compressor surge with GReddy RS bov
Old Jun 7, 2008 | 06:24 PM
ChattyRX8's Avatar
Now turbo!
I have the GReddy turbo with Mazsport CAI and Greddy type RS bov. 5psi or lower and the bov whooshes fine. Anything above 5psi and I hear the infamous choo choo choo choo. Should I try adjusting the bov or is this due to my completely stock exhaust creating a huge restriction?
If I should adjust the bov, should I go harder or softer? GReddy tech support was no help, and 45 minutes of searching the forum got me no answer. Please help! I'd really like to keep the GReddy snail healthy til I can save up enough for Satan's Hairdryer!
Old Jun 7, 2008 | 08:42 PM
halimsteven's Avatar
i dont think you need to change the BOV settings, because i have the same sound too. i think it's characteristic of rotary when it has turbo. i believe, because BOV sound how it is supposed to be when you put little boost, and you shift it. i think it's fine
steven
Old Jun 8, 2008 | 11:42 AM
Cattywampus's Avatar
Turbos blow!!
BOVs let out a steady flow of released air when the the throttle is let off. That's what the bov is for. If you getting the "choo choo choo choo" I would guess the bov needs to be adjusted. Could be wrong but that's the only thing I can think when putting reasoning for a bov to thought.
Old Jun 8, 2008 | 11:47 AM
mysql's Avatar
Doppelgänger
BOV venting has nothing to do with your exhaust. And your stock exhaust is going to be fine. My dyno numbers in my sig is with a full 2.5" exhaust.
steven
when the bov vents, all the air should be released. You should not hear compressor surge.
You should have the BOV at the loosest setting possible that still holds the boost without leaking.
Or you can upgrade to something like the synchronic that will not allow compressor surge to happen in the first place.
Old Jun 8, 2008 | 03:07 PM
Psychofox's Avatar
我愛台妹,台妹愛我
sounds like the valve is stuck and cant open fully to release the higher pressure (5 and over) ?
When i had my type RS, i had compressor surge at very very low boost. I never experience comp surge over 1 psi. I had to loosen up the preload spring to elimiate surge.
Old Jun 8, 2008 | 05:49 PM
ChattyRX8's Avatar
Now turbo!
This is such a newb question, but how will I know when it's leaking? Right now I get 19"-20" Hg at idle.
How much should I adjust the allen screw at a time? 1/4 turn? half turn?
Jason, do you know if titan motorsports still offers the flange adapter for the synchronic? Since I already have the type RS flange welded on, obviously I'll need to change it somehow to fit the Synchronic.
Old Jun 8, 2008 | 05:53 PM
mysql's Avatar
Doppelgänger
they sell a greddy flange adapter (I use it). I think it runs $20 or so more for it.
RXFEVER
Aug 29, 2018 10:14 AM
yurcivicsux
192
Sep 12, 2017 10:54 PM
05rx8mazda
Nov 28, 2015 09:42 AM
jDt!
Oct 2, 2015 04:04 PM
