Best tire pressure for 275/35 R18 RT615
Old Jun 26, 2008 | 04:26 PM
psonoda's Avatar
Less Weight = Better RX8
I tried the search, but no real luck. Does anyone have an opinion of tire pressure for this setup 275/35 R18 on 9.5" wide wheels. I started at 40 PSI but I am thinking this may be two high. Any thoughts?
Old Jun 26, 2008 | 04:36 PM
LionZoo's Avatar
road warrior
I think I've heard from Brian Goodwin that 29 psi works pretty well.
Old Jun 26, 2008 | 05:38 PM
magikone69's Avatar
i have that size in 19's and ive played with multiple setting, and i actually am very comfortable at 27psi..i have great rear grip and i eliminated all of that "bouncy" skidding feeling when htting a high speed turn. Not sure how this will work on tire wear and such but it feels comfortable for everyday and feels great when having a lil fun. My front tires 27 psi on 235/35/19
Old Jun 26, 2008 | 06:40 PM
Peppy@kacework's Avatar
Hoarder of RPF1's
I have mine at 32psi front and 30 rear.
Old Jun 26, 2008 | 07:53 PM
nuke0907's Avatar
Never Blend In
your pressure is on the sticker inside the door jamb. lower it to get a little more grip.
Old Jun 26, 2008 | 09:34 PM
psonoda's Avatar
Thanks for the input. I think I will try this setting. I will let you know how it works for me.
Old Jun 27, 2008 | 02:51 PM
BRODA's Avatar
Not yet famous
I run 28 psi cold pressure at all four corners for autocross, but I would probably suggest a couple more lbs for street.
Old Jun 27, 2008 | 03:00 PM
psonoda's Avatar
I lowered my air pressure to 34 front and 32 rear. It does corner better and has less understeer. I may try a lower number but I need to drive it for a couple of days first.
Thanks Guys.
cliffkemp
Dec 24, 2024 10:48 AM
hufflepuff
May 30, 2016 10:45 AM
snowrydr01
Nov 23, 2015 09:40 AM
