/40/18 fit? Thanks in advanced guys.
Old Jul 16, 2008 | 09:08 AM
416to212's Avatar
Utopia Taco Bell
Yes, the 225/40/18s will fit your stock rims but your speedo will be reading higher than your actual speed because you have effectively reduced the diameter of your wheel.
http://www.paspeedo.com/calculator.htm for more info.
Old Jul 16, 2008 | 09:36 AM
try 245-40-18's
Old Jul 19, 2008 | 09:10 AM
MadDashRX8's Avatar
Resu Deretsiger
Originally Posted by dannobre
try 245-40-18's
I concur. Even with a little drop (Tein s-tech) the tires fit fine. 225/40... What drives your desire to go to a shorter tire?
Old Jul 19, 2008 | 04:53 PM
Old Rotor's Avatar
+1 THE 245x40 are the best upgrade. Some have pushed it to 275X35, but with a few problems and more $$ why? Here is a site to help you with the size and how much it will change your speedometer. Put orig on left and change size on the right side. Then look at differences and then speed variance on bottom.
http://www.miata.net/garage/tirecalc.html
Old Jul 19, 2008 | 09:34 PM
04RX8man's Avatar
Rotary Powered Countryboy
yeah i have the 245 40 18's and they are nice i mean if you're already dropping the sidewall height y no tmake them wider also?
Old Jul 19, 2008 | 11:26 PM
Silver_Surfer's Avatar
I4NI
I got 225/40-18 on my 8. Even with the Tein S springs the tires are just inside the fenders.
Why? A lighter tire and a little lower gear ratio cant hurt. I speedo is only off by 3mph(I drive by a posted speed trap every day).
Old Jul 20, 2008 | 12:01 AM
kersh4w's Avatar
Hit & Run Magnet
so apparently the closest fit in a wider tire is actually a 255/40/8.
that will fit on a stock rim too. not ideal for 8" wide rim, but it'll fit.
Prescription 8
Non-Rotary Swaps
117
Feb 14, 2018 12:07 PM
hppy4u
Gulf For Sale/Wanted
9
Dec 3, 2015 09:11 PM
OnebaddRx8
Oct 17, 2015 10:05 PM
CMRine04
Sep 17, 2015 10:04 AM
Series I Do It Yourself Forum
Sep 6, 2015 01:04 PM
