GI for FI: Turbo selection and/or build assistance
Old May 20, 2008 | 09:11 PM
eastcoastrotary's Avatar
goal = perfect rx8
Hey guys, I am starting to do some serious research into going FI, but haven't been able to come to an educated decision concerning the different turbo kits available. I am also seriously considering a custom build (by myself with forum/book/mechanic assistance). Before I do any discussion, I will state my goals for the upgrade:
1) Power - very simple goal: 300rwhp
2) Powerband - not as simple: I want a smooth buildup of power, essentially like stock but with a lot more oomph, all the way to 9000rpm. In other words, I don't want to be driving and suddenly loose control of the vehicle because my boost hits in the middle of a maneuver. I want the boost to hit quickly (super fast spool-up time) and to develop a relatively flat torque curve for 4000-4500rpm onwards. I intend to tune it myself (regardless of whether I buy a kit or build a custom system) with the Int-X. I know this category is picky, but it's one of my most important goals.
3) Reliability - pretty standard: after finishing the installation and nailing down the powerband where I want it, I don't want to have anything blow up on me. This basically means I want to keep boost low, but still high enough for 300rwhp. I also want to maintain the lowest engine temperatures possible to prolong component life and improve performance.
4) Appearance - simple aesthetics: I would like the turbo to be visible when I open the hood and to be able to hear a beautiful BOV sound while driving. From staticlag's review of the Esmeril Kit (great thread), he mentioned that an external wastegate also sounds very aggressive and enjoyable.
Applications of vehicle: my car is currently a daily driver, but that will change within the next year and it will become a weekend/project car. At that point, it will be used for joyrides, occasional autocross, and very occasional tracking. Essentially, the car will not be pushed to the limit on a regular basis, but it will happen occasionally.
So...what are your opinions? Are the available kits suitable for my goals? I've read many, many discussions of the various kits, but very few of them go into the complete detail that I'm curious about. Should I look into a buying kit components and modifying them? Or go all the way and build a kit from the ground up?
On a more specific note, do you believe that a fuel upgrade is necessary (from my readings, I think it will be)? How about an ignition upgrade (like the upcoming Esmeril model)?
Time is not a serious object for this project; I would prefer to work on it for two years and have it be amazing than go FI in six months and be disappointed. Thanks in advance for your input.
Old May 20, 2008 | 09:15 PM
Falken's Avatar
Drop it into 3rd
The Petit Supercharger sounds like your best option. Check out this thread:
https://www.rx8club.com/showthread.php?t=132628
The orange line is the petit supercharger, flatly increasing power all the way to 9,000, ending up just a hair above 300hp
Sounds perfect for you. No BOV sound, but as far as your performance requirements go it's spot on what you're looking for. An ignition upgrade is not necessary unless you plan on pushing your hp over 340 or so, at that point you get spark blowout, but nothing a mazsport ignition solution can't handle.
Old May 22, 2008 | 05:55 AM
goal = perfect rx8
Good call! I hadn't thought about supercharging. There seems to be a lack of torque relative to the turbos of similar horsepower, though. Do you think it would translate into a significant difference in drivability? I definitely think, however, that the Pettit has a beautiful powerband. Thanks for pointing it out.
Old May 23, 2008 | 12:33 AM
kersh4w's Avatar
Hit & Run Magnet
mazdmaniac version of the greddy turbo.
cant go wrong.
Old May 23, 2008 | 01:06 AM
MazdaManiac's Avatar
cant go wrong.
Not visible from the top, which is one of his design criteria.
Really, the only proper choice is the MazSport type 2.
Old May 23, 2008 | 02:02 AM
rotorocks's Avatar
RotoRocks Powered
Yep, or a custom build.
Old May 23, 2008 | 03:34 AM
california style's Avatar
Londons Yellow Peril
on the sound side of things, with a Pettit kit, you wont get the BOV whoosh, but you would get supercharger whine....
whoosh or whine, eh, choices choices.... 8)
Old May 23, 2008 | 03:38 AM
The Pettit doesn't really "whine".
It kinda grumbles.
Its not like an Eaton.
I just noticed this part of the original post:
Good luck with that.
