Widefoot Racing
Old Nov 16, 2003 | 04:18 PM
Speed Racer's Avatar
Certified track junky!!!
Widefoot Racing
my10ae and myself dropped in on Widefoot Racing this weekend. David (owner of Widefoot Racing) is in the process of setting up a permanent shop in Hillsboro, NH with facilities to do R&D, CNC machining, engine testing, etc... He will be setup to do practically any custom job.
He has made several custom parts for RX-7s such as brake caliper brackets for larger rotors, sway bar mounts, cooling ducts for front brakes, and a "widefoot" throttle pedal extension to make toe & heel easier. The sample parts that we saw looked well designed and the quality was top notch. I'm definitely looking forward to see how David will apply his ingenuity to the RX-8 in the coming months.
While we were there David mentioned that he would like to expand his range of products to also include the RX-8. Right now he is looking for suggestions from people who own RX-8s. Here are a few that we came up with:
  • Harness bar
  • Custom brackets for racing seats
  • Fender strakes
  • Carbon fiber brake ducts
  • Oil dipstick that is easier to reach and read
  • "Widefoot" throttle pedal extension
If you can think of other items that you would like to see for the RX-8 please add them to this thread. Thanks!
Old Nov 16, 2003 | 05:26 PM
Omicron's Avatar
Longer clutch pedal assembly or shorter accelerator pedal assembly. After building a clutch pedal extension myself (see https://www.rx8club.com/showthread.p...threadid=13709 ) I can honestly say it makes a HUGE difference in how comfortable the car is to drive. However, a better solution would be a replacement assembly for the clutch pedal or accelerator. If they build these, I will definitely buy one, and I have a feeling quite a few other people will as well.
Thanks...
Old Nov 16, 2003 | 05:53 PM
Interesting idea. :D
Old Nov 16, 2003 | 06:31 PM
my10ae's Avatar
Moderator
Speed Racer, good to see you again today...it's been a long time Anyways, David seems like a a nice guy with all the right equipment. I think the idea's that were brought up today were very good and should be well accepted in RX-8 community. If anyone else has any idea's for enhancements for the 8, please post them up on this thread.
Kudo's to David and his crew at Widefoot Racing.
Kevin
Old Nov 17, 2003 | 10:51 AM
A few other ideas were brought up on this thread.
  • Engine management
  • Exhaust manifold
  • Lighter pulleys that are harmonically balanced
  • Light weight flywheel
  • Twin-plate clutch
  • Larger throttle body
  • Modify porting on rotor housing
Old Nov 17, 2003 | 11:47 AM
Bigcat44's Avatar
Good to see there are several NH 8s out there. I am from Londonderry well spent most of my time in Nashua, but am currently stationed in New Mexico (one hell of a climate difference) Hopefully I will be taking a road trip out that way this coming summer with my 8, we will have to all get together for sure!
Old Nov 17, 2003 | 11:57 AM
Spin9k's Avatar
Momentum Keeps Me Going
Originally posted by Omicron
Longer clutch pedal assembly or shorter accelerator pedal assembly. ... I can honestly say it makes a HUGE difference in how comfortable the car is to drive.
YES! I've taped a rubber block (1.5")on my clutch pedal and WHAT A DIFFERENCE in driving (I'm 5'8"). It's the best mod I've done to make my driving style less jerky and WAY more comfortable!
Now, my right foot is out straight, my seat is back, I'm away from the wheel enough to be comfortable finally, AND I CAN STILL SHIFT without reaching my toe out pointy style or shifting to the left in the seat or alternatively getting all bunched up at the wheel before the mod.
Make a better solution and I'll get it too!
Old Nov 17, 2003 | 02:05 PM
Omicron's Avatar
Spin9K, glad you like the idea too. I'm 6 foot, but most of my height is in my torso, so changing the pedal "length" helped me too.
Speed Racer, how about you suggest ADJUSTABLE pedal replacements?
Also, there's a whole 'nother thread that just got going discussing performance enhancements that can be done to the 8 other than intake, exhaust, and FI. Check it out at: https://www.rx8club.com/showthread.p...threadid=14703
Thus far, the most interesting things to come up are:
- Lightweight pulleys, standard size or underdrive
- Lightweight flywheel
- Replacement differential gears
- Twin-plate/Strengthened clutch
Old Nov 21, 2003 | 06:36 PM
my10ae's Avatar
Moderator
Anyone else have idea's for some enhancements/parts for the 8?
Old Nov 21, 2003 | 07:59 PM
Omicron's Avatar
4 inch, rotary shaped exhaust tips. Seriously.
And LESS EXPENSIVE side strakes. $200+ is ridiculous.
Gimme time, I'll think of more...
Old Nov 21, 2003 | 08:11 PM
mikeb's Avatar
100% Italian
mike A did a photoshop of my car with rotor exhuast tips
Old Nov 22, 2003 | 11:54 AM
Omicron's Avatar
Saw that, that's what made me think of it :D
Old Nov 22, 2003 | 02:38 PM
my10ae's Avatar
Moderator
Mike:
Can you post up a pic of the rotor exhaust tips for everyone to see?
Old Nov 22, 2003 | 03:04 PM
Omicron's Avatar
Here's what the photoshopped up tips look like. Check out this thread for more details: https://www.rx8club.com/showthread.p...threadid=15050
Old Nov 22, 2003 | 03:07 PM
VividRacing.com's Avatar
I too would be happy with a harness bar.
Magnesium's Avatar
Lurking troll
A little off topic, but I went to school in Hillsboro, NH from 1st to 3rd grade back in the 70's
Old Nov 23, 2003 | 12:25 PM
Omicron's Avatar
So Speed Racer, how does Widefoot Racing feel about the suggestions thus far? Are they beginning development on any of them?
And here's another BIG suggestion, and one that might be right up their alley: A thoroughly massaged "crate motor" version of the Renesis, built stronger and lighter, with massaged intake and exhaust ports, etc. Perhaps one with forced induction. See this thread for exact details on what I'm talking about: https://www.rx8club.com/showthread.p...threadid=14703
Hunterkelley24
Jun 14, 2022 08:32 AM
galognu
Rotary Swaps
138
Nov 16, 2020 05:20 AM
RX8mzda
Oct 1, 2015 10:17 PM
RAVSPEC
Vendor Classifieds
Oct 1, 2015 01:59 PM
drlubell
Sep 26, 2015 11:58 PM
