car stalls at all times after boost gauge install
Old Jun 8, 2008 | 12:43 PM
gregs's Avatar
Pull My Finger
last night i installed my prosport boost gauge and was not getting the boost gauge to read boost, i used the same vacuum line as the bov which is located under the throttle body. so this morning i was looking at the vacuum line and i noticed there was a small one way valve on the line so i removed it and tried again "walah" now i seeing boost but at stops the car stalls and struggles to idle also during driving the car backfires alot too...so what im thinking is to place the vacuum T fitting before the one way valve should this correct my issue? or should i get my boost gauge vacuum source elsewhere?
thanks
greg
Old Jun 8, 2008 | 12:58 PM
09Factor's Avatar
Original Turbo 'd Auto !!
The "T" should be placed before the One way valve. With the green side of the valve toward the "T" fitting.
Old Jun 8, 2008 | 12:59 PM
mysql's Avatar
Doppelgänger
vfad nipple on the bttom of the throttle body is a popular choice. I don't know why you're looking at the back of the intake manifold.
Old Jun 8, 2008 | 01:39 PM
gregs's Avatar
Pull My Finger
ok thanks for the info
Old Jun 8, 2008 | 06:24 PM
gregs's Avatar
Pull My Finger
ok so i just came back from a drive i moved the one way valve (greddy rs bov,one way valve, t fitting, vacuum port under throttle body) the green is facing the t fitting...car holds better at idle but still struggles to stay on and in between shifts sounds like im getting compressor surge???
Old Jun 8, 2008 | 08:21 PM
gregs's Avatar
Pull My Finger
now i disconnected the boost sensor and put everything back to normal and im still getting a rough idle at stops and at times it will stall?? i reversed the one way valve green facing the bov and idle is perfect while coming to a stop but im getting compressor surge??
Old Jun 8, 2008 | 10:49 PM
RE-check everything.
Old Jun 9, 2008 | 12:02 AM
slavearm's Avatar
Boost Junkie
You have a vacuum leak somewhere would be my guess. Recheck all the lines.
Old Jun 9, 2008 | 08:52 AM
gregs's Avatar
Pull My Finger
would a pressure test find if there were a leak?
rotorocks
47
May 11, 2016 03:23 PM
RXeckless
Aug 16, 2015 12:52 PM
escapedan
Series I Do It Yourself Forum
Jul 29, 2015 10:44 PM
dbarber
Jul 25, 2015 01:34 PM
Bamaham
Jul 23, 2015 08:08 AM