Old May 23, 2008 | 09:31 AM
rotorocks's Avatar
RotoRocks Powered
^ for number 3.
lol Challenging project! Basically you are asking for a solution that will double the engine output and reliability.
And #2, you sure a hell won't get there with Esmerils kit.
Old May 23, 2008 | 09:58 AM
MazsportScott's Avatar
Mazsport.net
Wait until you see Type2 Ver 2
Old May 23, 2008 | 06:58 PM
arghx7's Avatar
supercharger. if you turbo a car, you are going to get more lag than you seem to want (lag/response is all in your head, everybody has a different tolerance for it), unless it is some bullshit turbo that isn't worth the gazillions you spent on the whole setup.
Old May 23, 2008 | 07:29 PM
the Pettit crew was talking about discontinuing the S/C so might not be the best option. (I could be mistaken, check the Pettit thread)
Mazsport 2 or Esmeril are your only options that fit MOST of your criterias. (#3 is a doozy)
Old May 23, 2008 | 07:42 PM
I would pick the Pettit SC, but I have a G8 GT now..............
Old May 23, 2008 | 08:07 PM
Falken's Avatar
Drop it into 3rd
Yes, 60 extra pound-feet of torque is going to feel VERY different.
Wait...WHAT?
Old May 23, 2008 | 08:22 PM
nuke0907's Avatar
Never Blend In
yeah, wtf?
Old May 23, 2008 | 08:38 PM
kersh4w's Avatar
Hit & Run Magnet
he wants to see the snail from the top?
the piping would be more than enough for me... hell, the 300whp would be enough for me. if i could get 300whp n/a i would. different strokes..
Old May 24, 2008 | 07:46 AM
rotorocks's Avatar
RotoRocks Powered
Originally Posted by 080522jk
管道疏通高压水射流清洗技术有如下优点:应用范围广,不但可以对管道进行清洗,疏通管道还可以用于工业设备(如换热器、锅炉、塔、疏通管道储罐等)的清洗;对管道设备无腐蚀,疏通管道不污染环境,管道疏通产生的污水易于处理。中拓公司引进德国URACA公司高压水射流清洗设备,其卓越的性能以及良好的清洗效果 受到广大客户的青睐
uhhh!
WTF?
Old May 24, 2008 | 12:34 PM
you let the cat out of the bag!! on your own.. funny..
speaking of cats!?
Old May 24, 2008 | 12:40 PM
kevinD1226's Avatar
u simply bought the wrong car, ive spoken to people with the mazsport, and greddy turbo kits and the car simply doesnt run as good as stock, and goin FI def. wont increase ur reliability status
Old May 24, 2008 | 12:52 PM
tajabaho1's Avatar
Destroying Threads
yea wait till you see the price tag!! 12k ftw!!
Old May 24, 2008 | 01:35 PM
You are brilliant!
Old May 24, 2008 | 06:17 PM
rotorocks's Avatar
RotoRocks Powered
You've spoken?
I just laughed for 2 minuts straight!
Old May 24, 2008 | 09:41 PM
goal = perfect rx8
thanks for the feedback. a few issues seem to have arisen, though. first, performance and powerband are my biggest priorities, and i would easily compromise aesthetics for a better-performing vehicle. second, i know that reliability will not improve and will always be an issue with such a significant modification, but i just don't want something that is notorious for engine trouble.
so...the mazsport type II turbo kit and pettit supercharger seem to be the current front runners. i'll search posts concerning both and continue researching. thanks again for your contributions.
Old May 24, 2008 | 09:45 PM
mysql's Avatar
Doppelgänger
Imagine if it had a turbo installed, that's another 60+ ft/lb more torque on top of that.
Old May 24, 2008 | 09:59 PM
Falken's Avatar
Drop it into 3rd
Haha, the Mazsport turbo and the Pettit blower are my front runners as well I'm torn completely just like you, I guess I'll keep watching this thread seeing as how nobody will reply to mine
Yes, when I said that I was referring to the gap between the torque of the Pettit kit and the Mazsport turbo, which upon more careful math is actually 66lb-ft. I figured that was what the OP was asking about as well.
