favorite mod (non FI)
Old May 28, 2008 | 11:17 PM
LiL BenNy's Avatar
Bubblicious? DEF.
so after being FI and going back to stock with the exception of sway bars and a midpipe i have kinda been falling out of love with my 8... just curious what are some of your favorite mods that made you wanna drive your 8 more?
Old May 28, 2008 | 11:43 PM
af short shifter.
Old May 28, 2008 | 11:46 PM
paulmasoner's Avatar
Asshole for hire
+1 AFE short throw...
also i like music, i like to listen to music in my car. so upgrading my cd collection was a pretty good mod.
P.S. stop listening to bad music
http://youhavebadtasteinmusic.com/
Old May 29, 2008 | 12:20 AM
TheGreatLouisianaRoadkill's Avatar
why you went back to stock? i cant wait to get the AF short throw.
the mod i love the most is my exhaust and high flow cat. redline never sound so beautiful.
Old May 29, 2008 | 12:45 AM
kersh4w's Avatar
Hit & Run Magnet
he blew his engine.
Old May 29, 2008 | 04:42 AM
Fanman's Avatar
Yep, pretty much what I did as well. Best mod I ever made to the car was either the RB suspension package, or the goodridge stainless steel brakelines.
Old May 29, 2008 | 03:25 PM
imput1234's Avatar
I ♥ Drifting!!!
I don't have it, but lower your final drive. You'll be happy
Old May 29, 2008 | 06:09 PM
prospectjtaz's Avatar
i was just readin the final drive thread, 1700, dont think so, unless money is burnin your pocket
Old May 29, 2008 | 06:44 PM
the stainless steel lines made that much a an improvement?
Old May 29, 2008 | 06:48 PM
ss lines do MAKE A HUGE improvement on brakes. I got them put in when i di my brake job, running russell lines. None of that garbage spongy feeling, i feel like hte car will stop at any speed, with that firm hold. one of my favorite mods.
Old May 29, 2008 | 07:44 PM
Stealth is a nice guy
Old May 29, 2008 | 07:46 PM
kevinD1226's Avatar
man its hard to enjoy driving a na 8 after driving a turbo 8 i honestly dont know what u can do to get that love back to ur car, try buying some new wheels and maybe a mazdaspeed kit
Old May 29, 2008 | 07:47 PM
whoneedspistons's Avatar
mazsport ignition kit
Old May 29, 2008 | 07:48 PM
mysql's Avatar
Doppelgänger
my fav non FI mod was a turbo kit.
That counts right? The car wasn't FI before I installed it.
Old May 29, 2008 | 08:10 PM
alnielsen's Avatar
A lightweight flywheel is a fun mod. In my case it was a Mazdaspeed.
Old May 29, 2008 | 08:13 PM
RedefineRX8's Avatar
Super-impreza!
mazsport ignition
Old May 29, 2008 | 08:15 PM
mysql's Avatar
Doppelgänger
Originally Posted by RedefineRX8
mazsport ignition
funny. That's my least favorite mod of all time.
Old May 29, 2008 | 08:35 PM
rx8thunder's Avatar
Being (new) single rocks!
^ Why?
Old May 29, 2008 | 09:16 PM
mysql's Avatar
Doppelgänger
Because I have reason to believe my engine was damaged due to the coils not using the same dwell settings as the OEM coils did. This was before there was even any mention of dwell changes or that there was any risk by upgrading the ignition system. Dwell is basically charge time to power up the coils. Since the mazsport coils are not like the OEM coils, they require a different charge time to be set. If your coils don't charge up enough, the spark will be weak. If the leading spark plugs don't fire or the spark is too weak to ignite the fuel, you risk massive detonation when the trailings do. In boost that can cause catastrophic damage.
In two weeks my engine will be torn apart and rebuild from scratch. The engine actually runs fine, and has normal compression, but the front iron housing is cracked and leaks oil. No way to fix it other than to rip out the engine and replace the housing.
Yes, for all my random dealings with FI and other performance mods, it was the lowly ignition coil that brought the behemoth down.
Old May 29, 2008 | 09:28 PM
suay's Avatar
Work hard Drive Hard!
My Mod?
WOULD HAVE TO BE MY LAMBO DOORS. WAiting on my Stage 1 turbo with the works (all mazsport carries) hopefully I can later say "turbo kit"
Old May 29, 2008 | 09:34 PM
rx8thunder's Avatar
I haven't installed my mazsport ignition mod yet -- plan to this weekend. I'm NA with a Cobb. Any advice before I install or how I use Cobb with it?
Old May 29, 2008 | 09:36 PM
rx8thunder's Avatar
One of my favorite mods is new underdrive pulley -- seems to deliver better throttle response off the line (less hesitation). I also love the drop and performance of Tein S Tech springs
Old May 29, 2008 | 10:16 PM
mysql's Avatar
Doppelgänger
I haven't heard of any issues with NA use, likely because you don't need to ignite as much fuel. If you bought through Jeff, make sure to tell him to give you the map with dwell changes and hope nothing goes wrong.
The detonation I experienced was not something that happened all the time, so much like people saying "I didn't flood, therefor my car cannot flood", not having issues doesn't mean you cannot have issues.
btw, the issues I had was when I had the int-x, so it could be any combo of things that manifested in the negative outcome. You might not have any problem with the AP. It's hard to say.
Old May 29, 2008 | 10:32 PM
rx8thunder's Avatar
Just wait........
True enough Charles, I am most excited about the new clutch and flywheel! Please send it already
Old May 29, 2008 | 11:46 PM
good to know. i may end up bumping that mod further up my list.
