Hi Beams and headlight alignment
Old Jul 9, 2008 | 04:36 PM
alphamale's Avatar
alphamale
Pulling into the garage yesterday, I noticed that my driver's side hi-beam is about a foot higher on the wall than the passenger side. This surprised me because the low beam pattern seems proper. Is there a separate adjust for the hi and low beams or does the whole light housing move together?
Old Jul 9, 2008 | 08:37 PM
Jon316G's Avatar
Grasshopper
I know that the service manual for headlight alignment tells you to turn the low-beam on for the procedure and then to turn the adjustment screws. No mention on doing one beam at a time.
Makes me think that it moves the whole headlight housing... maybe someone can chime in with a more definitive answer.
Old Jul 9, 2008 | 08:44 PM
Easy_E1's Avatar
I would check to make sure the bulb is securely in it's socket. Sounds like it might be loose and maybe moved. I know of no way to adjust the highbeam bulb by it's self.
Old Jul 9, 2008 | 09:39 PM
Nubo's Avatar
Lubricious
I don't recall an adjustment for the highbeams.
Old Jul 9, 2008 | 09:57 PM
alphamale's Avatar
alphamale
I had this thought too. I'll check the bulbs.
drlubell
Sep 26, 2015 11:58 PM
vapor2
NW RX-8 Forum
Sep 17, 2015 07:43 AM
yankeepicker
Sep 11, 2015 05:42 PM
