Mazsport JUST INSTALLED!!!
Old Jun 27, 2008 | 02:25 PM
Chi-Tom8's Avatar
Talking Mazsport JUST INSTALLED!!!
got a couple questions... just installed my MAZSPORT turbo kit.. theres a lot of BS going around read a lot of unnecessary CRAP so im just going to ask.
Stock Internals i need to know what is a safe Boost for the turbo. and where can i get a good tune? willing to drive
Old Jun 27, 2008 | 02:27 PM
what fuel management are you using? Int-x?
Old Jun 27, 2008 | 02:35 PM
Find somebody who knows how to do a Dyno Tune.
Int-X is based on Motec (I think)
If its AP, well, u should get a MAP from somebody.
Old Jun 27, 2008 | 02:45 PM
maxxdamigz's Avatar
Baro Rex
Where are you? As for how much boost for stock internals - that really hasn't been proven out to any degree yet. People blow up all sorts of stuff before they hit that limit right now. You should be good to run 10 psi, maybe 12 - maybe 330 whp. You could blow an engine at 6 psi with a bad tune/abuse so..... I think MM is running up to 14 psi but that's probably "you're on your own" territory for now.
Call Mazsport and if you can get in touch with Scott, he can tell you what WHP he's seeing from the kits at what levels of boost.
Old Jun 27, 2008 | 04:00 PM
Red Devil's Avatar
Microtech, not Motec.
A-Spec is in Chicago and has been tuning rotary engines for years. Also Hahn Racecraft or Werks can probably handle the task.
Old Jun 30, 2008 | 12:21 PM
mdw1000's Avatar
I'll snap his neck.
PM importshowoff84 about Performance Auto Works in Plainfield. They are working on tuning his Esmeril kit with the IntX. I think it is their first RX-8.
Old Jun 30, 2008 | 12:54 PM
GrRx8MaZdA's Avatar
90% Carbon-100% Power
Which turbo kit did you install?Which type?And in how many days??
Old Jun 30, 2008 | 05:17 PM
CraigRX8's Avatar
CraigRX8
what he said, oh and pics
galognu
Rotary Swaps
138
Nov 16, 2020 05:20 AM
Zube6115
Sep 30, 2015 12:57 PM
Learners_Permit
Sep 27, 2015 07:38 PM
Evan Gray
Sep 26, 2015 12:30 PM
