Where did you mount your Battery?
Old Jun 15, 2008 | 08:29 AM
PoLaK's Avatar
Son what is your Alibi?
See the picture below, I'm aware that I could just make some cleaver mount, but to save me hours of bending and re-bending could someone post some pictures of how you did yours?
PS you can see my remote terminal and master cut off switch mount by the air pump.
Old Jun 15, 2008 | 11:08 PM
PoLaK's Avatar
Well heres what I did after figuring it out on my own.
Turns out that if you take the Metal Jacket off the odyssey pc680 and tilt it down into to the stock battery tray terminals facing the rear of the car the fit is so snug that I don't think you need any sort of tie down. Here is a little mini-diy of my relocate.
All cables I made with quick car racewire placed into ring terminals with molten silver solder inside, than crimped, and heat shrink placed over.
I cut up the stock positive cable EPS fuse holder and assembly to allow me to attach a positive wire extension from the stock stuff up to by the washer fluid bottle.
You'll see pictured two positive cables one to run to the positive terminal on the battery with 250amp ANL fuse; and one running from the positive OEM assembly.
Like I mentioned the OE battery box fits the PC680 perfectly so theres not need to really mount it any other way, less your feeling industrious. Here I cut holes in the bottom of the box and in the side for the terminals to come through.
Here you can see my battery siting snugly in the stock box.
Attached Thumbnails Where did you mount your Battery?-img_9042_1280_medium.jpg   Where did you mount your Battery?-img_9045_1280_medium.jpg   Where did you mount your Battery?-img_9049_1280_medium.jpg   Where did you mount your Battery?-img_9051_1280_medium.jpg   Where did you mount your Battery?-img_9050_1280_medium.jpg
Old Jun 15, 2008 | 11:16 PM
PoLaK's Avatar
This is my first bit of metal fabrication ever (okay second after I fudged up the "rough" version of this about 9 months ago). It has positive and negative charging posts, and a master disconnect.
Down by the washer fluid tank hole i sanded a grounding hole for the negative charing post.
Here it is all wired up, you see that negative charging post has a cable going down to the sanded hole pictured above. The positive charging post connecting to one side of the Master switch, the positive terminal on the battery connecting to that same side. Then on the opposite side of the MS is the positive OEM extension cable.
Painted a nice flat black
Assembled
Attached Thumbnails Where did you mount your Battery?-img_9052_1280_medium.jpg   Where did you mount your Battery?-img_9056_1280_medium.jpg   Where did you mount your Battery?-img_9058_1280_medium.jpg   Where did you mount your Battery?-img_9060_1280_medium.jpg   Where did you mount your Battery?-img_9063_1280_medium.jpg
Old Jun 15, 2008 | 11:33 PM
PoLaK's Avatar
Installed in the engine bay.
And some blow torch terminal making pictures.
Attached Thumbnails Where did you mount your Battery?-img_9074_1280_medium.jpg   Where did you mount your Battery?-img_9075_1280_medium.jpg   Where did you mount your Battery?-img_7910_medium.jpg
Old Jun 16, 2008 | 12:14 AM
kersh4w's Avatar
Hit & Run Magnet
that looks really good dude.
Old Jun 17, 2008 | 05:20 AM
ILoveFI's Avatar
That seems like it would also make an effective anti theft device if placed inside under the dash.
Old Jun 17, 2008 | 12:50 PM
kersh4w's Avatar
Hit & Run Magnet
we already have an ignition disabler.
Old Jun 17, 2008 | 09:41 PM
TheGreatLouisianaRoadkill's Avatar
what is the main advantage to doing this?
Old Jun 17, 2008 | 10:15 PM
PoLaK's Avatar
Battery is lower, and lighter (14lbs), and closer to the axle compared to OEM (38lbs).
I might just mount it even lower and further back if I feel like I want to fab up a box for it.
Old Jun 17, 2008 | 11:19 PM
Highway8's Avatar
Registered RX8 Nut
I put the stock battery in the trunk. I am waiting for the odyssey pc680MJT to be available (back ordered nation wide) so I can save some weight. I weighed my stock battery and it was 35 LBS plus 3 lbs for the box and hold down. The weight of the new positive cable was only 3.5 LBS, I reused one of the stock negitive cables to ground it in the truck and no problems so fair. The odyssey pc680MJT (metal jacket with SAE terminals) says 15.6LBS I believe and the hold down is less then 1 lbs so total weight is roughly 16.5LBS. So i took 38LBS from the front right and put 20LBS on the right rear. 18LBS less and better balance. for about 2 hours of work and $250.
Old Jun 18, 2008 | 08:33 AM
psonoda's Avatar
Less Weight = Better RX8
Here is my battery remount.
The battery fits snugly into the original bottom of the battery tray. I remove all the extra battery connections to further reduce weight. So far, it has run great. I just had my engine replaced at Mazda and they did not say anything about it.
92trbolzr
May 18, 2025 09:04 AM
cliffkemp
Dec 24, 2024 10:48 AM
Evan Gray
Sep 26, 2015 12:30 PM
